Question about Smeg WD16BA Front Load Washer / Dryer
Machine stopped for no reason
I have power, the filters and pump are clear! After selecting a program it starts ( dial moves ) but never actually get going.
It's five years old shall i buy a new one or is there a relatively cheap fix?
  • seanx12345 Feb 04, 2008
    Thanks for the response. I will give it a go.
  • leekellett Oct 29, 2008
    Same as above, have checked the hose is clear, but still no joy, would really appreciate some help, also I can hear a slight buzzing sound from a white box at the bottom left at the back of the machine, is that motor contoller unit, could it be this, as normally the drum blips and then it starts drawing water but nothing at all.
    Thanks in advance.
    Lee
    President:
  • 1,294 Answers
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped. Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
Posted on Feb 04, 2008
6ya staff
SOURCE:
Indesit WM12X the wash program starts then freezes (The dial doesn't turn)
Sounds like the dial timer is defective, I am not affiliated with this site, https://www.repairclinic.com/Video
Apr 25, 2017 | LG WM Washing Machines
Ariston AWD 121 will not complete cycle
It sounds like the dial is broken. You can call your local appliance store and order the part for cheap. Installation is easy enough to do yourself if you would like. Just make sure the power is disconnected.
Jun 30, 2014 | Washing Machines
I can't descale my C5
You may need to go into program mode and "tell it" you replaced the filter. We normally do this when we replace water filters in Jura's. On the f60 you get into program and scroll using the water volume dial and push it in to set the changed value.
Hope this helps
Jan 25, 2013 | Jura Impressa C5 Automatic Coffee Center...
Ignis adl349/a seems to fill and drain ok but stops after 2/3 mins and beeps 4 times
What this actually signifies is that there is a problem with the spray arms; they are blocked, needs cleaning.
Then, check on the filters as well, its an uncommon problem, but once cleaned, run the machine on a hottest wash, hope it clears the problem.
Check inside for the hose (see if in place or off the top spray bar)to check whether water is going into the spray bars and spray arms work well. ----------
The 5 flashes indicate a spray. Pump fault, either blocked or motor fault.
Press and hold the start button until the light goes out.
Select a program and try the machine again.--------
This should help.keep updated.Thanks.Helpmech,.
Feb 16, 2011 | GE Built-In Dishwashera Oven
Dial continuously turning
hiya
to reset the dial, switch the power off, then turn the dial to a dot on the selection then switch the power on, the light should flash about 3-4 times this should be it reset.
for the machine to start doing this mid cyle though usually indicates something is wrong, i would hazard a guess at the pump filter is blocked and the mahine was trying to drain at the time it started clicking.
the best thing to do is empty the machine manually by placing the outlet hose into a bucket or large dish, once empty remove the plastic kick plate on the bottom of the machine and behind this you will find the filter.
before you unscrew the filter you will need to place some towels or old cloths on the floor as there will still be water left in the pipes, remove filter and any foreign objects (possibly coins, hair clips etc) and then screw back in. job done.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
Aug 02, 2008 | Ariston Technologies Ariston AWD12 Front...
Hotpoint Aquarius wd440 washer/dryer wont pump out water HELP!
hold the start button for 5 seconds this should clear previous program. then select drain on your dial. press start as normal and machine will drain. if this does not work the only other remedy is with help, making sure the end of the drain hose is higher than drum at all times take machine outside, lean it back at 45 degrees agaist a wall with a towel or similar covering lid to stop scratching . working from underneath loosen the large jubillee clip that connects the drum to pump drain hose to the drum. As the drum is overfull there is no recepticle large enough to fit under so just let water just flow away. Dry every thing off. make sure you don't loose ping pong ball in filter and make sure filter is clear. refitting is reverse of removal
Mar 28, 2008 | Hotpoint Aquarius WD640 Front Load...
Program problems
please check you drain filter, situated @ bottm of appliance. if ok i think you may have a pcb fault and you need an engineer
Jul 14, 2007 | Indesit W 123 Front Load Washer
Timer clicks arround and arround
My Belling integrated washing machine will not stop at the end of the cycle. My partner had accidently moved the dial during mid-cycle. We have tried to reset the machine by turning it off and then moving the dial around to the stop section of the dial. However when we turn it back on it waits for a while and then continues to click around with starting any cycle. Can anyone help? Thanks.
Jul 02, 2007 | Belling SGE12X Front Load Washer / Dryer
Smeg WD16BA Front Load Washer / Dryer Logo
139 people viewed this question
Top Smeg Washing Machines Experts
matt
matt
ray gallant
ray gallant
Tom Chichester
Are you a Smeg Washing Machine Expert? Answer questions, earn points and help others
