Question about Westinghouse LTV-37WI 37 in. LCD Television
Picture clarity My westinghouse occassionally has red and green "snow". I've tried uprading cables to HDMI and resetting factory settings with no difference. The problem comes & goes and usually if I turn off or unplug the tv for a few minutes it goes away, but usually comes back within an hour.
    Genius:
  • 1,554 Answers
Sounds heat circuit related, and if under warranty you should notify them before you have to pay for the tuner or sync board.
Posted on Feb 04, 2008
I have a Teac LE3285FHD Problem with the Teac LED television I have a Teac LE3285FHD and about 10 minutes ago, as we were watching a dvd, the picture/display went all weird and now the picture/display is...
Sounds like a for sure, cable issue, especially if your running Hdmi, try switching out the cables, when it comes to color runs and weird graphics its always starts with the cable....
May 28, 2011 | Televison & Video
PS3 HDMI No picture nor audio
  1. Make sure the HDMI cable is connected to the HDMI OUT port on the back of the PLAYSTATION 3 system. Connect the other end of the HDMI cable into the HDMI Input port of the TV or display monitor.
  2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive power button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light --> green light --> then back to red light). This will ensure that you have held down the power button long enough to reset the Video Output Settings.
  3. Turn on the PLAYSTATION 3 system and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor).
Jun 26, 2010 | Sony Playstation 3 (PS3) Console
When using hdmi outlet,,,the picture comes in for 1 second then screen turns all green
That HDMI port hub it properly shorted,tries used another HMI ports hub?Tries to reset the tv back to factory setting,by unplug,replug it an hour later,go to the tv menu go to PICTURE,go down to reset.So the Tuner board reset itself back to the factory setting,all the HDMI ports hubs,should work now or that HDMI port hub is shorted,or the Tuner board it dead.
Jun 11, 2010 | Sony KLV-S32A10 32 in. HD-Ready LCD...
Westinghouse 47"lcd tv
are you using an hdmi cable or the red blue and green cables that came with the xbox? if using the original cables there is a switch on them that sets it to HD or standard. hope that helps
Jun 06, 2008 | Westinghouse TX-47F430S 47 in. LCD TV
Picture goes to a lime green fuzz and then no piture or sound!
which AV connection are you using? HDMI or the cable supplied with the PS3, If using HDMI, you have to set the PS3 visual settings to HDMI, to do this, use the cable supplied with the PS3, and have the HDMI cable plugged in. Then while using the cables supplied with the PS3, switch the settings over to HDMI, then change the TV's input selector to your HDMI and confirm the settings changes. Hope it helps take care
Oct 17, 2007 | Sony Playstation 3 (PS3) Console
No more picture and sound
Tv was showing perfect picture now it's snow solution 1 please check antena wire & its socket. 2 check for dust where wire is connected. 3 loose contact or print break near tuner. 4 tuner defective.
Sep 15, 2007 | Sanyo DS27930 27" TV
Red?Green picture
If you are connected to a HD cable box or sat. rcvr. using component cables, I would then suspect a loose or bad blue connection or cable. If you have Comcast and have their supplied flat component cable this is a common issue.
Feb 12, 2007 | Toshiba 46HM95 46" HDTV
Westinghouse LTV-37WI 37 in. LCD Television Logo
160 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
