PIXMA MP830 I can't believe how often I have to replace an ink cartridge...The printer is freestanding...not tied to a computer.....I only print black and white and very few pages at that; however, I have to replace some cartridge about every week or so....Is there a setting that would reduce this excessive use of cartridges especially since I only print black and white?? or do I need to trade the unit in for some other model...I've had the printer for 1+ years and find the replacement of cartridges seemingly unnecessary and very expensive...SS# AAET46090....thanks...Basil Howard
    Sniper:
  • 71 Answers
Some machines are very expensive to run.
If you are copying in colour mode, even if the page you are copying is just black & white, it will use all four colours to produce the black copy.
Change the mode to black and white and it should save you some money!
Posted on Feb 04, 2008
The printer will print ok in color, but will not print black ink. No copy or printing.
My best guess without knowing more is that your printer has both a color print cartridge and a black ink print cartirdge. Replace the black ink cartridge and you should be fine. You might also find that replacing the entire printer is less expensive....All the best!
Nov 06, 2009 | Canon PIXMA MP830 All-In-One InkJet...
My canonmp830 printer is not printing in black ink
**Repeat from previous post. Would not print black. I went through all the troubleshooting of cleaning the printhead several times. The Nozzle check (found under Printing Preferences/Maintenance tab) kept coming out without the PGBK section (Black) printed on it. All the colors printed. If your see any of the colors missing, it is probably the same problem---it needs the Print Head replaced.
Part # QY6-0061-010. I was able to find it at Canyon Computer Supplies in Phoenix, but you can also order them via the internet from multiple outlets. Mine cost $59.57 with tax...much cheaper than a new printer. The replacement is very easy...Canon has info on how to do it at http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=123&modelid=12804#SupportDetailAct ...if the link doesn't get you right there, search MP830, Support & Service, then search print head & you should find it. Once you remove all the print cartriges (printer ON), the gray lever on the left side lifts up and releases the print head...which is the unit that houses all the print cartridges. I just put the new print head in, replaced all the ink cartridges, did a nozzle check...and it worked!! I love fixing things myself.
Jun 02, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Need to replace ink cartridge
http://reviews.cnet.com/multifunction-devices/pixma-mp830-office-all/4505-3181_7-31785803.html
Replacing the five ink tanks (cyan, yellow, magenta, black dye, and black pigment) is a simple task. The top of the printer flips up to reveal the ink tanks and the printheads, and by flipping a lever, you can pull out each tank individually. Being able to replace individual tanks is a boon, as you won't waste colors you use less frequently. Also, you won't need separate photo ink to print photos, which we appreciate. Canon ships the Pixma MP830 with full ink tanks. Replacement color and dye-based black ink tanks cost $14.25 apiece, while the pigment-based black ink tank costs $16.25. Canon estimates the cost per page for both black text and color text to be an inexpensive 2 cents.
May 31, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Canon MP830 printing with interlacing shades of black
your printer cartridge or head unit ink channel (some of color or black ink channel) constipated, you may try:
1) if your ink cartridge is not new, take out the cartridge put the bottom surface touch cleaner liquid(special for ink printer) or water for 1 hr (you can see ink spread water), then set back and test. refill enough ink maybe necessary.
2) still trouble, you need clean print head ink channel to do same thing above, if your print head is separated from the cartridge.
Feb 05, 2009 | Canon PIXMA MP830 All-In-One InkJet...
#5 black ink cartridge skips through the middle occasionally
Replacing the print head
The print head may need replacing if, after all print head and ink tank troubleshooting has been performed:
  • The nozzle test appears broken or to have horizontal white streaks.
  • One or more of the colors is missing from the Nozzle Test.
  • The colors are incorrect on the Nozzle Test.
  • A print head error is indicated on the unit.
  • The printer powers off when the print head is installed.
I hope it helps!!!
Nov 29, 2008 | Canon PIXMA MP830 All-In-One InkJet...
In Use/Memory FAX after changing ink cartridge
I had the same problem - it would not print the faxes as the machine would not recognize the generic cartridge - I had to get the official Canon cartridge to get the faxes to print out of memory.
Mar 18, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Refilling Ink in Canon Pixma MP830
Hello, I found this in a repair manual for the MP830. summery is to press and hold the stop/reset button for 5 or more seconds. I copied the info from the manual too. The remaining ink amount unknown. [1683] (Applicable ink tank icon) The remaining level of the following ink cannot be correctly detected. An ink tank which has once been empty is installed. Replace the applicable ink tank with a new one. Printing with a once-empty or refilled ink tank can damage the print head. If printing is continued without replacing the refilled ink tank, press the Stop/Reset button for 5 sec. or longer to record the use of a refilled ink tank. Note: After the above operation, the function to detect the remaining ink amount is disabled.
Jul 17, 2007 | Canon PIXMA MP780 All-In-One InkJet...
43 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
