Question about Yamaha RX-V661 Receiver
TV on But no Sound
After power surge today I see TV but no sound, I see DVD but hear TV - CD and Radio work fine - what do I do to fix this?
  • barnaba Feb 03, 2008
    I dont understand - can you use non techical terms to walk me thru this?
    ok - \ when I went to the menu is read
    a- DVD
    b- DVD
    c DTV/CBL
    d. - fm/stereo
    at this point I see TV when I press Scene 3 button, but no audio- I press Scene 1 and saw DVD but heard TV
    I played around with it and changed it to
    a- DVT/CBL
    b-DVD left this alone
    c DVD
    Now I see TV and Hear it on scene 1 - but when I press scene 3 I see DVD but cant hear it - Music Scene 4 is ok
    Now my logitech remote is freaking out - how can this be?
    Sergeant:
  • 395 Answers
Go into the yamaha's menu and re-assign the inptus in the input assign menu. if the audio from the TV is comming from a sat box follow the audio cable to the receiver. there is a number on the input (like number 3 ect...) then assign that number input the name TV.
Posted on Feb 03, 2008
    Master:
    Sergeant:
  • 440 Answers
Cheak syterio outs puts and dvd players settinsg to pcm output ect reset them up
  • nick helpap
    nick helpap Feb 03, 2008
    yes make sure sound from dvd is going to tv direct ok is it or just picture cable from dvd to tv then tv master sound out to sterio also in dvd menu u may wann cheak out audio setting set to pcm corect if uuse analog red white cables ok if not doly digital thats optical cable or coxaial cable
  • nick helpap
    go back to dvd now and set its output mode to on audio to dobly digital not pcm ok
Sound doesn't work on television Worked fine yesterday but it isn't working today. I know the power went out briefly(few seconds) today.
Check a different input and all the connections to the TV to see if they are secure. After doing so and you still are getting no audio from all inputs then it means the audio processor failed. It was most likely caused by a power surge when the power went back on. This is fixed by replacing the main board. It is usually called a BU or AU board on Sony LCDs. Can be prevented in the future with a good surge protector or clean power surge filter.
Oct 07, 2009 | Sony Bravia KDL46V4000 46 in. LCD TV
Sound doesn't work on television. Worked fine yesterday and doesn't work today. I can hear sound from the cable box going to my surround sound, however nothing to the television. I know the power went...
Sounds like there was a power surge that caused the audio processor in the TV to go out. This is fixed by replacing the main board.
The power supply board in the TV should also be checked as that could have been damaged as well. These are usually the first to go out from a power surge. Get a good surge protector to help prevent this in the future.
Oct 07, 2009 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
The sound stopped working on my koss KS2503. Yesterday everything worked perfectly fine. Today there is no sound. Everything else seems to work. I checked all the connections and have had no success. Is...
unplugg your tuner from the AC wall outlet then check the setting on the tuner do not try to watch and listen to the tv only try to listen to the radio or a CD and select the right option on the tuner to do so. If you have sound on any of the functions....radio or CD/MP3 then the problem lies on the setting not correct for the TV/VCR/DVD mode.
Sep 12, 2009 | Koss KS2503 System
Head unit radio works fine but static when i try to play cd's
i had quality auto sound install it for me, and they added a pulse switch. my dvd works while i drive the car.
Jun 30, 2009 | Jensen VM9510 Car DVD Player
Onkyo TX-SR705 - No Audio - Flashing HDMI
The posabilities is power amplifier on your reciever is bad,
replays reciever or repair it.More likely this is IC amplifier located on the main board of the reciever
Apr 15, 2009 | Onkyo TX-SR705 Receiver
Blue Screen in TV Mode
I have an Audiovox FPE1506DV with the same problem: it plays DVDs okay, but when I try to watch TV, it only shows a blue screen, but sometimes you can hear the sound. Cable input is fine.
When going through the Menu option in TV mode, the "Display" option is disabled; you cannot select it with the remote.
SOLUTION: I unplugged the device for about 5 minutes, plugged it back in, and it has been working fine ever since. It's a very strange problem, but rebooting by UNPLUGGING (not just powering down) seems to have fixed it.
Dec 09, 2008 | Audiovox FPE1506DV 15 in. LCD TV/DVD Combo
Remote will not work dvd
HOW TO CHECK THE REMOTE WITH AN AM RADIO .
!. SWITCH ON THE RADIO AND SELECT MW BAND ON THE RADIO.
2.PRESS ANY BUTTON ON THE REMOTE CONTROL WITH BATTERY INSIDE.
NOW YOU CAN HEAR A PULSING SOUND FROM THE RADIO. THAT MEANS YOUR REMOTE UNIT IS WORKING FINE.
SO THAT YOU CAN CONFIRM THAT THE SENSOR IN THE DVD PLAYER IS NOT WORKING.
YOU HAVE TO CHECK THE VOLTAGE OF THE SENSOR /REPLACE IT IF YOU ARE A TECHNICALY QUALIFIED PERSON OTHERWISE TAKE IT TO THE NEAREST SERVICE CENTER.
Dec 31, 2007 | Panasonic DMRES30V DVD Recorder/VCR Combo
JVC AV-27F476 channeling the radio!
Please try to change the vco adjustment position or try to do fine tuning with the service menu.
Dec 28, 2007 | JVC AV27F476 27" TV
Lost sound on DVD
I have a CH-DVD 300--not sure how different it is from the 200, but I have the same problem. Putting in an audio CD seems to do the trick, and is less hassle than unplugging (which also works for me).
May 20, 2007 | Cyberhome CH-DVD 300 DVD Player
No picture when I turn the tv on only sound
TRY CALLING BEST BUY'S GEEK SQUAD TO COME FOR A IN-HOME REPAIR SERVICE CALL AND THEY WILL FIX YOUR PROBLEM!
Dec 14, 2006 | Sharp 27DV-S100 27 in. TV/VCR/DVD Combo
Yamaha RX-V661 Receiver Logo
100 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
