Question about Whirlpool LSB6200KQ Top Load Washer
Washing machine hi, I have a crosby washing machine that when it goes into a spinn the machine becomes unblances and will actually hit the sides of the machine I've pull the panels and check all the springs everthing is good and tight dont know what else it could be. Thanks Seaborne
  • sealverado Feb 03, 2008
    does the drum need to balence or something
  • sealverado Feb 07, 2008
    thanks
    Master:
    Sergeant:
  • 440 Answers
Cheak see if its balence and overloadingit
Posted on Feb 03, 2008
  • nick helpap
    nick helpap Feb 03, 2008
    whole unit take a level to test adjust bottem pegs up down ect
The washing machine has become very noisy in spinn mode
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Aug 22, 2011 | Washing Machines
After the final spinn cycle ther is still water in the washer
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Oct 04, 2010 | Maytag Neptune MAH5500B Front Load Washer
Spinn cycle made LOTS of noise won't spinn any longer
<span style="FONT-FAMILY: Arial; BACKGROUND: white; COLOR: black; FONT-SIZE: 10.5pt">Hi,<br />When my washer did that, I found that the shocks that hold the tub were bad...<br /><br />Check out this tip I wrote about the noise and vibration that front load washers can make..<br /><br />Washer Problems Washer noise when spinning<br /><a href="http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when" target="_blank">http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when</a><br /><br />heatman101 <br style="mso-special-character: line-break" /><br style="mso-special-character: line-break" /></span><span style="FONT-FAMILY: Arial; COLOR: black; FONT-SIZE: 10.5pt"></span><br />
Aug 25, 2010 | Frigidaire ATF6000ES Front Load Washer
The drum will not spinn?
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 20, 2010 | LG WM1814CW Front Load Washer
Washer jumps all around during final spinn
Hi
Does this happen every time???
If YES... then the machine is not balanced on the floor well.... the 4 stands on which the machine rests have adjustable screws... You will need to fasten or loosen the nuts that will adjust the height of the legs on which the machine rests.... all the 4 legs need to be firmly on the floor .... If one is too high then the machine rocks on its side...
If NO.. only sometimes...
You are overloading the machine with heavy clothes... distribute your wash clothes by weight...
Regards
Berry
Feb 04, 2010 | Speed Queen ATS90AWN Front Load Washer
Water still in machine
Depending on how high your drain hose is some of the water after the final spin can drain back into the outer tube of the machine. This wont hurt anything but when not using the maching, not a bad idea to leave the door ajared to prevent the washer from giving off a bad odour,
Dec 30, 2009 | Maytag Neptune MAH5500B Front Load Washer
Fisher&paykel 6.5 top load machine
hi
check that the machine is level , if they are not set up level it will cause balance problems
cheers grant
Oct 11, 2008 | Fisher and Paykel GWL11 Top Load Washer
Broken Machnine
hi. thanks for the question. the problem is .there is something caught in the water pump, and a burnt out belt ,replace both parts thanks the appliance doc
Oct 01, 2008 | Frigidaire GLTF2940ES Front Load Washer
Crosby washing machine has lint issue,,,my cloths gets linted,,,how to fix this,,,this machine is upward loader,,,has no window for lint remove
Hi khan,
Happy to be of assistance for you!
sounds like this time you need to,
call Service and have them come out.
If it's new your our under warranty for 1 year!
If it's 10 years or older then do not waste the money .
The newer ones are more efficient!
Good work done here.
A&E Factory Service
Nation Wide
7days/24 hours
They do Frigidaire warranty work.
Thank You for asking!
Please rate my, solution solved in this fixya site!
Neil
Aug 09, 2008 | Frigidaire GLTF2940ES Front Load Washer
Whirlpool LSB6200KQ Top Load Washer Logo
62 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
