Question about Technics SL-MC700 110-Disc CD Changer
Front door won't open
The door knob on front door turns but won't open
  • 983 Answers
Open the player wit the door ejected then clean all dust particles inside it especially below the door and on the way where the door closes ... and then also clean the rubber belt & near by which is connected to dc motor... and clean the lens also... remember clean only wit dry clothes...
if the door doesnt open means just hit on upside surface lightly after pressing eject button only...
Posted on Feb 06, 2008
6ya staff
SOURCE:
Electrolux EIFLW55HMB Front-Load Washer With IQ-Touch controls won't open
Try unpluging for a few minutes . wake the washer up by turning knob then at the same time press and hold start cancel error will display . take off top and you will find a tech sheet on left side and that should help. you can manually unlock the door after taking top off and reach down to door lock you will feel a plastic switch to pull
Feb 17, 2013 | Electrolux EIFLW55HMB Front-Load Washer...
Lights blink on settings around the knob won't run from there
Your door switch is not working, the machine thinks that the door is still open.
Mar 11, 2012 | Kenmore HE2 Plus Front Load Washer
Front door wont open when turn the knob
Hi! you need a carpenter to do the job for you. Something was detached inside the door knob locking and releasing system..
Jun 12, 2011 | Hardware & Accessories
How do i reset the locked oven door to unlock it?
I have had that problem once.I turned off the breaker to that oven over night and then in the morning the door opened as it should.I found a GE page that is below.It may help.
http://www.geappliances.com/search/fast/infobase/10000161.htm
Some models with oven Set and Temperature knobs must have those knobs set in the Clean position before the latch can be moved to the left. If your door won't unlock, try turning those knobs back to Clean, then slide the latch over.
May 16, 2011 | GE JTP15 Electric Single Oven
How do i change my code on my safe? it is a S-25E i have keys but want 2 change the code
Try this,
NOTE: The safe needs to be upright and right side up or the locking mechanism
won't work.
ELECTRONIC SAFES
To open an electronic safe the first time, press the following numbers/letters on the
electronic keypad -159B. (These numbers are preset. You should change the code as soon
as possible after opening the safe to insure proper security). After you have entered the
factory set code, you will need to turn the knob on the faceplate to open the door. You will
have 5 seconds to turn the knob before the locking mechanism is reactivated.
ENTERING YOUR SECURITY CODE
To enter your own security code you will need to follow the steps listed below:
1. After opening the electronic safe (with the pre -set factory code of 159B) locate the
small red button on the inside of the door near the hinge.
2. Press the red button and then release it, you will hear a beep.
DO NOT SHUT THE DOOR UNTIL YOU HAVE CONFIRMED THAT YOUR NEW
SECURITY CODE HAS BEEN ENTERED CORRECTLY.
3. With the door open, enter your own personal security code, which can be 3- 8 digits
long, and confirm your new code by pressing the letter "B" on the electronic touch pad.
Before you close the door, try the new security code to make sure the lock release the
knob so you can turn it and retract the live action locking bolts.
Good luck
Thanks
Apr 29, 2011 | Office Equipment & Supplies
How do I change the OPC Drum cartridge? I cannot find any instructions to get to it.
Open the front door.
Remove the toner waste bottle.
Turn the belt tightening knob (top middle with arrow on it).
Pull out the OPC Drum.
Install new OPC Drum.
Turn the belt tightening knob back.
Re-install a waste toner bottle.
Close the front door.
Nov 04, 2010 | Konica Minolta magicolor 2300DL Laser...
I have a wall heater that I don't know how to turn
Open the little door panel with the knob and turn up the thermostat knob. Down on the front.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Oct 13, 2009 | Williams 2509612 Ceramic Mid-Size Heater
Over loaded the washer and now the door won't open
lynn903:
If you turn the knob to "Drain" the door should open.
Feb 03, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Door not unlocking
open the filter door at bottom turn screw with coin , door should open ,
Oct 02, 2006 | AEG Lavamat Lavalogic 1600 Front Load...
Technics SL-MC700 110-Disc CD Changer Logo
198 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
