Question about PfaFF Creative 7570
Trying to us Creative Card
I have inserted the card and picked my item and press the foot control and I get an error that says Bring pressor foot to embroidery/darning position. I have tried it in the up and down position and say ok and the same error comes up again.
Slowly move the presser foot lever down while putting light pressure towards the rear of the machine. Just before the foot is fully down it will click into a position toward the back of the machine. This is the embroidery position.
Posted on Mar 23, 2008
There is an in- between setting. It's not up, but not down either. Does that make sense? If you put the lever up, then bring it down slowly and kind of push it to the back. Hope this helps!
Posted on Feb 09, 2008
Error message on Pfaff 7570 is "bring presser foot lifter to sewing position?" Is this a fatal error or is this a procedure that has to be done before the machine will operate?
Assuming that the presser foot lifter is working, this shouldn't be a fatal error. The presser foot has to be down to sew. The lifter needs to be in the down position to put the foot down.
The manual for the Pfaff Creative 7570 is available on the product page: http://www.pfaff.com/en-US/Machines/creative-7570 . The direct link to the manual is http://www.pfaff.com/SiteMedia/PFAFF/Products/Machines/Support-manuals/Creative_7570-manual-EN.pdf?ext=.pdf . See page 32 (page 36 of the PDF) of the manual to see a picture of the presser foot lifter.
I hope this helps.
May 27, 2018 | PfaFF Sewing Machines
Bar that sewng foot is attached to for raising & lowering suddenly will not drop sweing foot all the way down to plate. Any suggestions on how to fix?
Perhaps you accidently moved the switch that enables free hand embroidery? It's up and under next to the pressor foot lever. Slides forward and backward. Forward the pressor foot will go all the way down to the feed dogs. Slid back and it keeps the foot up off the feed dogs but allows the thread tension to work properly. It would be easy to accidently move it when operating the pressor foot raise/lower lever.
Aug 31, 2014 | PfaFF Sewing Machines
6020 off problem
Not sure, but am thinking perhaps the tension disk has gunk or threads stuck in it. Try soaking a length of perl cotton in rubbing alcohol, squeeze out the excess. Raise the presser foot and loosen the tension disk as far as possible and gently pull the perl cotton DOWN through the tension disk a few times.
If that doesn't help, then it's possible a spring in the tension mechanism or something in the presser foot lever is malfunctioning.
Dec 07, 2017 | Sewing Machines
Problem with striaght stitch pressor foot
it's possible that the needle bar is out of alignment and needs to be fixed at a sewing machine shop
Mar 18, 2014 | Kenmore Sewing Machines
How do i thread my needle with the singer handy stitch?
  1. Loosen needle screw & insert needle with shank's flat side facing front of machine. Push needle in all the way, then tighten screw to hold needle in place.
  2. Install a fully wound bobbin by loosening bobbin nut & placing bobbin on top. Re-attach bobbin nut & tighten. If standard thread spool will be used, then attach spool pin to bobbin shaft & place thread spool onto shaft. Attach white spool cap on end of thread spool, then tighten. Bobbin/spool should unwind facing forward toward needle.
  3. Bring end of thread through thread guides & over tension control. Pass end of thread through needle eye, from back to front, & pull it out about two inches.
  4. A spring pushes pressor foot onto fabric that is being sewn, so lift pressor foot & place fabric underneath.
  5. Turn large handwheel on side of machine (handwheel can be turned in either direction) to raise needle arm to its highest position.
  6. Holding the Handy Stitch in place with your right hand, press on power switch & begin sewing. Guide fabric (being sewn) with your left hand.
  7. To end this sewing session, turn off power. Turn handwheel to raise needle to its highest position. Carefully pull out about three inches of thread through needle & snip, then lift pressor foot to remove fabric. Turn fabric over & loop needle threader through last stitch. Place end of thread from underside through eye of needle threader, & pull to loop through. Pull to tighten and snip end of thread.
Nov 11, 2010 | As Seen On TV Handy Stitch Mechanical...
Foot control will not work machine just stoped mid stich
Try using the Start/Stop button instead. It works just like the food pedal. You might like to bring the speed down first or else it will take off like a rocket when you press the button! You hit the button again when you want to stop. Sounds like you might need to replace the food pedal - unfortunately an expensive item. Try taking it out of the machine, coiling up the cord, uncoil it and re-insert being sure to push the plug in firmly. Check along the length of the foot pedal cord to see if there are any cuts in the cord. If there are, it will definitely need replacing.
Jun 02, 2010 | Husqvarna Designer I
I can't get the pressor foot on the silver part came off and the actual pressor foot
Place the foot under the arm while arm is in up position. Put arm in down position and foot should snap into place (line it up where it is supposed to go together before lowering the arm).
May 11, 2010 | Brother XR-65t Mechanical Sewing Machine
I cant get the machine to sew a buttonhole.
I am not familiar with your machine, but some buttonhole attachments require a lever be lowered and inserted into a tab.
Review your manual to see if a step was overlooked.
Mar 07, 2010 | Janome Sewing Machines
I am trying to embroider something for the first time on my viking #1 husqvarna. Do I need presser foot Q/ or R/ .If it's R,I can't find it-what does it look like? I need someone to walk me thru the steps...
embroider on #1+:
If it's a #1+ I recommend the Q (the spring works better) it's hard to put on, but worth it.
Here we go:
1>Turn off machine (always when installing or removing embroidery unit)
2>Install Q Foot. Always leave presser foot pressure (on left end of machine) at 6 for presser foot Q
3>Insert Embroidery Card
4>Insert Embroidery cassette (matching #’s with card)
5>turn on machine
6>Turn on embroidery unit (on cassette)
7>Select design
7>Thread for color 1
8>press reverse to start the machine embroidering....weeeeeeeee!
Jan 18, 2009 | Husqvarna Viking 1
Sewing Machines Logo
120 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
