Question about Ricoh Caplio R7 Digital Camera
Ricoh Caplio R7 error 00-00-00 30-01-23 lens won't close
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Jan 05, 2010
2 Suggested Answers
SOURCE:
  • 102366 Answers
SOURCE: caplio R7 error 30-01-23
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Feb 23, 2010
In my rich caplio r7 its upper shutter is jammed in inner side when i try to pull it,IT came back to its inner position it happens WHEN someone drop my camera ON THE FLOOR
Sorry can't help ,I contacted Ricoh and they were less than useful, so I gave up scrapped the camera ,got a new one which wasn't a Ricoh as the people who took them over have forgotten how to build cameras well.
Sorry again but good luck.
Jun 09, 2014 | Ricoh Caplio R7 Digital Camera
Hi, someone drop my Ricoh R7 camera in the floor and since then the lens can not be withdrawn. It make some noise but isn't moving and doesn't switch on.
Unfortunately, many cameras that fall prey to lens error problems can only be corrected by professional repair. But, here are some last resort troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try.
May 30, 2011 | Ricoh Caplio R7 Digital Camera
Caplio R7 Lens having black spots
Sounds like the spots are on your sensor. If on the lens, it would be too out of focus to matter.
Jun 09, 2010 | Ricoh Caplio R7 Digital Camera
Ricoh Caplio R7 focusing problem
Go into the menu and find "reset"...follow the on-screen instructions.
Feb 24, 2010 | Ricoh Caplio R7 Digital Camera
My Ricoh R7, the shutter is jammed and wont close or open, its stuck half way. I live near Glasgow. Know where I can get a repair done?
If you are sure that your battery if fully charged but still does not do any good, then do this little trick:
1. Hold the camera on your right hand with the lens facing the ground.
2. As you press the power on button, tap or hit the camera's base to your left palm. Do this several times.
Chances are, there could be a sand or granule of dust that got stuck on the sides of the lens, preventing it to retract properly.
Hope this helps.
Nov 03, 2009 | Ricoh Caplio R7 Digital Camera
Caplio R7 error 30-01-23
Jun 13, 2009 | Ricoh Caplio GX Digital Camera
Ricoh R7 Lens Jammed
you would love to see what was the truth as link following,
http://xiaolaba.wordpress.com/2009/04/25/camera-ricoh-caplio-r7-a-real-****-lens-error-00-00-00-30-02-23/
it was a **** design by RICOH, sent your message of compliant to them. you may get free service.
Jan 25, 2009 | Ricoh Caplio R7 Digital Camera
Camera lens won't close says error 00000
This is a known problem, they wont easily admit it but we had 2 R6's and an R7 with the exact same issue. If you look on ricoh site they had a firmware patch for the R6 to try and fix this issue but it dis not work.
Lady at ricoh UK admitted there is a design fault with the Ricoh R6 and R7 and she sent me an R8 which has a whole new redesigned mechanism.
Dont let them sell you useless kit, get a replacement free of charge or complain.
Jun 20, 2008 | Ricoh Caplio R7 Digital Camera
Ricoh camera malfunction
The problem eventually fixed itself somehow.
Mar 17, 2008 | Ricoh Cameras
Ricoh Caplio R7 Digital Camera Logo
945 people viewed this question
Top Ricoh Cameras Experts
Bill DeLisi
Bill DeLisi
mbutkus
Level 1 Expert
Ekse
Are you a Ricoh Camera Expert? Answer questions, earn points and help others
