Question about Toshiba TLP S30 Multimedia Projector
Image The projector has a brand new bulb. When turned on it starts up fine and displays a crisp and clear start up page. But a yellowish tint seems to overlay the image displayed---except around the edges. The picture is perfect around the edges. I wonder if the yellow tint in the center may be signs of a burned panel or whatever lens is positioned next to the bulb. Anyway, it's too bad because otherwise, as I said, the picture image is crisp and bright even the within the yellowish part. I would appreciate any thoughts on this. Gilbert
  • gtxr77 Feb 03, 2008
    The Toshiba TLP S30 has a brand new bulb just installed. It starts up fine and displays a bright and crisp image. However, a yellowish tint overlays the image. Yet around the edges, the image color is perfect. It almost looks as though a panel or lens next to the bulb was burned causing the yellowish tint almost to the edges.
    I would appreciate any thoughts you might have on this.
    Tried adjusting the color, contrast, etc. but the yellowish tint is still visible.
    Also went through the steps for installing the new bulb and did not notice any obstructions near the lens area. The glass part that fits next to the lamp looks clean and clear. Any other ideas? Thanks. Gilbert
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 175 Answers
Well try changing the bulb again may be the problem is with the bulb.
Posted on Feb 03, 2008
    Genius:
  • 3,422 Answers
try adjusting the color first then tint. Sometimes if it is in a smoky enviorment it can cause a yellowish circle in middle of picture if it is a LCD. If it is a DLP, then it could just be the lamp going bad. I have seen them go bad as little as 50 hrs. This is why they give a 90 day warranty on most lamps. Let me know how this pans out..
Goodluck,
please don't forget to rate me as fixya..
  • 417 Answers
It maybe a filter problem go through the steps you took when installing the new bulb and check all then test.
Thanks J
6ya staff
SOURCE:
Sony Projector VPL-CW255 is showing yellowish tint on screen. I have put in new bulb, changed filter, new cord and still yellow? Any idea what else to do?
Wire ages no matter how many times it's used. You may want to check the amount of nicotine that may be on the lens if there is smoking allowed in the room too. It will add a yellow to orange tint as well.
May 27, 2014 | DS Miller Inc. Equivalent of PHILIPS LC...
We have a new bulb for our 50v720 and now there is a yellow tint!
Hi , it seems you are experimenting a light engine problem.Here's how your tv works: http://www.youtube.com/watch?v=ZLLHnQ4y-wo Basically there's 3 LCD chips that create the colors and image by blending together.When these chips start to melt you will get those blue spots, yellowish tint,pixilation even vertical lines.You will need to replace the light engine. Have a blessed one!
Apr 19, 2010 | Hitachi 50V500 50 in. HD-Ready LCD...
I have a yellowish tint in the center of picture
Why does my picture appear yellowish on the screen? I haven't changed the bulb in at least 2 years. Does this make a difference?
Aug 11, 2009 | Epson - PowerLite S1+ Multimedia Projector
Projector displaying yellow tint in center of screen.
The yellow tint is probably coming from the lens. It could be that the glass is tempered or possibly just needs to be cleaned.
Jul 24, 2009 | Sanyo PLV 60HT Multimedia Projector
Display has a green tint to it tho it looks fine on the laptop.
A tinted image (whether green or another color) is almost always a symptom of a bad or damaged cable - or a loose cable connection. In your case, you'll likely need a new M1 to VGA cable (Part# SP-DVI-A-R).
Assuming that you've made sure that the cable connections are solid at both ends, there is a simple test to verify that this is a cable issue and not a costly projector issue. While the image is tinted green, open the menu. If the menu colors appear fine while the rest of the image is still tinted green it's the cable.
Jan 21, 2009 | InFocus LP70+ Multimedia Projector
Optoma MovieTime DV10
I have the same issue, I have figured out its a fan issue, my fan must have went out. After about ten minutes the bulb will get too hot and the picture will start to turn a way off tint color. I put a fan on my projector and after about 40 min. the picture returned to the appropriate color. I am still investigation on how to get and replace the fan.
Sep 02, 2008 | Optoma MovieTime DV10 Multimedia Projector
Image flickers and colors off
I have the same problem as philvo. I was watching, the projector was operating normally, I heard a snap, there was a flash of light behind me I believe, and my Mitsubishi XD300U projector went to a black and white picture. That is all it will show now. All lights show normal operation. I would like to know if it is worth getting repaired. Does anyone have any ideas?
Jan 07, 2008 | Mitsubishi XD300U Multimedia Projector
Permanent Coloured tint
When the image turns pink, we find that replacing the cable between the projector and the lap top fixes the problem.
Sep 10, 2007 | Sanyo PLC-XU47 Multimedia Projector
Magenta tint to the projected image
The Lens assembly requires service. The dust is inside the panels.remove the dust and that will work fine
Apr 19, 2007 | Toshiba TDP-MT500 Multimedia Projector
Toshiba TLP S30 Multimedia Projector Logo
397 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
CheckitRight
CheckitRight
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
