Question about IBM ThinkPad 380ED
IBM Thinkpad 380 ED 00161 and 00163 errors
I read the possible soluitons about holding down the F1 key the then restar and I even hold it down fro another minute after the error appears. Boot disk does not work...is there a solution. I tried both with the bdead battery in and out...any thoughts?
Walter
  • 3 more comments
  • Cali222 Feb 03, 2008
    Not sure what you mean Drummernick, I just want the laptop to boot to my desktop...can you help?
    I get the INB thinkpad background and it wants me tp correct the date and time which I have done several times. when I complete that step it reboots automatically with the same error codes 00161 and 00163. Holding down f! at the startup does nothhing to help the problem.
    Is this something I can do by opening the the bottom of the laptop ans scot around looking for a very small battery, if yes do you know where they sell the the bios batteries?
    Thanks, you're the best. I got the bios battery out, on the bottom of the IBM's there is a door with one screw that has access to the memory and bios battery, now I just need a CR1220 battery and I'm good to go. Thansk for all your help.
    Walter
  • simcat44 Jun 14, 2008
    Hi, my laptop also has the errors 00161 and 00163. A friend of mine said to look the numbers up and then throw my laptob off a tall building, it wasn't funny. What can I do to fix it, I've tried F1 but it didn't do anything.
    Can you help me?
    Jessie
The cmos batters ar soled at walmart in the watch dep
Posted on May 24, 2008
I tested this camera for a client. I didn’t have the light running for more than 15 minutes. The battery lasted approximately 6 hours before recharging. The
LCD, however, had a few dead pixels - never saw this before. Tried returning for exchange and had to put up quite a fight. Anyone else seen this?
http://www.batteryfast.co.uk
Posted on May 02, 2008
If you get the "163" error it's simple. Just take the bios battery out or replace it with a new one!
Posted on Feb 16, 2008
    Master:
    Sergeant:
  • 440 Answers
What do u wann do redo computer boot into xp cd ?
Posted on Feb 03, 2008
  • 2 more comments
  • nick helpap
    nick helpap Feb 03, 2008
    what it doing when u try to boot up normaly ?
  • nick helpap
    i got ya can u go in bios battery in in it not holding nomore so ota get in ther see if we can find replacment labtop battery small very
  • nick helpap
    u can usaly on top area fold screen all way back 2 screws behind it take out pop top panel off pry with small flat head up off hinges of screen ok then u can remove kebord under here u will see it
  • nick helpap
    mark this is as fix ya thx again nick
How to reset all settings to my lenovo a269i mobile thru pc
Is it a think pad ?
Power off your Thinkpad.
Press and hold the "F1" key and turn your Thinkpad on, still holding the "F1" key down.
Release the "F1" key when you hear repeating beeps. Wait for the "IBM BIOS Setup Utility" to load.
Select "Startup" using the arrow keys and press "Enter."
Select "Boot" or "Startup Sequence" and press "Enter."
Select "CD-ROM Drive."
Press the "F6" key repeatedly until "CD-ROM Drive" sits at the top of the list.
Insert your recovery CD into your Thinkpad's CD-ROM drive.
If you have multiple recovery CDs, insert the CD that has "Disc 1" on its label.
Press "F10" to save your changes and exit the BIOS Utility.
Select "Yes" and press "Enter" when the "Setup Confirmation" window appears.
Your laptop will restart. Wait for the Recovery Utility to load.
Select "Restore to Factory Specifications" to erase the contents of your hard drive and reinstall the Windows version and drivers that your Thinkpad originally came with.
Follow the Recovery Utility's onscreen instructions.
When prompted to insert another disc, do so according to the numerical labels on your recovery CDs (e.g., insert "Disc 2" after "Disc 1" and "Disc 3" after "Disc 2").
Your Thinkpad restarts when the restore process finishes. Power off your Thinkpad.
Hold down the "F1" key and power on your laptop to access the "IBM BIOS Setup Utility."
Press "F9."
Select "Setup Defaults" from the menu and press "Enter" so that your Thinkpad no longer boots from the CD-ROM drive.
Press "F10" and select "Yes" to confirm your changes.
Your Thinkpad will restart and load your newly installed operating system.
http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-61432
ThinkVantage Technologies downloads
Feb 20, 2014 | Computers & Internet
Do i hold down the f1 key and then start the pc
No, You need to Hold F1 only if your machine is not having ENough power to boot. Connect the Power cable and Press F1. It will be booted. Make sure before swicthing ON your notebook it should be sufficient charge.
Sep 23, 2010 | IBM ThinkPad 600X Notebook
Thinkpad 600E won't boot from disk
Set the boot order to boot from cd drive first, to enter the bios ...
