Question about Pioneer PDP-6100HD 61 in. Plasma Television
Problem with audio and vidio
All cable connections ok ...hd power cord ok...cable box ok...blue explorer screen appears...loading data appears...able to change channels ...channel and discription of show appears at bottom of screen but no picture and no sound
    President:
  • 1,944 Answers
Is this a problem only with the cable box or also with oother sources as well?
Posted on Feb 03, 2008
How do i connect my cable box to my tv
Connect the coaxial "Cable In" cable to the "Cable In" port on the back of your TV cable receiver box. Make sure your receiver box is not plugged in yet. 2 Take the TV audio/visual cable, and connect the red, blue and green ends to the corresponding color "Cable Out" ports on the back of your cable receiver.3 Take the other ends and plug them in to the red, blue and green ports under "V1" on the back of your TV.4 Take the audio cord with the red and white ends, and connect them to the corresponding color ports of "Audio Out" on the back of your cable receiver; then, connect the other ends to the corresponding color "Audio In" ports on the back of your TV.5 Turn on the power of your TV cable receiver box first. Allow it to run through the boot sequence. When you see the time appear on the front of the cable box, you may turn on the television and check your signal.
  • Oct 13, 2011 | Televison & Video
    I have picture but no sound. We just had our surround sound system go out and are trying to run our tv on it's own internal speaker system. How do you hook it to our direct tv hd box
    Hi.
    You need to use audio cables. Connect two red and white audio cables from the output on the HD box to the relative input at the back of TV (nr.4 in picture below). The best way to connect the HD box is by using component cables, that are the red-green and blue trio of cables, plus a white and red audio cables.
    Here what you need:
    Three plus two:
    Component Video Cable
    Audio Red / White Cable
    or single set of five:
    Cables Unlimited - Video / audio cable
    Once you have the five cables, connect them to the output at the back of the Direct TV box, and then connect the other end of the cable to either group of connectors 6, or to one of the columns in connector 7. Do connection with box and TV power off. After re-applying power use the source-input selector on remote to select the source from Direct TV box.
    May 24, 2011 | Samsung HCM4215W 42" Rear Projection...
    IF I AM CONNECT THIS TV TO DVD PLAYER THEN THIS TIME ONLY VIDIO IS WIRKING OK BUT AUDIO IS NOT WORE.
    Please check your connections. It appears that your cables are not connected properly. Please remove all the cables and connect them again.
    May 18, 2011 | Audio Players & Recorders
    How to connect new HD cable box to receiver
    HI:
    You are using a new HD Cable box, that are using componet video cables for HD, Unfortunetly this receiver does not have componet inputs, so you will just have to run the audio from the televison directly to the receiver by connecting the video out and audio out from the television to the receiver's video Input one. This will require a normal RCA composite cables yellow,red,white. Connect one end of each of the cables to televisions output terminals, and the other to the input one on the receiver. Note: Your TV might have a seperate term called Monitor out, Connect the yellow here, and the red and white to audio out. You can do the same for the DVD but you have to use the same cables,Also the television will not display HD picture this way as this is not a HDTV Receiver. If you just want TV sound to the receiver then do not use the video(Yellow) cable just use the audio out terminals from the tv and connect to Input one on the receiver. you can do this with the cable box also but you have to use RCA type cables . If you want the full HD experience then a new up todate receiver is necessary.
    Dec 06, 2008 | Sony HT-DDW740 System
    Picture goes blank but audio on
    If you are using component cables to connect your HD box to TV. Make sure your connections are tight. You should make the colors match up. Green, Red, Blue. Check on both TV and HD box. Make sure HD pox is powered on. Make sure to select TV input to Component 1 or whichever you are using. If this doesn't work you may need to call and have COX refresh the HD box. This can be done over the phone. This will make sure you are receiving and sending the proper signal level. Good luck
    Oct 05, 2008 | Vizio L30WGU 30 in. HD-Ready LCD...
    HDTV-AT&T UVERSE
    First of all, is your blue "HD" light lit up on the front of your Uverse box?
    If yes, then you're in HD
    If No, you need to check your connections from Box to TV
    1.Those Red-Blue-Green cables are for video only, they don't carry sound and shouldn't be connected to audio outs. Audio needs a seperate cable. Make sure your Red isn't on the audio out which is also red. Make sure your blue and green aren't switched with each other either. Check that at both ends.
    2. Try an HDMI cable. It will carry audio and video together and it's one cord instead of 5.
    3. What brand/model of TV is it? Is it an older projection TV? The HD tuner might be shot. The individual color tubes commonly fail after a few years.
    4. Are you selecting 720p or 1080i from your TV's menu or from the Uverse menu? You'll need to set it through the Uverse box, not the TV.
    5.Follow -Menu -Settings -Aspect Ratio to change to 720 or 1080. This should start an autotest which will scramble your picture for about 5 seconds, then bring you back to a menu asking you to keep settings or revert back settings. If you never see that question pop up, then your TV isn't supporting the HD, and you settings will be rolled back automatically. If the question does pop up and you can read it, select "keep settings" and press OK. Your blue HD light should come on the front of the box now.
    Mar 01, 2008 | Philips 55PW9363 55" Rear Projection...
    Pdp6100hd tv audio visual not working
    unplug the cable box for 1 minute then plug back in and let it reboot.
    Feb 03, 2008 | Televison & Video
    Connecting bose 321 system to lg hd flat screen,bose receiver plays fm am ok threw speakers.tv will not play threw bose speakers.bose dvd plays sound ,but no picture
    You will need a Component Video Cable
    Connect the Red Green and Blue Connections from the TV to the Bose.
    if your audio is coming from the TV, also connect stereo audio from the TV's audio out to the "TV" input on the bose.
    if you want to hook up other devices (VCR, BluRay, etc) the video will go directly to the TV and audio will go directly to the Bose
    Jan 18, 2008 | Bose Cinemate Digital Home Theater System...
    Screen flicker when watching 1080i
    Component video has a max resolution of 720p. in order to use 1080i or p you have to use hdmi or dvi connections. That is why you get the flicker.
    Dec 08, 2007 | Onkyo TX-SR304 Receiver
    Pioneer PDP-6100HD 61 in. Plasma Television Logo
    97 people viewed this question
    Top Pioneer Televison & Video Experts
    Jaime Hernandez
    Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
