Question about Eureka 5849A Boss Bagless Upright Cyclonic Vacuum
BOSS 5851 Wide Track, 12 Amp
Mine is actually the BOSS 5851 by Eurkea. Wide-track, 12-amp. The belt mechanism breaks easily. I may be missing a part that keeps it in place. It isn't easy to get too. The motor runs and I can push but the drive doesn't go probably due to belt. But why then does the cannister-like suction hose function just fine. Does anyone know where I can get an owner's manual on this unit? If U know, please email me. greyghosts and G mail dot com.
    President:
  • 1,673 Answers
The top comes off to get to the belt and brush roll. Did you check the brush roll to make sure that the ends turn freely, or is one not turning, the belt is a lon life "U" part #61120A. The brush roll is what drives the vacuum, but if brush roll or belt is bad, then it won't drive it.
Posted on Feb 05, 2008
Often on these models the right rotating, hexagonal clip on the brushroll breaks off, or worse, melts off from faulty alignment. Check out the Eureka website to buy a new roll for under $20.00.
Posted on May 03, 2010
6ya staff
SOURCE:
My rug doctor (wide track) started making a,loud noice. I thought it was a belt broke. I can't find that they sell belts. Wondering is it the motor? Or something else?
best take it to a vacuum machine repair shop and have a proper diagnosis of the problem done
save a lot of guess work and money
Dec 10, 2016 | Vacuums
Brushes don't move. vacuum motor works
The brushes on the roller are driven by a wide, short rubber belt. These belts get old, worn, overheated, and break periodically.
It should be a fairly simple matter to unscrew & remove the plate, revealing the belt and roller assembly. You can get a replacement belt at Sears or nearly any vacuum shop.
While replacing the belt, it would be a good idea to take scissors or a knife (careful!) and remove the hair & other material that's wound around your roller. One thing that can cause a belt to break is when you're vacuuming & accidently pick up a string, a shoelace, a piece of cord... you know how fast that gets wound around the brush roller and locks it up? At that point, the belt is still trying to rotate the roller (which won't rotate)... and within seconds, the belt will get extremely hot. This can cause it to break, or reduce its life significantly.
This should be an easy fix, requiring nothing more than a replacement belt and a screwdriver. Good luck!
Mar 03, 2011 | Kenmore 31913 Progressive Direct Drive...
Our brush doesn't rotate anymore on our U5402-900 vacuum cleaner. What are common causes of this?
The number one cause of brushes not rotating is a broken belt. If you remove the four screws holding the bottom plate, you'll see a short, wide rubber belt that goes around the roller.
If this is broken, it's easy to replace. They do break because of age and wear. One of the leading causes of breakage is when the roller gets something - a curtain cord, for example - wrapped around it. If you don't immediately shut off the vacuum & remove the cord, the belt will continue to try to turn the roller (which can't turn), and this generates a lot of heat in just a few seconds.
The number two cause of brushes not rotating is, as suggested above, something jammed & wound around the roller. It's always a good idea to turn the vacuum over periodically and clean the roller... including using scissors or a knife to snip & remove wound hairs & threads. A clean and healthy roller will help to keep your belt happy!
Mar 03, 2011 | Hoover Vacuums
Belt broke how do i chane this
Lay it down on its side, unscrew the cover over the brushes (don't lose them). You may have to pull the brushes out depending where the belt goes. Slip the belt on where it goes and put everything back together. The roller may be a little hard to put back in because of the new belt being tight but it will go on with a litte pushing. Good luck. Mine breaks all the time so I have it down to an art on mine. Just takes a few minutes.
Feb 19, 2011 | Dirt Devil 12 Amp HEPA Filter Vacuum...
I have a Ultima 12 amp e10071, The brush is not turning, there is tension on the brush as if the belt is connected but still there is no rotation. The motor does run. How cani open the vac to take a...
