Question about Whirlpool GU2400XTP Built-in Dishwasher
I have sand in tall glasses when washed on the top shelf
My whirlpool gold quiet partner III came with the house I bought. Recently, tall classes or car/coffee mugs washed on the top shelf have "sandy" residue left over after a wash. I want to add a rinse aid (jet dry), but I'm not sure where to add it and I don't understand the 1-6 on the rinse dial. It would probably be helpful If I had my owner's manual, but that was not passed onto me from the prior owners. So, where do i put the rinse aid and do you think it will solve my "sand" problem? The sand is almost baked on when i take the glasses out so i have to soak and scrub them!
  • Anonymous Mar 08, 2008
    I have the same problem. We thoroughly cleaned the dishwasher with vinegar, we are using environmentally safe detergent, but the problem is getting worse. I found a small plastic disc in the bottom of the dishwasher, and assume that's the problem. I don't know where it goes or how to reinstall it if it is causing the problem.
  • Jill roberts Feb 16, 2013
    I have used dishwasher magic twice and it has had ZERO effect. Still have sandy grit in the machine
  • 3 Answers
We had the same problem until we started using the little cakes of detergent with the Jet Dry Power Ball in the middle. Now it washes great. This after going through so much vinger and CLR to clean the coils!
Posted on Apr 14, 2008
    Novelist:
  • 130 Answers
Jalexandruna the lid you opened on the dispenser that has 1-6 is where you pour in the rinse aid. As to if it will help or not, this sand issue may be hard water. Try using a eviromentally friendly detergent which is high in Citric Acid. Or try running a dishwasher cleaner like Dishwasher Magic thru the dishwasher to clean this residue out. Hope this helps
Posted on Feb 03, 2008
Quiet partner whirlpool III gold reset
TRY A RESET CODE
Press the "Sani Rinse," "Heated Dry," "Sani Rinse" and "Heated Dry" buttons on the dishwasher's electronic control panel in quick succession to put the appliance in diagnostic mode.
Close the dishwasher door and engage the door latch.
Wait 10 seconds before pressing the "Cancel" button to reset the dishwasher.
Dec 18, 2013 | Whirlpool Gold Dishwasher with Quiet...
My Whirlpool Quiet Partner II does not clean the upper rack of dishes properly. They are greasy. I have checked the top spray arm for blockages. There were none. I am fairly certain that water is
Make sure the center loading is not obstructing the water jet to the top shelf. Top shelf is only for glasses and saucers , use Jet-Dry .Pre rinse and clean bottom pan strainer from dirt debris.
May 14, 2012 | Whirlpool GU2400XTP Built-in Dishwasher
My whirlpool Gold Quiet partner III won't wash. Dishes come out greasy.
Add Jet Dry and run a cycle with dishwasher empty with bleach and should start working good
Nov 19, 2010 | Whirlpool Dishwashers
My 6 year old Whirlpool dishwasher is loud
This is a bad wash pump. Looking at about $175 for just the sump assembly. You could do it yourself, but unit would need to be uninstalled.
May 28, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Our quiet partner iii dishwasher is not working. It is not gettting dishes cleaned soap left on dishes
Our whirlpool gold quiet partner iii dishwasher is not working well . It is not gettting dishes cleaned soap left on dishes on top primarily
May 16, 2010 | Dishwashers
Whirlpool gold quiet partner iii bearing noise
if its noisy when washing check chopper assembly. if its ok change the sump pump assembly
Feb 09, 2010 | Whirlpool Dishwashers
Dishwasher is not getting dishes clean. Water is
follow this link:
http://www.fixya.com/support/t2390397-dishwasher_acts_up
that guy gave me some good advice!
Jun 09, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
The only number on the nameplate of my Costco-purchased "Quiet Partner IV" built-in Whirlpool dishwasher (steel insides) is 8575637. This dishwasher does not clean spoons right-they always have dirt left...
Yes, you almost certainly have a Whirlpool Gold Quiet Partner III Model #8575637
Of course the great news with buying from Costco is the ability to return products you are dissatisfied with. Check with the customer service desk.
Please reply if you want to to get into repairing it and we will get under way.
Mar 31, 2009 | Whirlpool Gold 24" Tall Tub Built-In...
RUN TIME ON NORMAL WASH IS ABOUT 3 HOURS
common failures on that usually are the heating element. Look at the botton and see if it is broken anywhere.
Mar 22, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Not cleaning properly
Our Whirlpool Quiet Wash plus is 20+ years old and was on its way out the door because of erratic white residue, spotting, and film.  Nothing worked: vinegar, different soaps, more soap, less soap. Today I opened it up and started digging behind covers and checking the insides - multiple places were clogged with a soap/mineral film - ugly! I sprayed the insides with Restore 4 (a tile cleaner) and scraped and brushed and broke loose the hidden deposits. The only thing I didn't open was the sump pump - but now know how to do so. (thanks FixYa) Then I added about a 1/2 quart of vinegar and ran it full hot on the heavy wash cycle, added more vinegar between each cycle and let it dry.  It looks super inside - the gunk is gone.  I am now washing a load of glasses and am hoping for the best!
Feb 26, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool GU2400XTP Built-in Dishwasher Logo
1,086 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
