Question about Candy CNW136 Front Load Washer/Dryer
Renew washing machine front door seal
I need to fit a new door seal to my washer/drier
    Master:
    Sergeant:
  • 440 Answers
Ye sthey sell those local maytag store ok slips in and round
Posted on Feb 03, 2008
I would like to get some information on how to replace the door seal of a Miele Metor 4000?
Depends if washer drier or just washer...The Door boot seal is secured with two rings one on the outside of machine case the other on the inside...The tricky part is fitting the inner ring in some cases the front of the machine can be removed,greatly simplifing the job if you look on utube you will see step to step how to fit a door boot seal this may help you decide if you need an engineer to do job..Happy New year from Scotland...
Jan 01, 2011 | Miele W 4800 Front Load Washer
Whirlpool Front Loading Duet Washing Machine Plastic at drum front shredding
i think your talking about the rubber door seal????
you can change this yourself,,,under the seal on the case is a wire spring unhook it and the door seal will fold inside the washer,,,on the inner drum you will find the other wire spring undo this as well and pull the old door seal out through the hole in the door,,,the new seal is fitted to the iner drun first so you need to turn the new seal inside out to fit it,,,push the seal into the washer and fit the inner wire first then unfold the seal and fit it over the outer door so you can fit the wire spring,,,
easy after you have fitted a fuw 100?
Aug 21, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
Fitting a door seal to a Zanussi ZWD 1270SA washing/drier
Follow these steps to replace your door seal:
For all Free appliance repair videos visit our VIDEO TUTORIALS
Disconnect all power to the machine first!!
1 Locate the outer clamp band securing the seal to the door rim on the washing machine and examine it carefully for holes or tears. Many can be prised off with a flat-bladed screwdriver they have a spring system holding them, but some have a tensioning arrangement that has to be loosened.
2 After removing the outer clamp band, locate the inner one securing the seal to the drum and establish how this is secured. It may be necessary to loosen a clip, or you may be able to prise the band off with a flat-bladed screwdriver. Some are like very large Jubilee clips that you have to undo usually from the top.
3 Once the clamp bands have been removed, use both hands to pull the seal away from the inner drum rim. Some machines have a water spout holes that will have to be lined up. Others have a drain holes.
4 Rubbing a drop of washing up liquid into the groove on the door seal/gasket that locates on the drum makes fitting the new seal easier.
5 the new washing machine door seal should be fitted by locating the drain holes at the bottom of the seal first then push it on with both hands working opposite directions towards the top. This is quite hard if you have never done it before.
6 refit the inner band remembering this must be tensioned correctly for it to be water tight.
7 now fit the outer band and the test the machine for any leaks,
All washing machine spares featured in this article are available at apart4u with more video help in our tutorial section.
Information provided is a guide only. aPart4u accepts no liability for any problems occurring whilst attempting any advice shown. If in any doubt about fixing your appliance, always contact a qualified repairer.
Dec 28, 2009 | Zanussi ZWF1440 Front Load Washer
Fit a new door hinge
Remove the wire clamp securing rubber seal to front of washer, pull seal of front of washer, this will give you clear access to tjhe door hinge, ondo the 2 screws securing the door hinge, remove door ,and seperate the 2 door halves by removing the screws securing it together
Replace with new hinge, fit back in reverse order.
Please rate my solution.
Thanks.
Nov 12, 2009 | Creda W120VW Front Load Washer
easy fix love what you need to do is un-plug the washer now tak the 2screws from the back of the washer that holds the top(lid) in place now open the door and around the edge of the door seal there will be a spring wire pull this out so you can unattach the door seal totally from the washer front the seal will still be attached to the inner drum though now stand up and look down through the top of the washer down to the front were your door seal is still attached to the washer there will be another clamp with a screw on it undue the screw but you dont have to undue it totally though pull the clamp out through the front through the door seal now will come off the washer now just do these instructions backwards to re-fit the new door seal let me know how you go on or if you get into trouble doing the job peter
Jun 10, 2008 | Hotpoint Aquarius WD640 Front Load...
FITTING NEW DOOR SEAL ON WHIRLPOOL AWM5125
this is a complex repair and the machine complet frount has to be removed
May 10, 2008 | Whirlpool AWZ410 Front Load Washer/Dryer
Usually it will be just be reversing the procedure of removing the old seal. At any rate, the door will need to be disassembled.
Mar 29, 2008 | Whirlpool AWM5125/1 Front Load Washer
Fitting a new door seal
unplug machine. Pull off retainer clip from the front , with both hands inside push up the seal untill its free. Then with the new seal apply washing up liquid to the gap on the seal. And fit this is fiddly. Then pull the spring you removed to loosen abit and with a screw driver to keep it in place throught the door lock thats why youve unpluged it. strech the spring around. the ease on the front part of the seal and replace the clip. put on a wool wash to check for leaks. appliance doctor
Feb 05, 2007 | Zanussi IZ161S Front Load Washer
Candy CNW136 Front Load Washer/Dryer Logo
119 people viewed this question
Top Candy Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Candy Washing Machine Expert? Answer questions, earn points and help others