You get to the belt & brush roll area from the top. On the hood of the vacuum, right behind the word Altima, to the right & left sides, you will see a screw. Remove them, lift off plastic hood. Check belt if broken or just stretched too big to catch brush to turn it. Check ends of brushroll for any hair, thread buildup & clean it. See if end caps turn easily. If one or both ends do not turn easily, the brush roll would need to be replaced.
Eureka Brush roll part # 62365-3
Eureka U belt part # 61120D
Sep 01, 2010 | Eureka Altima Upright Vacuum Model 2996AVS...
Roller brush will not turn on Eureka "The Boss Power Plus" 12 amp
Depending on the model there will be a couple of screws on the top plastic cover. The cover lifts off and the belt is then serviceable. On some models you will need to remove some parts on the bottom too to get the roller out.
In any case just look for screws that hold the covers on and explore a bit. You can't break anything.
Jul 30, 2009 | Eureka Boss SuperLite Bagless Upright...
I have a eureka power paw that keeps breaking belts. there doesnt seem to be a part that keeps the belt in place
Make sure the roller and turbine bushings are clear of obstructions (hair, etc) and spin without excess resistance. As for a lack of barrier or belt guide, make sure that the bushing blocks on either end of the roller (and turbine, but most importantly the roller) are installed identical to each other (otherwise the roller may be in on an angle causing the belt to mis-track). Possibly a part may be missing or improperly installed, but not likely. What's important to remember is Eureka (Electrolux Homecare Products) designed the Power Paw as a cheap, quick source of income to add onto their uprights to cash into the ever-lucrative market of pet owners dealing with pet hair. Like their upright vacuums, Eureka/lux know extremely well the importance of designing their product with a very FINITE life-expectancy, and hence expecting this product to be anything of a long-term or durable solution is evidence only of you having been mislead by marketing. Of all the turbine-driven tools in use today, this one is the most inexpensive, disposable I've had the pleasure of working with. I got one free when they hit the scene. I took it back to work still in the package after seeing its track record evolve.
Long-term solution if you love these turbine-type tools? (and you should, they're great and solve major issues. I own several different ones and am very attached to them as attachments!). Go to a vacuum store and find a robust, long-life version of what these little things are trying to be. They're in a higher dollar-range, but so's a Power Paw if you start replacing it every few months. Ask for one made by Wessel-Werk. German engineering, been around for decades. The made-in-china knock-offs are better than the power paw, but if you're up for it, the actual tool made by Wessel is the benchmark by miles. The only thing possibly comparable in long-term quality and durability is called a RugRat by guys in our industry, and sold by Vacuflo and Kirby and such for decades and decades now. Most vacuum vendors should be able to hook you up. :)
Jul 12, 2009 | Eureka Vacuums
My Eureka Boss vacuum belt keeps breaking
I have been searching the machine for something which could be rubbing against the belt to cause it to fray and break as often as it does. So far, I haven't found anything. I have heard that the belts, called ribbon belts, are terrible! I find that the belts break faster when I use the hose. I haven't found a way to make a belt last longer.
Jul 03, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
My wife's Eureka 5855 Boss Bagless Wide Track stopped running
its probably something in the motor. you may have to replace the motor which could cost around $50.
Apr 15, 2009 | Eureka 5849A Boss Bagless Upright Cyclonic...
I can't figure out how to change the belt on my hoover bagless Sprint upright. Please help.
1 set up vacume with bottom facing you , making it easy to deal with.
2 remove the 4 screws holding base plate on and carefully remove the base plate, on mine there is a small catch that must be released.
3the belt compartment is on the right, remove the old belt, it's about 1 and 1/4 wide.
4 You have to put the belt on the stainless steel motor spindle first, then work the belt over the plastic drive wheel, and spin it around a few time to ensure it's running on track ok.
5 Replace the base plate , click in the self catching clip last.
6 Replace the four screws and test the vacume.
Oct 23, 2008 | Hoover Vacuums
Eureka 5849A Boss Bagless Upright Cyclonic Vacuum Logo
1,259 people viewed this question
Top Eureka Vacuums Experts
JoeVacs
Irene Tulloch
Android Man
Android Man
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
