Question about GoVideo Go Video DVD/VCR Combo
DVD Door Will Not Open
Cannot get the DVD door to open whether hitting the button at the machine or using the remote. I tried holding the power and eject buttons at the same time but did not work.
  • curious57 Feb 07, 2008
    DVR4000 dvd door will not open, eject button does not cause any action, pushing on the door does not cause any action.
    I see others suggest opening to clean/clear belts. How do you get to the belts?
  • JAKE-K Mar 21, 2008
    CANNOT GET THE DOOR TO OPEN CONSISTENTLY. ONRARE OCCASIONS IT WILL WORK. MOST TIMES IT WON'T. ALSO ATIMES WHEN IT DOES OPEN IT WILL AUTOMATICALLY CLOSE BEFORE YOU HAVE TIME TO PUT IN A DISC. IT MAKES NO DIFFERENCE IF YOU USE THE REMOTE OR THE BUTTON ON THE MACHINE
  • 983 Answers
May be the dvd is broken inside it ... just open it and remove the rubber belts connecting to the dc motor and then u can remove the door clean the obstacles near the door way and inside player if the dvd is broken means clean it clearly.....
Posted on Feb 06, 2008
  • 98 Answers
Unscrew the unit repalce the belt . sometimes belt wear out..
My door want open from the inside or outside
This sounds like theres a problem with the latch or the linkage. the first thing would be to get the door open but lets hold off on that for now.
Use the key and t ry to lock and unlock the door and see if you can, then try to lock and unlock the door using the button, let me know if it can lock and unlock. this test is to see if maybe the lock actuator is frozen. a frozen actuator will not allow you to unlock the door from inside or with a key but if you can lock and unlock then there maybe another problem. take note as you move the lock button make sure it moves up and down all the way or if it fells tight, if irs fine then the next step is to try and get the door open or remove the door panel to get inside the door. this may be hard but can be done.
try pushing on door and pulling on handle to try and open door. Another trick is to try and hold lock button in unlock postion and hold with a little force while pulling on handle to open the door.
Apr 12, 2012 | 2011 Nissan Titan Crew
Tip
If disk door wont open - stays locked
I called Samsung who suggested pushinhg the play button on the panel and the power button on the remote together. "No disc" eventually showed on the screen and pushing the open/close door button worked.
However, my remote wouldn't work, even after changing batteries.
The machine did play. Unfortunately, later that night I tried another DVD and it locked up again. The next day I tried the above 2-step and it worked again, so maybe the other DVD caused trouble. But I cant get my remote to do anything except the 2-step listed above.
I don't use the player very often.
on Aug 02, 2010 | Samsung DVD-P241 DVD Player
Power door is not delatching
there is a door lock actuator that has failed, it releases the latches so the door can open. you need to remove the door panel. unbolt the window and tape it as to hold the window up then remove the window regulator assembley then unbolt the lock actuator from the back side.
Apr 23, 2009 | 2004 Toyota Sienna
Door won't open
Those kind of problems just require that the door open one time. However, to do that you will have to take the cover off the player with the power off of course. Once you have take the cover off ( only a few screws ) you will be able to see the disk player well enough to see the back part of it. There are two ways you can do this, first, is to power the player back on, press the power button on. Then when you press the open door button or use your remote whichever, have your finger on the very back end of the carriage that holds the disk and push to the front gently as it tries to open the door, you will know because you will hear a short click from a relay. If you cannot open it after a couple of tries then power it off again and unplug it. There are only four screws that hold the disc player part in itself. Take those four screw off so you can lift it far enough to get to the bottom front of the disc player. Once you can do that, without the power on, there is a white neoprene part that moves from left to right or right to left to open and close the door. You will be able to see it and you can manually slide the part to whichever side it will move and that will open the door. You can gently push the door back closed and open it again a few times. Then place the disc player back in place with the screws in and power it up and open the door with the remote or button. It should open. What happens is that depending on how long the player has set on a wharehouse shelf or just around even if it is new, the lithium grease that they use for the moving parts dries out and it needs a little push and use to work properly again. Let me know if I can help in any other way.
Feb 09, 2009 | Sharp BDHP20U Blu-Ray Player
How to reprogram Sears Mult-Function Keyless Entry garage opener
On the garage opener that actually opens the door the one on the ceilling has a green or orange button that is called the learn button just press and release it you have 30 seconds to punch in a 4 digit code and when your done press and hold the enter button until the lights on the garage open blink once or twice then just press the code again and it will open the door press enter once to reverse the effect and and twice to stop the door completely.
Hope that helps
Jan 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
The DVD drawer will not open
I have the same problem. Best way to open the door is to hit the eject button and then bang lightly on the door using the remote controller. Works every time.
Mar 31, 2008 | GoVideo Go Video DVD/VCR Combo
Dvd player won't open
I had the same problem for my panasonic dvd player (ht540). Neither of the above solutions worked so I found this one on the panasonic website:
1. turn off unit by holding down the POWER button for 10 seconds.
2. unplug the power cord and wait for one minute.
3. plug the cord back in and turn on the unit
4. when the dvd begins to play, press "EJECT".
It worked for me. The site for other troubleshooting is:
http://www2.panasonic.com/consumer-electronics/support/FAQs/details-FAQs+for+DVD+Recorders-UCM_PRD_CNT_001989#dvdrec6
Peter
Oct 09, 2007 | Philips HTS3410D/37 700W DVD Home Theater...
Dvd recorder doesn't eject disc
Yes, I'm having the exact same problem -- I can't eject the dvd that's in the player right now either manually or remotely. It plays fine.
Sep 23, 2007 | Televison & Video
Insignia DVD Player
Try hitting the "Lock" button on the remote. That solved the problem for us.
Dec 03, 2006 | Insignia IS-DVD1001 DVD Recorder/VCR
GoVideo Go Video DVD/VCR Combo Logo
431 people viewed this question
Top GoVideo Televison & Video Experts
Demonic-2011
Demonic-2011
Computer Repairing
Computer Repairing
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
