Question about Minka Cirque Brushed Nickel- MinkaAire Indoor Ceiling Fans Fans
Light blows when turned on
I have a minka cirque. Every time I put a new bulb in and turn the light on, the bulb blows. I've tried a different switch with no change. I don't see any connecting wiring issues. Fan worked well for 2 years before problem appeared. Electrical feed supplies fan in second room as well and when the fan with the problem is swittched on, the fan in the second room doesn't work. Sounds like a short. Any idea where it may be occuring and how to trouble shoot?
  • 883girl Nov 25, 2008
    I have the same problem! My switch is only for this fan/light combo, does not power any other fan in any other room, just this one. Also, the fan wobbles horribly when running.
    Any ideas? Just burned through 3 bulbs in a row!!
  • Anonymous Mar 15, 2014
    the fan & night light work but the 2 bulbs will not light. Both the fan & night light are on a separate wall switch. The switch to light the two bulbs is located on a switch in the hallway.
I had the same issue. Electrician pointed out my bulb was not 120v like it needs but 12v-hence the problem.....
Posted on Dec 21, 2008
  • 103 Answers
Check the switch on the other fan and make sure the screws are tight, if they are used. If the wires are solid copper and go into holes into the back of the switch, remove them and use the screw terminals. This is done by inserting a small oject into the rectangular slot next to where the wire goes it. That will release the spring that hold the wire in, then you can remove it.
Hope this helps, and please rate my answer, good OR bad!
Good luck!!
Posted on Feb 04, 2008
Minka aire f608 top won't screw on
Check to make sure your blades screws are tight. They could be rubbing against the glass.
Jul 01, 2013 | Minka Aire Ceiling Fan
Changing light in minka cirque fan
You have to twist off the bottom housing.
Apr 20, 2013 | Minka Aire F596-BN Cirque? Fan
Some functions of switch stopped working
Sounds like you need a NEW RECEIVER. Call 1-800-307-3267(Minka Aire)
Feb 13, 2013 | Minka Aire Ceiling Fan
Minka Aire Como F603 - Light bulb burned out
I found the Manual to the F603 in pdf format at: It describes how to put bulbs in so it was simply a matter of reversing the instructions to get the old ones out. However, it is not that easy to get the bottom section off so one has to be careful or you will twist the whole unit instead of just the bottom part..... I think what you did was push up too hard and then turn the whole unit. Try pushing up firmly but at the same time hold some fingers (or have someone help in this) on top of the bowl above the fan blades and then twist counterclockwise an inch or two and the bottom part will release (don't let it fall). Then you have easy access to the bulbs. Good luck.
Sep 08, 2009 | Minka F603-WH Ceiling Fan
Fuse blows when shift in reverse
Am I correct, the turn signal fuse is blowing when you put the manual shifter in reverse?
Let me know.
Mar 26, 2009 | 1999 Chevrolet Tracker
Minka Aire Como F603 ceiling fan - light bulb replacement
Try Googling (Minka Aire)(F603)(manual) without parens for instructions.
Jul 28, 2017 | Minka F603-WH Ceiling Fan
Minka Aire Remote control R211
You need to change the tiny DIP switch settings so each fan is set up differently. (Note that each pair of remote transmitters--the one in the fan body, held in a bracket above the light kit when you drop that down; plus the one on the wall switch or in a hand-held remote, must be set with the same combination.)
Our Minka Aire Churchill model has 4 DIP switches; I have seen Casablancas with 5.
Jun 01, 2008 | Minka RC120 Remote Control
Minka aire concept II ceiling fan bulb replacement
The glass dome is tightened firmly in the factory, so removal is difficult. When removal is attempted to, the metal housing to which the dome is attached will spin with it, making removal impossible. To see what I'm talking about, look in the small space between the dome and the bottom of the blade housing - it looks like a metal flange, but this is only the bottom of the reflective metal canister that holds the light. Note that there are 4 "dimples" around the circumference of this housing, facing inward. These dimples are what hold the glass dome in place. The trick is to use a rigid piece of wood or metal about the size of a 12" ruler and place the corner of that ruler in one of those dimples - FIRMLY. Then, a second person can get some leverage on the glass dome and "unscrew" it from the housing (counter-clockwise). The purpose of holding the ruler-sized material against the dimple is to keep the housing from spinning with the dome. This is easier said than done, but it will work.
Mar 30, 2008 | Minka Concept II Flush 44 Ceiling Fan by...
Minka aire ceiling fan
This may not apply. There could be an electrical problem. But if you installed the bulb with your hand, the oil on your skin can cause the buld to heat excessively and fail. I suggest you use the packaging or part of it when installing it, taking great care not to touch it.
Mar 11, 2008 | Dryers
Dryers Logo
707 people viewed this question
Top Minka Dryers Experts
Joseph Coppeto
Joseph Coppeto
Are you a Minka Dryer Expert? Answer questions, earn points and help others
