Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Glass shelf covers
How are the glass covers removed for cleaning or replacement?
Beatrice Tobin
    Master:
    Sergeant:
  • 440 Answers
Up and out did u look under it there not screwed in are they
Posted on Feb 03, 2008
6ya staff
SOURCE:
How do I change the bulb inside the cooker of the B5741 cooker
Oven Lighting
Warning: There is a danger of electric shock! Prior to changing
the oven light bulb:
  • Switch off the oven!
  • Disconnect from the electricity supply.
Place a cloth on the oven floor to protect the oven light and glass cover.
Replacing the oven light bulb/cleaning the glass cover
  1. Remove the glass cover by turning it anticlockwise and then clean it.
  2. If necessary:
Replace bulb with a 40 watt, 230 V, 300 °C heat-resistant
oven light bulb.
3. Refit the glass cover.
Dado
Apr 15, 2015 | AEG Ovens
HOW TO REPLACE THE LIGHT BULB IN MY OVEN
Oven Lighting
Warning: Risk of electric shock! Prior to changing the oven light bulb:
- Switch off the oven!
- Disconnect from the electricity supply.
Changing the oven light bulb/cleaning the glass cover
1.Remove the glass cover by turning it anti-clockwise and then clean it.
2.If necessary: replace with 25 watt, 230 V, 300 °C heat-resistant oven lighting.
3.Refit the glass cover.
24472822-skr3uzd4ii43xzwyhmpsswym-3-0.jpg Dado
May 21, 2014 | Electrolux EOB5665G Ultrafan Electric...
Need to replace sunroof..
you need to replace glass or is it leaking if leaking then you have to remove upper seat belt covers pop off remove bolt 14mm and the trims on upper pillars pry off carefully held in by clips remove covers on interior light at front where sunroof switches are there are screws by bulbs disconnect connector remove center light cover and screws disconnect connector with clean hands remove rbber trim around sunroof opening and plastic cover on each side of sunroof glass held on with plastic screw clips then remove four 10mm nuts lift sunroof glass out of car remove cover and screws from rearview mirror all plastic trims around headliner move pass seat forward most and flip back rest all way down roll pass window fully down then slide headliner out of car now you can remove electrical connectors and remove water flow hoses from sunroof unit remove 8 12mm nuts holding frame to roof remove through door you will see the track sunroof slides on remove nuts along problem is silicone between track and frame is deteriorated lift track clean replace silicone reattach frame to roof dont put trims or liner in till test connect switches and glass to frame make sure sunroof works and closes fully then go through car wash to see if leak is fixed
Jan 13, 2011 | 2001 Subaru Legacy
LHow to clean under side of glass plater
note where the dirt is located,unplug all wires from back, remove top hinged cover, undo 2 screws at the top, remove cover plate by gently tipping toward top, slide glass with plastic sides up and out, clean with approved cleaner, reverse to reinstall glass (plug in power cord prior to replacing top cover plate to check for any missed fingerprints or dirt on underside of glass), once your happy with cleaning complete the reassembally.
Oct 06, 2010 | Canon CanoScan D1230U Flatbed Scanner
I need to replace the light bulb in my whirlpool self-cleaning oven but I can not remove the glass cover. How do I remove it?
hello,
Here is a solution to go about the glass bellow
Removing your microwave door allows you to quickly clean out any accumulated food or grease. This also makes it easy to get to all the crumbs and debris around the door hinges. While you have the door off its hinges, examine the plastic panel and glass window for signs of damage. Make sure you install a replacement door that is designed for your brand of microwave to ensure that it will fit correctly.
  • Remove the power cord from the electrical outlet and move your microwave onto a workbench or sturdy table. For cabinet-mounted microwaves, pry off the decorative grills or front panels and remove the mounting screws. You should then be able to slide the microwave out of its mounting bracket.
  • 2 Open the microwave door and remove the glass tray. Use a flathead screwdriver or putty knife to pry off the plastic cover on the inside of the door. Work around the edge of the glass until the cover slips free.
