Question about Thermador SGS36GS Gas Cooktop
Burner with intermittent feature won't light once hot; spart OK - - no gas.
Burner lights fine when cold.  But once it's hot and is turned off, it sparks but no gas and no light.  This model has the intermittent feature (ultra low).  Gas range top.
  • mdpaul Oct 19, 2008
    Checked your theory, but not in this case.  Burner started working again for about a month but now is doing the same thing again.  Any more suggestions?  Thanks
    Novelist:
  • 130 Answers
Mdpaul, sounds to me like 1 of the burner switches for the ignition is sticking. There is a small area where the switches turn to that shuts down the ignition. If the switch has failed from heat or is out of position, this can cause this issue. The switch is designed so when you turn the knob it closes the contact. The switch has to be locked into postion on this model. There is a push fit type retainer that locks this down. Pull the knobs off and turn with a pair of plyers to see if one is moving around. If so then with a deep socket, see if you can tighten the retainer by pushing down on it. Hope this helps.
Posted on Feb 03, 2008
My left front burner was turned off for almost half hour but remained hot. the hot surface light was still lit. I had to throw my main breaker to turn it off. What could be my problem
Sounds like the thermostat on that burner gas gone. When you switched the breaker back on, did the burner get warm after being cold? If so, you need a new controller. They are easy to change if you can get to the back of the unit. Make sure you turn off the breaker and physically remove the plug.
Nov 24, 2013 | Whirlpool RCC3024 Electric Cooktop
No matter which burner I try to turn on, the same one tries to light - I thought the gas was turned off, but the fact that just the one burner tries to turn on makes me nervous. thanks
Hello- On modern gas cooktops and ranges when you turn on one burner ALL the burners will click, spark, until that burner is lit. I would ask if the other burners are lighting ok or do you have to use a match? Do you smell gas when all the burners are OFF? Feel free to reply and if you could provide the Model number of the unit that would be helpful. Best regards.
Sep 27, 2010 | GE Cooktops
When I turn any burner on, the ignitors work fine but it takes a very long time for the burners to ignite. Problem is worse the longer the top has been turned off. Once gas gets to the ignitor, it lights...
It seems like one of your burners is clogged. You made need to use some oen cleaner and a small toothbrush to clean the burner. If the problem occurs with all the burners, then you have a blockage in the gas supply line. you willm have to take it apart at the stove and clear it out. Check the main gas connection and at the burner(s) to spot the debris clogging. Make sure to shut your gas valve off behind the stove. Good luck... hope this helps.
Jul 15, 2010 | Bosch 30 in. NGP 732 / 736 Gas Cooktop
Piezo goes off every 10 seconds.
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Apr 10, 2010 | Whirlpool SC3017RQ 30 in. Gas Cooktop
Burner won't light
hi gud day,i think the sensor is we have problem is hard to repair in ur own,try to call the person have expireince for repair that unit, or ur igniter ligther have damage like small broken if u hear have click is ok but much better to check the igniter coz the broken igniter is not directly spark in the burner that why is not light.to check if remove the burner base cover then see if the igniter like a small niddle color white,turn the knob to click the igniter then see it wer the spark directly if u not see it means have a broken igniter.
tns gerbee
May 26, 2009 | Amana AKS3040 Gas Cooktop
Burner on Thermador stove top does not light
Switch for burner 4 is not working properly - could have a bad contact resulting in just one spark and nothing more.
May 03, 2017 | Thermador SGS36GS Gas Cooktop
Viking stove ignitor
the continues to click problem, for e it was only when my smaller burner was lit. theo others were ok. When I took the burner apart it was very dirty. I cleaned it up (a wire brush in my drill press) and it works fine now. I think it was just bad electrical conduction.
Aug 20, 2008 | Viking 31 in. VGSU101 Gas Cooktop
Intermittent fault
i wold pull the orfice out of the burner and check for a partial obstruction hold it up to the light look down in the burner tube
Jan 25, 2008 | Bosch 30 in. NGP 732 / 736 Gas Cooktop
Baumatic B40 Gas Hob : Gas not staying on.
we have the same problem... try removing the knob, ours works fine without the knobs ????
Dec 19, 2007 | Baumatic 24 in. B40 Gas Cooktop
Burner won't light
Clean the gas nozzle w/small wire are located at the back of the gas cook top /shut off the gas clean small gas nozzle clog / w moisture /rust dust and any foreing material.
Dec 19, 2007 | Thermador SGS36GS Gas Cooktop
Thermador SGS36GS Gas Cooktop Logo
127 people viewed this question
Top Thermador Cooktops Experts
Dan Webster
Dan Webster
Justin Duby
Justin Duby
jasbo
jasbo
Are you a Thermador Cooktop Expert? Answer questions, earn points and help others