With the unit powered off, hold the F1 key and power the unit on. Keep F1 held down until Easy setup appears.
Jul 17, 2010 | IBM ThinkPad 600E 2645 Notebook
Error 00161 00163
[CHANGE YOUR CMOS BATTER WHICH IS INSIDE YOUR CPU CASE]
I do not think you fixed the CMOS battery - (backup battery = CMOS battery)
According to the error codes, you have a dead backup battery and the time is not set. Makes sense?
161
(Dead battery.) 1. Go to Checking the Backup Battery
2. Backup battery.
3. System board.
163
(Time and date were not set.) 1. Set time and date.
2. System board.
Go to www.ibm.com Find and download the user manual, and the "hardware maintenance manual."
Do you know how to get into bios/setup?
Start with the machine OFF. HOLD DOWN and CONTINUE TO HOLD THE "F1" key.
WHILE STILL HOLDING "F1", turn the power on, and CONTINUE TO HOLD "F1"
This will get you into the bios "setup." You should check the date, bootup order, etc, and reset.
I would check the "wire" you think you reconnected---you may just not have actually reconnected it.
The "hardware maintenance manual" shows you how to maintain this machine, and it explains the meaning of the error codes.
This will get you started on looking for the manual:
http://www-307.ibm.com/pc/support/site.wss/multiplefiledownload.do?validate=true
May 16, 2010 | IBM ThinkPad 380ED
Error 00161 00163 unit comes on and shows this screen any imput would be great thanks
WHILE STILL HOLDING "F1", turn the power on, and CONTINUE TO HOLD "F1" This will get you into the bios "setup." You should check the date
Nov 21, 2009 | IBM ThinkPad 600E 2645 Notebook
Hello my ibm thinkpad 600E will not come up. it says error 00161 and 00163. what do i need to do?
Start with the machine OFF. HOLD DOWN and CONTINUE TO HOLD THE "F1" key. WHILE STILL HOLDING "F1", turn the power on, and CONTINUE TO HOLD "F1" This will get you into the bios "setup." You should check the date, bootup order, etc, and reset. I would check the "wire" you think you reconnected---you may just not have actually reconnected it.
According to the error codes, you have a dead backup battery and the time is not set. Error: 161
2. Backup battery.
3. System board.
Error: 163
2. System board.
Jul 14, 2009 | IBM Computers & Internet
How to enter into BIOS when trackpoint was broken.
Hi there.
Its something to do with the trackpoint, possibly the cable has become loose.
* If an emergency power down is made by switching the system off during or while an application is open, then immediately switching the system on creates a 8611 error.
* Repeatedly turning power off and back on without properly shutting down or allowing the system to shut itself down.
Solution
Wait at least 6 seconds or longer after shutting down the system or before restarting to correct the 8611 error.
See if that gets rid of the error, if not it could be a loose cable to the trackpoint.
Good luck
Jun 01, 2009 | IBM ThinkPad 600X Notebook
Entering BIOS settings, Easy-Access, after POP, with external KB
The Power On Password problem is near impossible to crack. It is designed to prevent unauthorized access to the Thinkpad and removing the BIOS battery will not remove the password because the password is stored on an EEPROM chip.
There are no backdoor passwords available, the only option is to ask the person who set the password.
OR
There is a way to hack into the Thinkpad to see and remove the password but it requires electronic skills, a program and a working computer.
For details on how to do this go to :-
http://sodoityourself.com/hacking-ibm-thinkpad-bios-password/
Feb 03, 2009 | IBM ThinkPad 600X Notebook
161 and 163
Are you trying to access the Bios set up? I own the IBM ThinkPad 380Z, 13" full Screen, 233MHz Pentium II model. If you power on the machine and just hold down the Q button it will then take you to easy set up. If you have Windows on it just wait to the IBM logo screen clears and press and hold F8 and that will bring you to Windows setup.
Nov 26, 2008 | IBM ThinkPad 380ED
174 error message on thinkpad 380
Try this:
Start with the machine OFF, hold down and CONTINUE TO HOLD the "F1" key and turn on the power WHILE STILL HOLDING DOWN "F1"
This should get you into the bios/setup, which on most thinkpads is pretty simple and self explanatory. You can reset the date, and something called "initialize" as I remember.
POST YOUR MODEL NUMBER!!!!
Ibm.com's support is famous for having very good, extensive support for thinkpads. I searched for this error no. but we really need the model number
http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-4YLR6R
Mar 18, 2008 | IBM ThinkPad 380ED
IBM ThinkPad 380ED Logo
1,919 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
