Question about Aiwa CA-DW535 Boombox
Aiwa CA-DW535 CD-ROM drive spins, but cannot find track. I cleaned the optical lens once and the drive worked for one CD, now it doesnot work again!
  • Al_Eagle Feb 03, 2008
    Is optical lazor a replaceable part?
    Master:
    Sergeant:
  • 440 Answers
Optical lazor fulty and the controler thattriggers it and cheak cable connecting it if u can get in it otherwise cd rom bad ther go bad after 2 3 yrs on these ones
Posted on Feb 03, 2008
  • nick helpap
    nick helpap Feb 03, 2008
    aww that might be but know how hard it is to getthat will be tuff
Aiwa cxzr525 cd player. After loading under the eye cd does not spin or play. It just clicks. I tried a cd cleaner disk and that did not work. Is it the same as a lens cleaner? What else can I try? Thank...
The clicking you are hearing is an attempt to focus on the disc. The usual cleaning discs don't work well. Try to gain access to the lens and clean itusing a cotton swab and alcohol. That will remove any film that remains on the lens. If that fails to resolve the problem, the optics will need to be replaced.
Dan
Oct 21, 2009 | Aiwa Audio Players & Recorders
Player will not work. keep getting the disc will not work message, for all discs.
HI.This will occur when the optical assembly becomes unstable. this ((Whole One Piece)), assembly incorporates the spin/load motor, optics housing /arm, tracking device and tracking rail. This is connected to the loading dock assembly. This 'NO Disc' or CD NOT PLAYABLE, code is the result of a failed or burned out lens. It is possible that you have a dirty lens cap. you can try using a cleaning disk in this case to confirm actual lens failure. if the cleaning doesn't restore normal reading capabilities, this will confirm my diagnosis.
You will need to have the optical assembly replaced in this case. once replaced, your unit will be able to read and track once more.
Oct 06, 2009 | Samsung BD-UP5000 Blu-ray and HD-DVD...
Getting 'no disc'
HI.This will occur when the optical assembly becomes unstable. this ((Whole One Piece)), assembly incorporates the spin/load motor, optics housing /arm, tracking device and tracking rail. This is connected to the loading dock assembly. This 'NO Disc', code is the result of a failed or burned out lens. It is possible that you have a dirty lens cap. you can try using a cleaning disk in this case to confirm actual lens failure. if the cleaning doesn't restore normal reading capabilities, this will confirm my diagnosis.
Jul 25, 2009 | Pioneer PD-F1007 301-Disc CD Changer
CD wont play in my Bose Wave
Jul 23, 2009 | Bose & Wave& Music System
CD player not tracking right
These are the early signs or optical lens assembly failuer. i would start preparing to replace this assembly. the tracking motor and rail are damaged.
May 28, 2009 | Audio Players & Recorders
My dvd-rom model gdr-8163b won't play or read . it spin once and stop
When you get no disk error, that is usually because of a problem with the optical laser lens that is dirty, faulty or opaque, and will start operating on certain disks better than others.
In that case you will hear disk spinning, whirring and clicking, but the TOC (table of content track at start of CD/DVD will not be read, therefore the error.
Whe this problem is starting you may be able to read only CD, DVD or Blue ray, or for example only DVD-R and not +R , or only to read and not to write and so on. After more prolonged usage , often the unit goes losing the rest of functions, and ends up not reading anything at all.
If instead there is no noise, and disk does not spin at all , then there is a faulty motor, or the motor micro-switch is bad. This situation is far less common than the lens problem.
Try first using a CD/DVD or Blue ray lens cleaner disk to clean the lens. If that does not work you will need to disassemble the drive , and clean lens directly with q tips and isopropyl alcohol, or to replace the CD/DVD lens, or the whole drive unit.
Apr 26, 2009 | Computers & Internet
Latitude C840 wont reconize optical drive in BIOS
Try first using a CD/DVD or Blue ray lens cleaner disk to clean the lens. If that does not work you will need to disassemble the drive , and clean lens directly with q tips and isopropyl alcohol, or to replace the the whole drive unit.
Apr 25, 2009 | Dell Latitude C840 24X CD-R W/ DVD Combo...
My cd rom not reading any cds
In that case you will hear disk spinning, whirring and clicking, but the TOC (table of content track at start of CD will not be read, therefore the error.
When this problem is beginning you may be able to read only CD, DVD or Blue ray, or for example only DVD-R and not +R , or only to read and not to write and so on. After more prolonged usage , often the unit goes losing the rest of functions, and ends up not reading anything at all.
Try first using a CD lens cleaner disk to clean the lens. If that does not work you will need to disassemble the drive , and clean lens directly with cotton tips and isopropyl alcohol, or to replace the CD drive unit.
Apr 13, 2009 | LG CRN 8245B (CRN-8245B) Internal 24x...
Sayes disk err can read disk
CLICK HERE TO ORDER YOUR NEW REPLACEMENT DRIVE(ROM)
Mar 21, 2009 | Capcom Resident Evil: Code Veronica X
CD ROM not working
When the CD does not read any disk, that is usually because of a problem with the optical laser lens that is dirty, faulty or opaque, and will start operating on certain disks better than others.
Mar 05, 2009 | Candy CDC266 Dryer
Aiwa CA-DW535 Boombox Logo
145 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
