Mr Heater MH75KT - won't start with diesel
I bought a brand new Mr Heater MH75KT multi-fuel space heater, filled it with #2 diesel, and it will not burn. Igniter is throwing a good spark, fuel is flowing thorugh the nozzle, but no fire. If I press my finger over the vent nozzle the flame starts but as soon as I remove my finger from the vent the flame goes out and then the heater shuts off with the LED doing 6 flashes for no flame sensed. How does one make this heater burn diesel>
    Problem Solver:
  • 14 Answers
If the MH75KT is the correct model, then it is a Kerosene only heater. Fuels, like oil and diesel all have different ignition points.
http://www.mrheater.com/upload/newsletter/70276_MH_HS_50_75_125_175_210KT_REV%20A.pdf
See page 3 of the manual.
Posted on Feb 04, 2008
Added gas to diesel multi fuel turbo heater
Your talking about 1/8 cup of gas, per gallon of diesel. I think it should be fine but it will run hotter than usual. You will need to keep an eye on the flame and after it warms up. If the flame continues to pass by the cone then you will need to drain between 1 to 2 gallons out and store it (You will need to use your best judgement). Fill the heater back up with new diesel and use. when you run out, add 1 gallon of the tainted diesel to 2 gallons of new diesel and repeat. You will need to pay attention to the performance and make your own determination. Please remember that these units are to be used in well ventilated areas. They produce a lot of carbon monoxide. Good luck., .
Jan 07, 2014 | Reddy Heater-30-55,000 BTU Variable
I have a Mr. Heater MH75KT Forced Air Kerosene Heater and it starts and the fan spins but it shoots fire through the cone section. I cant get it to start like it would during normal use and I cleaned the...
Discontinue use and take of house , this unit could start a fire. I would call the factory and talk to one of there Tec , because it might be an on going problem with other units.
Dec 07, 2013 | Heating & Cooling
Big buddy Heater - 20 lb tanks won't keep pilot lit,
I had the same problem I called tech support and they said to turn the valve on the 20# cylinder on very slowly for the first 1/4 turn then all will be fine. There is an excessive flow check valve that causes restricted flow when the valve is opened quickly----------mine works fine now
Apr 09, 2013 | Mr. Heater Mr Heater Portable Buddy...
I have a 75000 kerosine heater that only runs a few min and shuts off and the led has a steady flash, (high limit switch open circut)
Jump the 2 yellow wires together if it stays running replace high limit switch under hood against the chamber
Feb 18, 2013 | Mr. Heater MH75KT
Can you burn diesel fuel
Hi, If this heater is the Reddy 170,000 b.t.u. heater, model # 170t professional series, then yes you can.It is a multi-fuel heater. Fuels it can use are Kerosene, JP8, Jet A fuel, 1&2 Diesel fuel, and 1&2 fuel oil. It must be this model 170T.
Sincerely,
Shastalaker7
Jan 19, 2010 | Reddy Heater-170,000 BTU Kerosene Deluxe
What will happen if I burn a diesel/ gas mix in a reddy heater 55000 multi fuel heater?
Hi, If the heater recommends kerosene or diesel only, and you mix gas into the situation, you will get an explosion and fire loosing not only the heater but most everything else.Unless the spec's say you can since it will use other fuels, gas would be one I would not use, mixed or not, like I say only if it says you can. At 70,000 B.T.U.s, as it says above, this Reddy heater burns hot anyway, and I don't want to put you in a dangerous situation by saying yes, go right ahead? So please check first, I would say no way. Good Luck, and Sincerely, Shastalaker7
Nov 21, 2009 | Reddy Heater R70 Portable Forced Air Space...
Heater wont stay lit unless cover is off. heater is dynaglo 12500
it souds like it is starveing for air, I would check all of the filters and the air line that runs to the combustion nozzle as it may have a crack or break in it. The nozzle does tend to get pretty hot and the lines get brittle after a while.
Jan 24, 2009 | All-Pro All Pro SPC K125 Forced Air...
Mr heater 75,000 btu kerosene heater
HLS should stand for high limit switch(control) this model does show one in the parts diagram.
Feb 27, 2008 | Mr. Heater MH75KT
Heating & Cooling Logo
783 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
