I need help with the operating instructions for my lumix zx1 camera as I bought it here in France and cannot find the instructions in English on the cd. Please help I would love to use my Christmas present.
The instruction manual for this camera can be found here:
http://www2.panasonic.com/webapp/wcs/stores/servlet/PNAEndecaSearchCmd?N=779832097&Ne=&No=0&Nr=12001&Ns=&Ntk=SupportSearch&URL=vSupportSearch&cmTag=true&catalogId=11017&storeId=15001&cm_sp=SiteSearch-_-SupportSearch-_-SupportSecCat&Ntt=lumix+dmc-zr1
Click on which camera is yours, then select the "Operating Instructions" tab.
FYI - The ZX1 and ZR1 are essentially the same camera.
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
You need to take out all moisture
trapped in the camera. You could do this: Dry the camera, battery, any accessory, etc. with
cloth and wrap each piece, camera and accessories, in
newspaper. Place a few handfuls of rice into a plastic bag and then place
the wrapped camera in the bag with rice. The newspaper wrapping avoids
direct contact of rice
with your camera because the dust from the rice can get into the small areas of
the camera. The newspaper and rice will absorb moisture. Leave it there (with
the bag open) at least 24 hrs.
Normal
0
false
false
false
font-size:10.0pt;
Did you dry
the camera completely? If not here is the procedure to take out all moisture
trapped in the camera: Dry the camera, battery, any accessory, etc. with
the bag open) at least 24 hrs. Hope this helps!
It says DO NOT format on PC - you need to format in camera - have you done this? on Page 29 of the Manual http://panasonic.com.au/content/library/files/F002413.pdf
About cards that can be used in this unit
You can use an SD Memory Card and SDHC Memory Card.
•When the term card is used in these operating instructions this refers to the following types of
Memory Cards.
– SD Memory Card (8 MB to 2 GB)
– SDHC Memory Card (4 GB to 32 GB)
More specific information about memory cards that can be used with this unit.
• You can only use an SDHC Memory Card if using cards with 4 GB or
more capacity.
• A 4 GB (or more) Memory Card without an SDHC logo is not based on
the SD Standard and will not work in this product.
This is the instructions for the ZR1/ZX1 model
http://panasonic.jp/support/global/cs/mpi/dsc/zx1/menu01.html
A number of manuals available from this site
http://www2.panasonic.com/consumer-electronics/support/Cameras-Camcorders/Digital-Cameras/Lumix-Digital-Cameras/model.DMC-ZR1K
If this solutions solves you problem, please do not forget to rate my solution.
If not, then please comment back so I can help some more
