Question about Maytag Atlantis MAV6000 Top Load Washer
No hot water
I have a Maytag Atlantis Toploader. When I turn the knob to Hot/Cold no water comes out. On warm setting the water flow is cold. The hose is checked, the screeen is cleaned but nothing come out when turn to Hot/Cold setting. Please advise
    Scholar:
  • 90 Answers
Make sure your hot water supply valve is on first. If so then try reversing the hot and cold water feed lines and see if you get hot water when asking for cold. The water valve for the hot water side could be bad. Are you familiar with a voltage meter or know someone that can see if you valve coil is getting 120V when the machine is trying to fill with hot water. If not the control unit is faulty. If you do have the 120Vac on the solinoid coil and no water the either the coil is open circuit(bad) or the inlet is plugged. Most generally the problem is in the control knob unit.
Posted on Feb 03, 2008
Maytag Atlantis Washer - no cold water
Check the solenoid valves. If it's connected to hard water, the minerals build up inside and won't let the internal plunger move.
Mar 16, 2017 | Maytag Atlantis MAV9501E Top Load Washer
No hot/warm water coming into machine...checked all the obvious hot water heater etc. Somehow it not coming in from water hose/is there some sort of shut off valve on the washer....just getting cold water
There are 2 water solenoids on most washers. 1 for cold, 1 for hot. If the valve for the hot has a bad coil, or the wire connector has fallen off, it will prevent the hot water from flowing. If your live in area with very hard water, the valve may be closed shut from crud scale and such.
Nov 02, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Can't get anything but warm of hot water
If you set the washer for cold wash with a cold rinse, no hot or warm should enter the machine. If any hot or warm enters machine on cold / cold, check to see if the hot and cold hoses are hooked up correctly, and not reversed.
Jun 14, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis top load washer that wont' let cold water cycle through. Water is always hot or luke warm. checked screens on hoses. Any suggestions?
ok just a touch of help for ,,onthejob...i need you to start at a cycle and put unit on cold cold,,ok...now i want you to put your hand on back of unit where the inlet vavle and the hose meet at unit...do you feel a vibebration,,or here it humming,,now if hot water comes though,,all you have to do is reverse the hoses there on wrong,,im here onthejob
Dec 28, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag mav6000 hot/cold problem
hi try to just regulate the temp by turning down the water flow from your taps if more cold is coming in than hot turn cold water down a bit to your satisfaction thanks THE APPLIANCE DOC
Sep 05, 2008 | Maytag Atlantis MAV6000 Top Load Washer
My Atlantis Oversize Capacity Washer is the problem.When I select a Warm/Cold wash the water starts out warm, then kicks into hot water. So then I have to hit the Warm/Cold button over and over as it fill...
The temp is controlled by a thermistor to make sure the warm water is warm. If the incoming cold is too cold, or the incoming hot is not hot enough, it will compensate by turning off the cold until the temp comes up, then it should turn the cold back on. Make sure the hot supply is to the hot water valve. If the hoses are backwards it won't work right either. Or you may have a bad solenoid in the water valve. It's possible for a water valve to work when it's cold, but as electricity runs through it, the solenoid heats up and causes it to open electrically which will close it mechanically and turn the water off. Usually if this is the case it won't open again for at least 10 minutes until the solenoid cools down enough.
Jul 21, 2008 | Maytag Washing Machines
COLD WATER
3 suggestions. 1st, make sure all of your valves are open. (some times installers forget to open them back up after the install) 2nd, fill the machine until the water gets hot. Check on the rear of the machine and make sure the hose going to the "COLD" valve is not hot (somtimes these hoses are reversed when they are installed) if those are both ok, then 3rd shut the water off and unscrew the cold side hose. (There is a screen underneath that can get covered with sediment from the house water supply and cause the water not to flow)
Jun 04, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Hot/Cold water knob will not work on washing machine
Does the water flow when you have it on warm or cold settings?  If on warm setting and water flow is cold, its probably the mixing valve.  This part isnt that expensive, and not that hard to replace.  Remove the two front console caps, remove the two console hold down screws then flip the console out and then over the top.  You will see two gold cabinet hold down clamps, pop them out, the lift the whole cabinet off the unit.   You will see the mixing valve right where the inlet hoses connect to the machine.  Let me know if you need further help.
Oct 16, 2007 | Washing Machines
Maytag Atlantis MAV6000 Top Load Washer Logo
211 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
