Question about Lexmark All-In-One Printer
Paper Jam My Lexmark X5250 will not print. I put the paper in and it stops half way continuing to make and irritating noise. I have checked inside the printer numerous times but have not found anything thing stuck in side. I have tried everything from taking away paper to only putting in one. I do wonder if the roller ( I think thats what it's called) is not working properly. I also wonder if another wire is not plugged in properly. Please respond to this and tell me what you think.
  • 30 Answers
If it truly stops halfway then it must be obstructed by seomthing. If it only gets a short way past the pick up roller then it may be something else. A little trick for removing obstructions is to fold your paper in half or even a quarter so it is much thicker and stronger and try to feed that through. This can push through any obstructions (assuming they aren't too big). If it still gets stuck see if you can manually turn the main gear found to the side of the carriage and try to push the paper through that way (hence pushing through your obstruction). If your paper feeds through fine doing this then you may have another issue.
Good Luck.
Please rate my advice, good or bad.
Posted on Feb 04, 2008
4TH LIGHT FROM THE TOP KEEPS COMING ON LEXMARK E232
What this light sequence means that the printer has a paper jam.
When a paper jam occurs, the printer stops and the operator panel's Paper Jam light and Continue button lights come on. Press and release Continue twice quickly to display the specific secondary error paper jam light sequence.
How to clear Paper Jam
Press Continue button twice quickly to see the secondary error code.
To get the secondary error codes
When the Error light (!) and Continue button lights are both on, a secondary error has occurred.
When the Paper Jam light (4th light) and Continue button lights are both on, a paper jam secondary error has occurred.
Press and release Continue button twice quickly to display the secondary error code light sequence.
Press Continue button to resume printing once all the jammed pages are cleared from the paper path.
We recommend that you clear the entire paper path when a paper jam occurs.
To clear a paper jam:
1 If you are feeding paper from a tray, remove the tray, and then remove any jams.
2 Open the front cover and remove the print cartridge assembly.
NOTE: Do not leave the print cartridge assembly exposed to direct light for an Extended period of time. Extended light exposure can cause print quality problems.
3 Remove any jams in the area behind the print cartridge assembly.
4 Lift the flap at the front of the printer and remove any jams beneath the flap.
5 Open the rear exit and remove any jams.
6 After you have cleared the jams, reinstall the print cartridge assembly, make sure all printer covers and trays are closed, and then press Continue button to resume printing.
NOTE: The printer reprints the pages that caused the paper jam.
Jun 30, 2011 | Lexmark E232 Laser Printer
Hello my printer wont work, the powerbutton is blinking and i hear a tikking noise. is mij printer broken?? lexmark x5250
It could an alignment problem, a paper jam, or something blocking the paper path. Open the printer cover and remove both the cartridges. While the cover is open, check the cartridge area for any obstructions in the cartridge carrier's path. Check any transparent strip(encoder strip) that has become loose from its position. If there's nothing out of the ordinary, close the cover. Unplug and replug the printer into the power source to reset it. When the printer turns on, reinsert both cartridges and make sure they properly inserted and secured. Close the cover and try to print again.
May 29, 2011 | Lexmark X5250 All-In-One InkJet Printer
Paper feeds about half way and then stops. All of the indicator lights come on.
If you get a paper jam, the Paper Jam indicator light promptsyou to clear the paper path. If the paper has just started to feed from thepaper feeder when the jam occurs, pull the paper straight up out of the paper feeder. Open and close the printer cover toresume printing. If the paper jam occurs inside the printer, remove the paper from the output bin. Turn the printeroff, then on. If this doesn't clear the jam, open the printer cover.Remove the print cartridge and cover it.For additional assistance, please contactLexmark Technical Support
Apr 11, 2011 | Lexmark Optra E312L Laser Printer
It says paper jam but there's nothing there i have tried to check the insides but there is no paper jammed just won't work
Sometimes high cotton content paper will deposit paper "dust fibers" in the paper path and roller gears. Or there is a small torn piece of paper in the paper pathway somewhere. I have found bits of paper in the upper roller section on my Lexmark 5470 in the past. If that is not the problem unplug the power supply for a few minutes and then restart it. That should clear the error message.
Mar 06, 2011 | Lexmark X5250 All-In-One InkJet Printer
Lexmark x342n printer paper jam
Remove the jammed paper by gently pulling it straight out of the MFp
Please contact Lexmark Technical Support for additional assistance. NOTE: When calling for service you will need your printer model type and serial number. If you need help locating this information, click here.
May 31, 2009 | Lexmark X342n All-In-One Laser Printer
Won't print or copy due to ''paper jam''
the gears in the printer which pulls the paper r either blocked some where or r worn out.and needs replacement.
Nov 14, 2008 | Lexmark X5250 All-In-One InkJet Printer
Hp psc 1315 paper jam
. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
2.
Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
3.
Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
4.
Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
5.
Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
6.
Use the carriage access door to get at a jam further inside the printer. You may need to remove the print carriage to get to the jam.
7.
Replace all parts and return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Jun 18, 2008 | HP PSC 1315 All-In-One InkJet Printer
Printer jam
There is an easy fix for Lexmark E232 paper jams at the beginning of the paper path. This fix only works when the problem is that the paper starts to feed, but does not quite make it out of the paper tray.
The problem is the pickup paper rollers. If you remove the paper tray and press down on the paper indicator (the red lever to the left of the paper tray) you can see the twin rollers attached to a spring loaded armature.
Chances are these rollers are worn and are very smooth to the touch. This slick smooth surface does not have enough friction to push the paper up to the next roller.
To fix this, remove both rollers, they slide off easily. Then simply turn both rollers inside out and replace them on the armature. Notice how much "stickier" they feel now? Chances are your paper jam problems are over, until the rollers wear out again.
At that point you will have to replace them.
Mar 30, 2007 | Lexmark E232 Laser Printer
Lexmark All-In-One Printer Logo
82 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
