Trutech TV I turn the TV on and half of the screen is blue for a long time sometimes it goes away and other times it doesn't. Help I cannot find my owner manual.
  • sangreal29 Jul 12, 2008
    want turn on at all now started with it taking a while for the picture to come on and then there was sound and no picture and now nothing.
I bought a Trutech 20 inch Flat Screen TV about a week ago. All of a sudden the picture has reduced to about 15 inches, on some channels. Also the picture breaks up a little every time I run a DVD.
Posted on Jun 16, 2008
How do I get Amazon Fire TV resolution set so I get more than a blue screen?
Select the input channel for your Fire TV - Turn on your TV and select the input channel for the HDMI port you used to connect your Fire TV. You should then see a loading screen with the Amazon Fire TV logo 4.
Jul 04, 2017 | TV Box Televison & Video
Bottom half of the screen is faded in color
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Oct 20, 2015 | Televison & Video
Hisense TV - right half is blue
change your tcon board and you will be fine
Oct 06, 2017 | Televison & Video
Half the screen doesn't work. It goes black sometimes, and sometimes that same half, the right side, has vertical color lines. The tv is only 6 months old. The problem actually went away for a while...
You need to go into the back of set and look for the wire connection to the board that is top center (looking from the back of the set). The wire plug will be about 1 and a half to 2 inches wide with several wires on it. Carefully unplug the wire going to that board and take a pencil eraser and clean the contacts gently and carefully. Plug it back up. The wire mentioned will come from the main board (with all the jacks and connections).
Jun 23, 2011 | Dynex DX-LCD37 TV
I have the TruTech DVD player and I went to use it the other day and when I turned it on the blue light will come on but it will not show up on the TV. When we try to turn it off and turn it back on it...
This DVD player have power supply board and the laser eye reader problems.DVD player very cheap these day.Can buy a new one about $40.So the old DVD player,junk it,not worth fixing.
Oct 21, 2010 | TruTech TT320
Generic problem for all Flat Panel Televisions Plasma TV turns on
if I were you I would move the TV to a place where it would get more air to the vents of the TV so the heat buildup would be less.
Jan 10, 2010 | Maxent MX-42V1 42 in. Plasma Television
Blue and red overlap shadowing
convergence ic's are your culprit. they are responsible for aligning the 3 colors your tv projects onto your screen..
Mar 15, 2009 | Mitsubishi WS-65807 65" Rear Projection...
Black Rectangles on 42" Vizio HDTV LCD
Your DirecTV signal is probably too low. That would produce the small black rectangles (pixilation). Also, try replacing the cable you are using to get the signal from the DirecTV receiver.
May 20, 2008 | Vizio L32 32 in. LCD HDTV
Screen turning blue now and then on various channels
Picture tube issue. How long have you had it? Call the manufactor.
Jan 03, 2008 | Toshiba MW30G71 30 in. TV/VCR/DVD Combo
Televison & Video Logo
305 people viewed this question
Top Televison & Video Experts
Electro Med Services...