  • 3 Remove the door by pulling the mounting pins out of the hinges at the top and bottom. You may need an assistant to steady the door so you can have both hands free to work with the pins.
  • hope this solution help?
    Thanks for visiting fixya.
    Oct 03, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
    How do I replace the back window?
    Remove the black vinyl trim from the edge of the glass. Remove broken glass & urethane adhesive from the metal pinchweld leaving a thin layer (approx 1/16") of urethane for new new urethane to adhere to. Vacuum broken glass. Prime nicks to the metal to protect from rusting (also insuring a good surface to bond to). Attach vinyl reveal molding to glass (unless it's a "T" shaped push in type - it would install after the glass is set). Clean and prime the replacement glass. Apply new urethane adhesive. Set glass in place.Slide the metal joint cover in place on the molding (at bottom in the center). Clean outer surface of glass. Allow for safe drive away as noted by urethane manufacturer.
    Sep 25, 2009 | 1995 Oldsmobile Cutlass Ciera
    Can't clean the inside of the glass door--the screen blocks it
    Have to replace the door. You probably removed the protective plastic cover inside the unit intended to keep material from passing through the screen into the area where the glass is located. That was my problem. I thought the plastic was shipping material. My Bad! No way to clean the glass from the inside because they "never imagined" someone would remove the plastic cover.
    Nov 10, 2008 | GE XL1800 1100 Watts Microwave Oven
    Glass cleaning
    first remove scanner cover look at how it is connected in hiddle is raised piece dont rember if you push towards front or back of printer its been awile scince iv had to do this one on left side of scanner is two screws screws on right are under control panel to remove this carefully take off cover over numbers by putting small screwdriver at bottem of lcd and lift up on cover over buttens after this is up find small slot on very front middle where this cover was if you press down carefully and slide control panel forword to release do slowly two ribben cables attach it remove carefully then remove all screws with T-10 driver glass and outer plastic should lift do not damage ribben cables after glass clean put cables back thru slot carefully replace screws reattach control panel cables look at how it slides back on
    Mar 11, 2008 | HP PSC 2410 All-In-One InkJet Printer
    Ricoh ft 3213 printing problem
    Is it only when you use the top feeder? Check by placing an original on the glass and copying if the same fault then there are three possibilities
    1. Optics Dirty (Dust on the copying mirrors) Remove glass and clean the mirrors on the scan unit also remove the lens cover and clean the mirrors under there replace lens cover clean glass and refit. (Do Not remove any mirrors you can clean them in there place and use a glass cleaning solution)
    2. Toner Waste and drum cleaning unit full. Open front cover and split machine as to remove jam not touching the drum (Large Cylinder ) check there is no banding on there. IF so to the left of drum there is a unit that contains the cleaning blade and fills with waste toner remove vacuum out waste toner check that cleaning blade ok and reinstall. Close and check machine if ok then great if not could be fault number 3 or that the cleaning blade is worn and need replacing.
    3. The fuser section (Heat section) While the machine is split look at the bottom left you will see a Orange unit this is the fuser section that houses the heat roller which welds the toner to the page. Check that the top roller is OK that there is no toner stuck on it and the Teflon coating is even. If not then the fuser will need replacing and as you said that you are missing text the most likely faults are going to be the fuser or the drum or the drum cleaning blade.
    I hope this helps you
    Thanks J
    Jan 18, 2008 | Office Equipment & Supplies
    Oven
    Pry back the bulb glass cover wire spring and remove glass cover. Use heavy rubber gloves or a plastic bottle opener(piece of serrated soft plastic/rubber) and unscrew counterclockwise.
    Mar 05, 2007 | Whirlpool GBS277PR Electric Single Oven
    Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
    102 people viewed this question
    Top Kenmore Refrigerators Experts
    Jimmy
    geob91
    John Tripp
    John Tripp
    Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
