Question about Haier HL37 37 in. LCD Television
Haier HL 37 BG
WORKED FINE FOR 2 WEEKS, NOW WHEN I TURN IT ON ALL I GET IS A BLUE SCREEN, IT WILL PLAY DVD THROUGH COMP-1
There is a Haier Authorized Servicer in NYC who repairs the panels. Give them a call . Website is www.asnyonline.com
Posted on Sep 11, 2008
My brand new flat screen haier tv 39'' is flashing white then red green then blue and black screens how do i fix
Try to disconnect the set and a box if being used from power for a while and then power both back as either could cause this problem.
Dec 15, 2012 | Haier Televison & Video
T.V. COMES ON WITH A BLUE SCREEN ONLY WILL ONLY PLAY DVD'S
CHECK TO SEE IF YOU TV IS SET TO AV OR EXT 1 OR 2 ETC
IN SET UP MENU OF YOUR TV
CHECK SCART PLUGS ARE PROPERLY INSERTED
Aug 25, 2010 | Protron PLTV-37 37 in. LCD Television
Unlock a Philips portable DVD Player Pet 741/37
It worked for my Philips PET741/37:
1. Power ON the DVD player without a DISC inside
2. Press the skip keys in this order (the keys are under the "disc menu" and "stop"): right, left, right, left, right, right, left (YOU DON'T HAVE TO GO TO SETUP MENU, just do this in the "blue screen".
3. It will show a menu with region, now use the arrow keys to select "region" and change to "test 0" (all regions).
4. Press OK to confirm. Enjoy
Silmara
May 15, 2010 | Philips PET724 Portable DVD Player
04 Pontian Montana DVD, dead battery
sound like a fault in dvd player.its running battery down.have dealership check it out.sound like a electrical problem.
Jan 03, 2010 | 2004 Pontiac Montana
Lost entire picture, sound and everything else OK
check the invertor boards resistors they power the back lights
also check for any capactors that have blown (raised tops) they look little bateries
Dec 12, 2009 | Element Electronics FLX3220F 32 in. LCD TV
Burned image on comp 1 chanel
When an image is burnt in to screen it is always there you just dont see it when you watch tv because of the changing video. On some sets you can burn the image out by using a all white screen, from a signal generator or from the service menu, turning the brightness all the way up and letting it play for 24 hours. Here are some websites that have software that is supposed to erase burn-in images, but you would have to hook tv to a computer, unless it can be copied to a dvd and played through a DVD player. Have not used it myself so not sure how or if it works. Be careful not to cause any more damage to screen. A new screen can cost a few hundred to over a thousand dollars to replace. Set should be taken to a panasonic repair shop to try burning it out with white screen approach, so if they damage it they have to fix it.
http://www.sharewareplaza.com/JScreenFix-download_44365.html
http://www.top-shareware.net/lcd.html
http://www.fast-download.info/screen-fix.html
Nov 03, 2009 | Panasonic TH-37PX60U 37 in. Plasma HDTV
Blue screen on my haier 37 inch tv
my tv just went to a blue screen one day. I can turn it on and then it will just remain on the blue screen. Any button (except the volume) I push on the remote comes up on the screen "no signal". What would you suggest? I have been reading about replacing a fuse or board? Most of those are on the 42 inch version---I have teh 37 inch version.
Feb 02, 2009 | Haier HL37S 37 in. LCD HDTV
Prima HDTV has a black screen on TV, but works fine while Playing DVD
try turning the channel up or down with the tv remote to input 1 or 2 depending on which one is being used for the dvd player. tv should use input 1. dvd should be on input 2.
when turning the channel set it to show the dvd screen, then go up 1. if it doesn't show, return and go down 1.
Oct 22, 2008 | Prima C2012 TV
Haier HL37 37 in. LCD Television Logo
78 people viewed this question
Top Haier Televison & Video Experts
Jaime Hernandez
CoppellTVRepair.com
Are you a Haier Televison and Video Expert? Answer questions, earn points and help others
