Question about Arris SURFboard SBG900 Wireless Router (DHSBG900)
Second PC Thanks to help from this site I have security set up on my SBG 900 Motorola Gateway. My second pc has an adapter that I have decded to remove and go with cat 5 cable instead after I turn off the wireless feature at the access point. I wonder if I can add the cable to the second pc with a simple "T" connector or is a hub necessary from the Motorola access point. I only plan to use them for internet surfing, no printer control or data transfer. Thank You.
    Novelist:
  • 171 Answers
You can't use a T connector for a network (to my knowledge there is no such thing for an ethernet cable). All computers must connect directly to the router, whether they connect wirelessly or not.
Your other option is you can purchase a network hub/switch, e.g. one of these:
http://www.bestbuy.ca/catalog/subclass.asp?logon=&langid=EN&catid=21103
You plug this it into your router. Then you can plug usually up to four computer into it, and they'll all be on the network.
Posted on Feb 03, 2008
If I don't have the disk to run the set up program for my motorola sbg 900 what can I do to set up my connection as a secure network?
go to this ip
http//:192.168.100.1
Defualt login: (if you did not set one)
user: admin
pass: motorola
and you will get the con-fig for the router
also here is the manual for this router/modem.
MotoModem
May 18, 2011 | Arris SURFboard SBG900 (49402201900) Modem
Weak signal thorugh my sbg 900 wireless surfboard gateway
On the Wireless > SECURITY — basic Page check whether the WPA Encryption type is TKIP.
If all of your wireless clients support AES, change the WPA Encryption to AES. This may make a difference for you.
Jan 03, 2010 | Arris SURFboard SBG900 (49402201900) Modem
Motorola SBG901 how do I secure the network
Go here and start on page 61. It tells you all the setting you need to make your wireless secure.
Hope this helps! Please rate if so!
Dec 15, 2009 | Arris SURFboard SBG900 802.11g/b...
My x box keeps saying my mtu settings need set at 1364 or higher i have a motorola sbg 900
Is this a router or a modem? Could you please tell me exactly how your xbox connects to your network?
Jul 17, 2009 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Cant lock my signal was trying to find a alternative way because i lost the disk??? i have a SBG 900 and any one can get on my internet signal
There's another option to configure the security or encryption using your SBG 900
Connect your computer to one of the LAN ports
Access the configuration of the modem (example 192.168.254.1)
The if you got the configuration page open find the wireless settings and configure the WPA or WEP security using your modem.
Mar 08, 2009 | Arris SURFboard SBG900 Wireless Router...
Need to change the security of my SBG 900 wireless router
Plug your router in with an ethernet connection and type 192.168.100.1 into your browser address bar. This should load the modem login screen. Unless you have changed the username / password they are admin / motorola. From here you can click on wireless and configure the SSID and security setup.
Feb 07, 2009 | Arris SURFboard SBG900 (49402201900) Modem
SBG 900 SECURITY
you probably need to access the web management function for this modem. Using a PC connected to the modem, open a web browser and type into the address bar the address of the router/modem/gateway. This is usually 192.168.0.1 or 10.0.0.1 or 10.1.1.1. If you cannot find this information, find the status of your ethernet connection on your computer (where it tells you you computer's IP and time connected etc). Here you will find a number labeled "Gateway" this is the number you want to type into your web browser.  Once you get this correct you will be prompted for a username and password (by default it will be admin, admin) then you should have access to the configuration of the modem.
Write back if you're unsure of any steps
Jan 08, 2008 | Arris SURFboard SBG900 (49402201900) Modem
Need Firewall
For what reasons do you want to install a firewall on the wireless network? There may be valid one's I just need to understand what you want to achieve.
Here is another option to complete a different task that traditional firewalling will not stop.
If it is to secure the network from use by others outside those intended then there are other means that should be considered. The SBG900 supports WEP encryption -- where a password (or passphrase) is entered into the router and into each wireless adapter (assuming the wireless adapters also support WEP) of machines to connect to the router keeping those machines without the password off the network.
Jan 03, 2008 | Arris SURFboard SBG900 Wireless Router...
Networking with Motorola SBG 900 Gateway
No, you don't need a router... that gateway supports up to 253 devices on your private network segment. That being said, you only have one ethernet port, so if your desktops have LAN cards rather than wireless, you'll need a hub to split off enough ports. If you add a router, it'll give you a whole new level of complexity. A gateway is a router/modem combo. It converts the Cable Internet signal from your ISP to ethernet and isolates all of the computers behind it into your own private network. A hub is basically an ethernet splitter... it won't isolate a new network segment, it'll just add more ports. Get a hub, they are cheaper and won't add a new level of complexity.
Sep 09, 2007 | Cisco (1841) Router (cisco1841)
Arris SURFboard SBG900 Wireless Router (DHSBG900) Logo
79 people viewed this question
Top Arris Computers & Internet Experts
bobkoure
Level 1 Expert
Jerry
Jerry
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
