Question about Dishwashers
Kitchenaid dishwasher kds-18
Should lower wash arm lift off shaft easy? then should shaft lift out easy?why is shaft knurled where it goes down in the pump ?
  • Mark Booker Nov 23, 2012
    I have water jetting from a molded plastic hole at the bottom of my KDS-18
I have a kds 18 that I just use for parts, I may be able to help u cheaply Mark
Posted on Jul 05, 2008
    Novelist:
  • 130 Answers
Knjjjr what you have is a defective (or in this case) worn out lower wash arm support. No the shaft shouldn't come out. It will need to be replaced. However remember this dw is over 20 years old.
Posted on Feb 03, 2008
How do I remove spin arm assembly from my kitchenaid dishwasher
About 56,200 results (0.83 seconds) Search Results
    How To Repair Dishwashers/KitchenAid Repair/Chopper ...
    https://en.wikibooks.org/...Dishwashers/KitchenAid.../Choppe...
    WikibooksDisassembly guide to access the chopper assembly in: KitchenAid K seriesdishwasher (similar to Whirlpool and Kenmore models) ... If the door safety interlock fails, the dishwasher could return to an active mode where these blades spin and ...place and carefully work around it to remove the upper spray arm water conduit.
    How to: remove and clean your dishwasher spray arms ...
    ? 3:13
    https://www.youtube.com/watch?v=MCWvxGmK3eM
    Feb 1, 2013 - Uploaded by Indesit Service UK
    Watch our easy to follow guide on how to remove and clean your Indesit dishw... ... KitchenAid & Whirlpool Dishwasher - Not Cleaning ,pump wash arm impeller chopper ... Why am I getting poor results from my dishwasher?
    Dishwasher Not Cleaning-How to Remove Spray Arms ...
    ? 3:47
    https://www.youtube.com/watch?v=BIru-ieAK54
Feb 03, 2016 | KitchenAid Dishwashers
I have a Kitchenaid dishwasher KDS18. How do I replace the TANK SEAL at the bottom of the door? Do I take the door off to replace it? Thanx
It's always best to remove a door to replace a seal. Lay the door on a hard flat surface so there isn't any twist in it. Remove the old seal and install the new one.
May 13, 2011 | KitchenAid Dishwashers
How do I remove the bottom arm to unclog it?
Based on my dishwasher which is a similar model, unscrew the cap on the support arm. Then lift off the lower wash arm. (Turn counterclockwise to loosen.)
There are several models of the KUDS02FRSS and the parts diagrams and manuals are available from http://www.managemylife.com/mmh/owner_manuals/search?query=KitchenAid+KUDS02FRSS .
I hope this helps.
(we recently had to take off the the lower wash arm to replace a seal; by the time the part arrived, we forget how tight the cap was on originally. Pay close attention to the wash arm ease of rotation when you disassemble it. We overtightened it and the arm refused to spin until we corrected the mistake.)
Feb 26, 2011 | KitchenAid 24 in. KUDS02FRSS Stainless...
Detergent opener does not dispense detergent during wash cycle. ive tried washing 4 different times and detergent sits undissolved in dispensor. dispensor door does not pop open either when i open door...
Most KitchenAid dishwashers have an adjustable upper rack, since I do not have your model number I cannot advise on specifics but if you move the upper rack to the higher position the dispenser will open a little further.
Also if you are not washing well on the upper rack you may have either a plugged spray arm or sump.
Look at the spray arms close, if the holes are plugged then it will not spray into the dispenser properly.
If you have a tall tub KitchenAid then the sump may need cleaned.
Here are instructions that might help.But not knowing your specific model these instructions may not apply
A plugged up sump can cause a multitude of problems in a dishwasher, it can make the dishwasher not clean as well as it should, make the cycle run longer, it can create noises and redeposit food.
To clean the sump follow the directions below.
- Remove the lower rack
- Remove the lower wash arm (1) by turning the nut (4) clockwise (right) lift the arm off, there is a bearing (3) (small thin plastic washer) under the arm, be sure not to loose it. Lift the tab on the back of the feed tube cap (2) and swing it to the right and lift up, this may need a bit of pressure to release it.
- Remove the 4 screws (3) from the accumulator (1), lift off the accumulator. Remove 1 screw(7) from the cover (8) this is located down inside of the sump (4) on the left front side. Lift up and remove the cover (8), watch for glass and clean out all the debris from the sump and especially around the the area of the chopper and screen (6) which will be exposed with the cover (8) off. If the screen is blocked with debris that usually means you need a new chopper. it may be broken or loose and not doing its job.
Once clean reassemble and enjoy a dishwasher that cleans the dishes again.
Feb 14, 2011 | KitchenAid Dishwashers
KitchenAid Dishwasher (model KUDS01IJBL) has black gunk inside
That black gunk is caused by soap deposits and food particles that do not get washed down the drain. This all collects in the area around the door gasket and front of the wash tub and forms a sticky black sludge. You need to periodically clean the interior of the dishwasher out with a non-abrasive cleaner with some bleach in it to kill bacteria. You should also check the wash pump sump (located under the lower spray arm) to make sure it is not being clogged with food and debris. In order to access the pump sump, you will need to perform the following:
1. Remove the lower wash rack and lower spray arm.
2. Remove the upper wash rack and spray arm.
3. Locate the screws holding in the upper spray feed tube. Remove the screws to the feed tube and turn the whole assembly 1/4 turn to the right (CW direction). The entire assembly will unlock from the wash pump assembly and lift out.
4. Remove the strainer assembly (known as an accumulator) that covers the pump sump area.
Inspect the sump area for food particles and debris that may be contributing to the mess inside the wash tub. If you need some guidance, pcappliancerepair.com has some very helpful exploded view diagrams to assist you.
If you have any questions, or require further assistance, please let me know. I hope this is helpful to you.
Aug 17, 2009 | Dishwashers
KitchenAid dishwasher Lower wash arm
if its a newer model the sprayer sits on top of a plastic screw that just needs to be tightned
Feb 04, 2009 | KitchenAid Dishwashers
Noisy Dishwasher
has there been any hard objects such as fruit seeds nuts egg shells ect. is it doing it in all the cycles
Mar 28, 2008 | Dishwashers
Loud Knocking/Ticking Sound During Cycle
have you lowered the top basket into the lower position? if so the spray arm will knock the cutlery /plates. it sounds as though it is a spray arm problem. remove them and put it in wash to see if the noise goes. if not there may be an obstruction in the wash pump, this is a stripdown job then.
Jun 04, 2007 | KitchenAid KUDC02IRB Dishwasher
Dishwashers Logo
594 people viewed this question
Top Dishwashers Experts
