Question about GE A830 Digital Camera
Picture on viewfinder
Picture taken appears on camera like a venetian blind, but downloads to computer fine. what's going on?
  • 3 more comments
  • jbarnesinfin May 03, 2008
    I'm having a similar problem. At my son's first bday party it started doing this and then just as quickly went back to normal. A few days later it started doing it again. The main difference between the problem mentioned and my problem is that even when I download them it doesn't show as normal, still w. the same venetian blinds look.
  • smiley2day May 22, 2008
    Same thing. The viewer is fine to take the picture. The venetian blind look is on the taken-photo.
    I thought it might be due to humidity (I took it into the Rain Forest at our zoo). I put it and the memory card in a baggie of rice. No luck.
  • shmexxii Jun 10, 2008
    Ok i have had my camera for about 6 months now and recently i started taking pictures with the lines across and i was still able to put them on the computer without the lines but after a while it did it on the computer too and i have tried to fix it but nothing works and its not like i dropped my cam or got it wet or anything like that i took good care of it and all
  • Anonymous Aug 21, 2008
    Seems like mine does it when its near light but in the dark it takes fine No idea whats going on!
  • plucher Oct 14, 2008
    I have the same problem. Perhaps these cameras are prone to this malfunction and should be recalled??
I have no solution just a problem of my own i need soft ware to use my ge a830 to my pc thank you richard.
Posted on May 27, 2008
Got a problem with Nikon coolpix s255 works fine on video but every picture has white lines as soon as taken or on viewing image . Looks like picture is behind a white Venetian blind
Those white lines should not be there and it indicates that something is wrong with the electronics of the camera when shooting video.
Take out the memory chip and play it back video on a computer. If it plays back fine on computer then the playback camera circuits are fubar. If also bad on computer then the anomaly is in the record section of camera.
Repairing those cameras since they are small and the parts are proprietary is an expensive proposition that you would only entertain if the camera was initially a very expensive one. Repairs on less expensive units are simply not cost effective.
Sep 15, 2016 | Nikon Cameras
When camera is turned on no picture appears in the viewfinder or on the LCD screen, it remains black. The batteries are new. I can access the menu, change settings. Everything works but there is no image...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Sep 04, 2010 | Canon PowerShot S2 IS Digital Camera
My camera is a F460.Some photos looked like you took the photo through venetian blinds. Some photos came out great than the shadings.
it is due to the change in the light patterns
if you take a pic of TV or PC monitor the image look like venetian blinds
this is the reason
Aug 29, 2010 | Fuji FinePix F460 Digital Camera
Thick dark vertical lines appear on the video taken during playback.
It is problem of dirty / clogged video heads, use good quality video head cleaner in your camera and clean video head. Problem will be resolved.
Nov 10, 2008 | JVC GR-D250 Mini DV Digital Camcorder
Pictures look like view through a venetian blind
i think the grid lines have been enabled.
and so disable it to having the problem solved
Apr 29, 2008 | Olympus SP-350 Digital Camera
Picture problem
If you're having like a bright picture with venetian blinds, you could try the steps below:
POWER RESET:
- Turn off camera
- Remove batteries for a minute
- Return batteries
- Turn on camera
MASTER RESET
- Turn on camera
- Press MENU button
- Scroll to the right until you see SETUP
- Scroll down and look for RESET
- Press right button so you could see YES or NO
- Select YES
- Press MENU button
- Turn off camera for a few seconds so that
settings will be refreshed
* If it still does not work, call the Manufacturer so they
could tell you how to send camera for repair.
Dec 13, 2007 | Samsung Digimax S500 Digital Camera
Help... white lines
I also have the same problem! I absolutely love this camera but suddenly out of the blue I have stripy lines on the screen that look like you are looking through a venetian blind. I have contacted Fuji but they say it will cost £99 to repair or have offered £50 discount on any other camera. I just want my F460 working ok. Please, please can anyone help us?
Nov 12, 2007 | Fuji FinePix F460 Digital Camera
Only see bright light effect in viewfinder and LCD
the Screen has failed or a connector to the main board has come lose. Check out the Makers help line for advice. The likely cost of a repair is going to be high be prepared for a new camera.
Oct 29, 2006 | Konica Minolta DiMAGE Z2 Digital Camera
Pictures look further away than they seemed through the viewfinder
Like all point and shoot cameras, PhotoPC's viewfinder is not 100 percent accurate and will slightly magnify the subject. The actual picture will always appear to have been taken further away than what the user views through the viewfinder.
Sep 12, 2005 | Epson PhotoPC 500 Digital Camera
GE A830 Digital Camera Logo
90 people viewed this question
Top GE Cameras Experts
Steven Wander
Steven Wander
jjanesic
jjanesic
Level 1 Expert
Are you a GE Camera Expert? Answer questions, earn points and help others
