Question about Car Audio & Video
Speedo, horn & central locking not working on Mercedes C180 elegance
Speedometer not moving at all. horn not working. can't lock doors with key,
  • Anonymous Feb 24, 2008
    speedo not moving stuck on 0mph milage not going up?
  • DeeCl Oct 07, 2008
    Speedometre not working at all and central locking gone after being relpaced last year.
    Please help!
Neither Speedometre is at 0 and milage isn't going up and now the boat is locked and we can't open it as the central locking is gone!
Any ideas?
Posted on Oct 17, 2008
I have a Mercedes Benz C180 '98 battery is dead
Spray the lock with WD40 and work it a few times over you should be able to unlock it.
Jul 10, 2013 | Cars & Trucks
The horn on my Mercedes c180 Elegance 1995 n reg automatic isnt working, but when the alarm is set off the horn sounds..is there a simple fix for it ?
Hi paul, If the vehicle has air bags the problem very well may be the unit inside the steering wheel. The unit carries the connections for a number of operations and problems occur when a cable in the unit breaks. Regards John
Oct 17, 2012 | Mercedes-Benz E-Class Cars & Trucks
Nissan micra,02,5dr .998cc,no horn, and 1 key won't lock doors
i'd say 2 completely different issues,did key work when you bought vehicle,i'd say ones a replacement and they may not have coded it to immobiliser,horn may be horn itself ,but often the moving parts behind steering wheel fail,have you checked the fuse?the relay can often fail to
Nov 20, 2017 | Nissan Cars & Trucks
I have a mercedes C180 Elegance - N reg. I've just changed the batteries in my key fob, as I was unable to unlock the door, therefore opening it manually. After changing the batteries the car started....
Theres something on google about that i think you turn ignition on and hold 1 of the buttons not sure which this is suposed to reprogrambthe key to the car and visa versa but i would defobtry google as there are many uploads about this i have a m reg 180 its not that posh just a key no fob which isvthe way i like it unless its cold and my mouth gets stuck to the door lock defrosting it lol hope this gelps cheers ivan
Nov 23, 2017 | 1995 Mercedes-Benz C-Class
VZ 2005 ute central locking works well from the
is it a factory or aftermarket security system?
Apr 28, 2010 | 2008 GMC Savana Cargo
Ihave just purchased a mercedes c180 esprit 1994, but speedo not working
check the speedometer cable that runs from your speed gauge to the rear side of the transmission..either you have a loose connection or a bad cable
Apr 21, 2010 | 1994 Mercedes-Benz C-Class
1998 mercedez c180 won't open with key,fob won't work either.When i press the key the indicators flash as normal but the locks won't open.I have no access to the car.HELP!
sounds like a fault with the comfort control module.if u go to the passenger side front door u can pop off a plastic cover on the handle and this will allow u to open the car with the key.
Mar 09, 2010 | Mercedes-Benz 190-Class Cars & Trucks
1996 C-180 manual saloon, central lock is not working properly
must be the central locking module. its different from the cars alarm.
Jun 03, 2009 | 1996 Mercedes-Benz C-Class
HELP HELP !!!!!!! Electric fault i think !!!!!!!!!!
1....ensure the battery in the "Key Fob" is OK............Press either Lock or Unlock button for more than 1 second, the lamp on the fob will light if OK. Change battery if it does not illuminate! 2.....if battery on fob OK.......Re Syncronise the key fob to the car by:.... a brief press on either button twice and within 30 seconds turn Key to position 2 on the ignition lock
Hope that fixes it...let me know?
Nov 09, 2008 | 1998 Mercedes-Benz C-Class
Car Audio & Video Logo
380 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
