Question about Zenith B27A11Z 27" TV
Tv colour gone green
Tv colour has gone green
  • 4 more comments
  • Anonymous Sep 28, 2008
    the colour of the tv is gone into a sepia tone - all red has disappeared!!!
  • Anonymous Dec 13, 2008
    when
    When my tv is on tv mode it is fine but when it is on dtv the colour is green !
  • tyxoo Jan 27, 2009
    everytime i on my tv the screen is green.i hit the tv and it works,but after awhile it turn green again.i hit it again and now it become blue colour
  • Anonymous Feb 08, 2009
    my tv colour has gone green
  • emonkton Mar 21, 2009
    I've the same problem as Sept 28 Guest. The Reds come and go. If I whack the side of the TV, the Reds come back....for a while. Glad to see I'm not the only one. Too bad about professional help though (I've nothing hooked up to it other than the DVD/VCR combo and a cable box).
    Problem Solver:
  • 7 Answers
Dan (above) is partly correct, that a resolder, COULD solve problem, but also BE WARNED!
HIGH VOLTAGES Inside the Cabinet
The Circuit components of the main circuit board could be up to 500 Volts at certain points.
THE CRT Voltage Doublers can have a lethal jolt to any skin that may make contact at the wrong points.
A Soldering Iron may be Grounded through the probe to earth (ground) and could potentially cause a problem when re-soldering the board.
GET THE SERVICE MANUAL or a Similar TV set manual.
Understand the building blocks of the TV and where the 'discharge' points are for the safety aspects of servicing the tube.
IF the above makes you skittish, bring TV to competent service shop. The $20-$30 is far cheaper than a trip to the burn ward or cardiac section of your local hospital!
For the problem above, the red may not be getting enough 'signal' from the video section.
The Red Filter Circuits could be clamping the red signal if a Capacitor has dried out on the main board.
a quick test is if the Video board has Composite Video inputs, What happens if a Video Source (VCR - Video Game?) is connected to the Video In.
Posted on Mar 22, 2013
    Scholar:
  • 119 Answers
It is the cinescopic tube damaged.consult a specialized services.
but fisrt of all try to  remove all the magnetic devices from him..like speakers..to see if there is any difference..
bye
Posted on Feb 03, 2008
2 Suggested Answers
  • 4234 Answers
SOURCE: The colour has gone wrong on my tv.
This problem could be as simple as poor solder connections on the board that sits on the back of the CRT to a defective driver transistor for the red gun to a bad picture tube. It is possible that this is an inexpensive repair (solder connection or defective transistor) or expensive (bad tube). If you can solder, try resoldering the CRT board connections and see if that resolves the problem. If not, then have a shop take a quick look. They will be able to determine whether the CRT is bad or not.
Dan
Posted on Mar 09, 2009
Colour on the tv as gone green
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Screen-shots to defective LCD panels are given. You can see and compare to that to your TVs', and can make sure about the fault to an extent.
Nov 12, 2014 | Televison & Video
The colours on my Wharfedale 350 tv have gone wrong. Everything is green and purple. How do I fix this.
The problem is AV cables or connectors on the TV, try to replace the connector shouldwork
Mar 04, 2012 | Televison & Video
I just plugged in kworld pc to tv and connected to tv.i have a picture but has lost its colour i have a green color now. no matter what i do to settings it is still green. what has gone wrong? is there any...
If it is all green, it is usually just the connection that is not plugged in properly - disconnect the cables and re-connect and make sure you did not bend any pins on the connectors. Also make sure it is not a lose connection in the cable (i.e. a damaged cable) test this by bending the cable at the connector - sometimes u find its just a damaged cable that can be replaced.
Feb 03, 2011 | KWorld PC to TV (0872880887527) Video...
Picture gone green
why mess with it, it is still probably under the manufacturer's warranty, call an authorized station or contact lg's customer service number to get a list of servicers tha can help repair it for you under the warranty.
Jan 09, 2010 | Televison & Video
Colours on tv screen have gone green in colour
If you have used the red, green and blue video cables, the your red is either damaged or loose. If yuo used the regular red, white and yellow AV cables, the yellow is loose or damaged, In either case, if the cable is not loose, you'll need a new set of AV cables
Nov 27, 2009 | Nintendo Wii Console
The colours on my tv have gone pink and green
Either your picture tube has gone bad or the transistor or IC on the crt board, on the picture tube, that feeds the blue gun has gone bad. You would have to test the transistor to see if its shorted or open with a multi-meter, or check the voltages to and out of it. The voltages are around 200v and dangerous if touched, best left to a proffessional. If its the transistor/IC it would be a cheap and easy fix by a repair shop, if its the tube, you may want to go tv shopping.
Aug 30, 2009 | Goodmans W280NS Television
Colours missing from tv
There are three color guns in a TV that make up the picture. Red, Green & Blue. It sounds like you have lost the green color gun.
You can get it rpeaired again, but your TV sounds like it is ready for TV heaven.
Jul 25, 2009 | RCA 20F512T 20" TV
Screen gone yellow and green
I have a 21'' NEC TV Screen and it about 3 year old. the colour has gone to yellow and green color and the red etc
May 10, 2009 | Samsung PPM42S3 42 in. Plasma Television
T.v problem with picture,too much red and no green colour
your TV's picture tube has gone ,just immediately change it.. it will be again working good.
Oct 09, 2008 | Televison & Video
Loss of colour
With the set being 12 years old, I'm sure the picture tube is near the end of its useful life. You probably have a defective semiconductor, either an IC or transistor that has gone up giving you no color, but with the green picture, it is not likely worth repair.
Jan 02, 2007 | Toshiba 36AF61 36" TV
Zenith B27A11Z 27" TV Logo
861 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
