No power with Sanyo TV
Sanyo TV, model DS31650, suddenly has no power. Sanyo customer support suggests that it needs a new fuse. Sounds simple enough, except which one of all the thingys in the back of the TV is the fuse? What does it look like, should I be able to replace it myself, and where would I get a repacement? Home Depot? Best Buy?
  • Septenber42 May 28, 2008
    TV went dead for no apparent reason, red standby light flashes red then orange. No live sound or static coming from TV.
  • Anonymous May 30, 2008
    Se prende y dura tres segundos y luego se apaga ya le revise el +B y esta
    ok en 130 volts. La proteccciòn lo esta apagando por algun sobreconsumo de corriente y entonces se activa el shut down. lo forse a trabajar con una fuente externa y le inyecte el pulso de horizontal al driver y el HOT se calento supongo que debe ser el fly back pero no le encuentro la referencia podrian colaborarme con la referencia del fly back por favor.
    Gracias
Why isn't the answer to Tom Gray's problem posted on this site?
Posted on Feb 15, 2009
The problem was fixed at a repair shop. They "replaced thermistor in degause circuit adjusted as necessary". The part cost 19.95.
Posted on Mar 28, 2008
Sanyo tv mod.ST21kx2 no power on
Posted on Feb 14, 2008
  • corics Feb 14, 2008
    sanyo tv mod.ST21KX2 dead
    what component replace sanyo tv st21kx2 dead
Sanyo dp42841 no picture
Sounds like either the CCFL for your LCD TV has blown (It's basically a miniature florescent tube) or the inverter that drives it has given up.
Have a look on Ebay for replacement parts and to see if you feel confident enough to tackle the job yourself.
Sep 05, 2014 | Sanyo Televison & Video
NO POWER ON SANYO TV MD DS31650
Check and replace damaged component/s at its main power supply regulator stage [SMPS] circuit. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Feb 14, 2014 | Televison & Video
Vertical line in center
If the line is "vertical" then the vertical circuit sounds OK. The problem would be in the horizontal deflection.
Check yoke connection and solder around horz defl circuit.
If the line is horizontal then I would suspect the vertical IC.
Apr 02, 2009 | Sanyo DS31520 31" TV
Sanyo e16 camera not working
Sounds like protection mini SMT fuse in DC/DC circuit. Needs to be replaced.
Mar 18, 2009 | Cameras
I have a Sanyo 32 inch tv, model # DS31650, that has no sound
there is an SIF coil (sound-intermediate-frequency) that goes bad on these units. it will be near the video jungle ic and marked sif on the board. since your sound is poor anyway you could try to adjust, in very small incremens at a time to see if audio picks up. sometimes dirty connections in the coil will cause poor conductivity, by turning this will move contact to new position mch
Mar 08, 2009 | Sanyo Televison & Video
Does my Sanyo TV Model Number DS31650 need a converter box?
As long as you have either cable or satellite, you will be OK. The change coming in Feb. is for people who still use an outside antenna( rabbit ears). Please take time to rate this response. Thanks
Dec 07, 2008 | Televison & Video
Sanyo DS31650 31
If the set runs at all, your flyback and output transistor are good. If the set shuts down after a few seconds and the sides are wavy, it usually means that the main B+ in your power supply is too high and not regulating properly. I do not know what kind of power supply that model uses, but if has an old-style STR regulator (like the STR30130) then it is probably shorted, and if the set uses a switching power supply then look for an open or leaky electrolytic cap on the primary side. If the power supply is working correctly and the set shuts down, check for an open safety cap (the large 1.6 - 2Kv cap connected to the collector of the horizontal output transistor).
Aug 17, 2007 | Sanyo HT32744 32" TV
Screen split with black bar through center, top of picture shows in bottom
It sounds as you desribe, the vertical output IC and or the b+ feed capacitor off the Hi voltage transformer feeding the vert. IC its required voltage. Not a really hard job to replace, but not for a handi person to do. This should be left to the professional, as there are no user serviceable parts inside this set and with the HI voltage and the safety issues its best to call somesone to assist you with this repair. Good Luck
Jun 14, 2006 | Sanyo DS31520 31" TV
Televison & Video Logo
1,628 people viewed this question
Top Televison & Video Experts
