Question about Technics SL-1210 Turntable
Technis 1210 technics 1210 do spin very well n e more they were mint when i first got them easy 2 keep in beat now he do what they want if u speed the pitch up it takes a few seconds before anything happsens and they are just performing like belt drive decks at the moment really pore and mega hard to keep in beat any help appreciated dan
  • 515 Answers
The pitch controls are probably dirty and need to be calibrated. Any authorized Technics service center should be able to do this fairly easily. You can clean them out yourself by using DEOX-IT or similar, but would need a frequency counter to calibrate them.
- DJPROLAB
Posted on Feb 24, 2008
My 1210 mk2 spins at crazy speed when turned on and both 33/45 buttons light up but dont do anything when pushed.
I have seen this problem many times.
Option 1:
If you are comfortable with soldering, try replacing the drive IC. This solves the problem 90% of the time. The part number is: AN6675 . This is a discontinued part so you may have to search around a bit, but you can usually find one of them on eBay for between $25 - $40. There are a few newer versions of the chip that are suggested as replacements, but most of them have been on back order for years and you could end up waiting forever. I'd stick with the OEM part number on eBay. Just be sure it is in stock before you buy.
Option 2:
If you are not comfortable with delicate soldering or want a fix that is easy and 100% sure to work, I suggest replacing the whole motor board. This may sound extreme but it's really not. These are discontinued as well, but are usually easy to find on eBay. I've purchased many of these for less than $115. That may seem expensive at first, but it is still way cheaper than the $300 - $400 price a repair shop will charge. Be sure to purchase from a reputable seller with good history and, be sure that it is in good working order. Some are not, so carefully check the description. Some may look a little different than yours due to minor changes over the years, but as long as it is listed as compatible with the MK2 series, it will work fine. This is the most fool proof option if you don't mind the price. Like I said before, it is super easy and always works.
If anyone else is having trouble with a Technics SL1200/1210 MK2, this link is a must have:
www.deckdoctor.com.au/TECHNIC%20SL1200%20PCB.pdf
http://www.deckdoctor.com.au/TECHNIC%20SL1200%20PCB.pdf
I used this page again and again to save time identifying problems. Extremely useful. Good luck. EW
I’m happy to help further over the phone at https://www.6ya.com/expert/erik_149c4c1c216e42f2
Apr 13, 2014 | Technics SL-1200MK2 Turntable
Technics deck has power but stopped rotating
If you're lucky, this can just be a dirty/corroded speed control. Try removing the platter and you should see 2 holes lower center of the indented section. In those holes should be the coarse speed controls. These really set the range of the fine speed controls we play with on the outside. Use a good commercial contact cleaner and spray these babys. Gently move them a bit counter clockwise and clockwise, spray again, then return to about where they started.
If that doesn't help, you either have a motor issue or the controller board has a problem - no easy fix there.
Oct 23, 2010 | Technics SL-1210 Turntable
Technics 1210 MK2 - unstable/uneven speed problem
Since this is a direct-drive turntable, it isn't a slipping or stretched belt. You will need a technician with a couple pieces of equipment and some experience/training to find the source of the problem. I suspect the part(s) will be the minor cost of the repair.
Sep 07, 2009 | Technics SL-1210 Turntable
Help for technics 1200 MK2 and 1210 Speed is too fast
On the 1200MK2 the pitch control slider is for just that purpose. Disregard the 0 setting and use the illuminated strobe marks on the platter to adjust to nominal speed. When they appear to be motionless you are there. The control on the 1210 may be a knob but the same principles apply.
http://en.wikipedia.org/wiki/Technics_SL-1200
Apr 04, 2009 | Technics SL-1210 Turntable
Turntables lags on pick up
I have the same exact problem with one of my 1210 MK2 turntables. It seems like the motor is too slow now. When I hit the start button or release the record, it takes much longer to speed up to the normal speed than my other same exact turntable. I don't think it has anything to do with the pitch slider. Please let me know if you find out what the problem is thanks!
Mar 18, 2009 | Panasonic Technics SL-1210MK2 Turntable
Pitch problems
You would need to calibrate them to each other. Not very difficult, but not that easy either.
I would suggest taking it to a service center, and ask them to calibrate the turntables to each other. It's a matter of adjusting VR302, which is located underneath the turntable platter. You'll also need a frequency counter or similar - which aren't cheap.
- OPTiC
Technics Repair Videos
Technics DJ Repair
Technics Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
Mar 15, 2009 | Technics SL-1210M5G Turntable
Won't stop
This is a common issue with the drive in these units. Unfortunately, there is no easy fix. You will need to take it to a qualified service center for repair.
- Davis
DIGITAL ANALOG THERAPY
www.REPAIRNYC.com
Jul 10, 2008 | Technics SL-1210 Turntable
1210 mk 2 pitch
Doubt it, ive heard of this problem before, usually people buying them second hand and the answer has always been get them repaired professionally, i dont know the reason for them doing it sorry.
Jun 10, 2008 | Technics SL-1210 Turntable
Technics SL-1210 Turntable Logo
129 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
