Question about Amana ALG443RAW Gas Dryer
Dryer problems My dryer is not working. I thought is was the belt, changed it and it still doesn't work. Is makes a buzzing sound when you try to start it but nother happens; no drum movement, no heat. Now, the sound is gone and...nothing.
    Master:
    Sergeant:
  • 440 Answers
Power transformer on it went or main bord controler i would call guy in pin point it instead of us having u chnage this and that
Posted on Feb 03, 2008
Hi, I have an AEG T35850 tumble dryer. The motor makes a buzzing sound as it slowly gets going when empty. If it has a really hard time getting started, most of the time failing to get going.
The most likely cause is a slipping drive belt from the motor to the drum. Check the tension on the belt, but if the belt is worn, replace it. If the belt has been slipping for a period of time , it will probably be worn out.
Motor making a buzzing sound, is the motor actually turning? If so it is probably the belt.
If motor not turning, try taking the drive belt off and if the motor now runs, you may have seized drum bearings = expensive, buy a new dryer !
May 03, 2016 | AEG t35850 7kg vented tumble electric...
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
www.applianceblog.com/.../7655-Dryer-won-t-start-Makes-electrical-buz...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' PartSelect.com ...
? 4:32
https://www.youtube.com/watch?v=Tk1YezyYMDY
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
DRYER BUZZING NOISE - Dryer For Sale
Dec 18, 2015 | Amana DLE330RAW Electric Dryer
My dryer has burnt smell just buzzes but doesn't
Check the motor, it's sticking or already burned out
Mar 26, 2013 | Dryers
When I try to turn on my dryer it just buzzes for about 5 seconds and doesn't do anything else. The heater doesn't turn on and the drum doesn't turn. Help!!!
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 09, 2011 | Electrolux EIED55H Dryer
Kenmore 65611 electric dryer makes buzzing sound when press start but doesn't start drying process
heatman101
Jun 17, 2011 | Kenmore Dryers
Only buzzes when trying to start my LDE7304ACE Maytag electric dryer. the drum spins freely.
Verify and indicate in which part where the buzz is coming from. It's the timer motor if it's coming from behind the timer knob; otherwise, it is the dryer motor at the base of the dryer.
The drum belt has slipped off if the dryer motor is the one that buzzes and the dryer blows out hot air. Otherwise, the dryer motor (part number Y303358) is stuck; replace it.
Check the continuity of thermal fuses, one on the blower housing and one on the heater enclosure, if the buzzing sound is coming from the timer motor. These thermal fuses are wired in series with the dryer motor and will make it inoperable should any of the thermal fuses fail. Replace also the cycling thermostat should the thermal fuse (part number 306604) on the blower housing has failed and the high-limit thermostat should the thermal fuse (part number 307473) on the heater enclosure has failed.
May 24, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Dryer has started to make a loud sqealing when it starts and gets up to speed, the kind of sound a loose fan belt makes on a car, and now just makes a buzzing sound when the button is pushed but dosen't...
If you push the start button and you here a buzzing sound, This sounds like the motor is bad.
Somthing you can try and this might not work. but open the dryer door and turn the drum a littel bit then close the door and try to start it. If it starts running again then you have hit a bad spot on the motor.
If it just still just makes the buzzing noise then the motor is most likley bad.
Jan 15, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Dryer makes buzzing noise but will not run.
that is the sign of a bad dryer motor-sorry-mike
May 08, 2009 | Dryers
Amana ALG443RAW Gas Dryer Logo
75 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you an Amana Dryer Expert? Answer questions, earn points and help others
