Question about Toshiba TN55X81 55" Rear Projection Television
Broken Mounting bracket Toshiba TN55X81
The mounting bracket supporting the board PB8923 in a Toshiba TN55X81is broken. I thought of trying to epoxy but would rather have a new bracket if they can be purchased seperatedly. I'm having trouble locating a supplier.
    Master:
    Sergeant:
  • 440 Answers
New braket hard to get on this model i loked all over i would use e poxy like u said should be fine
Posted on Feb 03, 2008
Everite umbrella part
Probably, but neither cheaply nor easily. Try scrubbing it really well with a steel wire brush, then repairing it with epoxy. Use too much - make sure there's plenty of epoxy on the outside for support. If that doesn't work, it'll probably require heliarc (because it's probably cast aluminum).
You MIGHT get lucky and be able to buy a replacement, which would save you all this trouble.
Feb 01, 2014 | Deco Lav Plumbing
Maouting bracket is broken
check with Charmglo , we do not know what they sell parts wise
Jan 12, 2018 | Masterbuilt 20010406 Deep Fryer
Broken mounting bracket
Refer your inquiry to Masterbuilt.
Dec 21, 2013 | Masterbuilt 20010406 Deep Fryer
I have a TN55x81. the picture will just stop working (goes black). I will shut it off for about 5 minutes and then it will work fine. Some times for 2-3 days and other times just 10-15 minutes. Any ideas??
Intermittent problems on this type of TV are often because of cracked solder joints on the circuit board. They can be hard to see. When the TV gets warm, parts on the board expand and move by tiny amounts, sometimes with the right amount of expansion or vibration from the speakers, the broken solder joint looses connection and the unit shuts down. When things cool-off, the contact can be made again all by itself and everything fine until it happens again. Given the random nature of your problem, this is a suspected problem. Often it is the solder around the lead of a large component which is mounted to a heatsink.
Jan 22, 2011 | Toshiba TN55X81 55" Rear Projection...
Husqvarna ST927E snow blower. The mounting bracket for the auger end of the auger engagement cable is broken off. This is a 1998 model so the mounting bracket is welded not bolted. I see the new parts...
Obtain the new bracket and drill holes in the old bracket remainder to allow mounting of the new bracket over the top of the old part. You may have to do a little grinding on the old part to allow flush mounting of the new part. Apply a little grease or some paint to protect the damaged metal. Hope this helps!
Dec 01, 2010 | Husqvarna Garden
My TN55X81 is showing the same problem.
Replace the IC's with STK 392-110T.
Toshiba has a Service Bulletin on this problem.
Aug 01, 2009 | Toshiba TN61X81 61" Rear Projection...
Transmission dip stick moves on a ford f150 2001
is the mounting broken?look at the bottom.you may need to make a bracket for it.if it leaking at the bottom it has to be de greased and then epoxy to the motor
Jul 11, 2009 | Metra Ford F 150 Truck 1996 Up
Hotpoint aquarious extra wd63 motor mounting broken
Made a new mounting bracket out of a piece of flat bar. Machine has never run so quietly!
Jun 13, 2009 | Washing Machines
Maytag Neptune Broken Tub Support Arm
ummm yea your int market for a new washer. why cahnce epoxying a tub thats holding water doesntsound like a viable option. ( not worth the chancing the flood )
Mar 16, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Laptop LCD mounting bracket broken.
try ebay search for toshiba Satellite A105-S361 "for parts only". you may get one for less than $10.00.
Sep 16, 2007 | Toshiba A105-S4054 Notebook
Toshiba TN55X81 55" Rear Projection Television Logo
77 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
