For dolby digital to work you have to have the optical or coax cable hooked up to the reciever ,The HDMI cable is for digital video and audio output but does not support dolby digital out the cable into your reciever , so just turn off the dolby digital on your reciever and you should hear the sound.
here is more info
Dolby TrueHD is an advanced
lossless multi-channel audio codec developed by
Dolby Laboratories which is intended primarily for high-definition home-entertainment equipment such as
Blu-ray Disc. It is the successor to the AC-3
Dolby Digital surround sound codec which was used as the audio standard for DVD discs. In this application, Dolby TrueHD competes with
DTS-HD Master Audio, another lossless codec from
Digital Theater System.
Dolby TrueHD uses
Meridian Lossless Packing (MLP) as its mathematical basis for compressing audio samples. MLP was used on the earlier
DVD-Audio format, but details of TrueHD and DVD-Audio differ substantially. A Dolby TrueHD bitstream can carry up to 14 discrete sound channels. Sample depths up to 24 bits/sample and audio sample rates up to 192
kHz are supported. Like the more common legacy codec Dolby Digital, TrueHD
bitstreams carry program metadata.
Metadata is separate from the coding format and compressed audio samples, but stores relevant information about the audio waveform. For example, dialog
normalization and
Dynamic range compression are controlled by metadata embedded in the TrueHD bitstream.
I TRIED THE FIX AS SUGGESTED. STILL DIDN'T WORK. I WENT TO BOTH MY BLU-RAY PLAYER SETUP AND CHANGED EVERYTHING TO DIGITAL AUGIO AND DID THE SAME FOR MY TELEVISION. I AM STILL GETTING ONLY AN AUDIO SIGNAL ON MY RECEIVER. NO SOUND AT ALL IN THE DIGITAL FORMATS.
