Question about Vtech 5.8GHz Analog Cordless Phone
Charge/in use light
I bought a new vtech 5.8 portable phone. question ? after charging the battery for over 16 hrs is the red light on the telephone base suppose to go out or stay a constant red? the red light on my new phone stays red all the time, is this normal ??
    Scholar:
  • 103 Answers
Typically the charge light will stay on as long as the phone is on the charger. After 16hrs, the battery should be fully charged. Leaving it on the charger constantly can actually overcharge the battery, shorening it's life. The best thing to do is use it until it tells you the battery is getting low, then charge it uninterrupted for about 8-12 hrs. Of course, that's ideal and can't always be done, but the more you can do that, the better.
Hope that helps, and please rate my answer, good OR bad.
Posted on Feb 04, 2008
My battery started to go dead and i have it on the charger but it has been on there for a while and it still says lowbattery, how do i get that display to come off?
Posted on Mar 27, 2009
Bought a used vtech 5.8 phone, charged the battery and now see message "not registered. I can not make calls... how do I register it?
I believe it is telling you it is not registered with the Base Unit. You did get the Base Unit with it didn't you, otherwise you have a paperweight.
If you do have a set then this is the answer
Tip 1 of 1
Step 1: Place the handset in the base or charger. If PRESS FIND HS 4 SEC ON BASE does not appear on the screen after a few seconds, lift up handset and recradle it in the base or charger.
Step 2: On the telephone base, press and hold FIND HANDSET for approximately four seconds. Release FIND HANDSET once the IN USE light comes on.
After a while, the handset will emit a series of tones, and the newly registered handset will be assigned the lowest extension number not previously assigned to another system handset when successfully registered. Repeat Steps 1 and 2 if the handset does not successfully register to the telephone base within two minutes.
https://vt.vtp-media.com/ecp/documents/product_Product/67/UserManual/1647/ia5874_manual_bkm.pdf
Search Results
VTech 5.8GHz Cordless Home Telephones & Handsets ' eBay
https://www.ebay.ca > ... > VTech 5.8GHz Cordless Home Telephones & Handsets Results 1 - 25 of 151 - This is a Vtech 5.8 cordless phone digital answering machine base with time stamp & a handset that needs a new battery. It came from an ...
Technical Product Support ' VTech® Cordless Phones
https://www.vtechphones.com/support/technical-support Stay up-to-date on new VTech products, emerging technology and special offers. ... My VTech DS6722-3 Cordless Phone rings once and then disconnects. Why ...
Vtech 5.8 Phone Instructions ' Techwalla.com
https://www.techwalla.com/articles/vtech-58-phone-instructions Mar 31, 2015 - The Vtech 5.8 is a cordless phone that allows you to add additional handsets to your main phone so that you can have quick access to phones ...
[PDF]User's manual - VTech Canada
www.vtechcanada.com/support_docs/vtt/CS/CS5111-x_en_cib.pdf everything new at VTech, visit our website at www.vtechphones.com. ..... Once you have initiated your call by dialing the phone number in pulse (rotary), press.
[PDF]User's Manual
https://vt.vtp-media.com/ecp/documents/product.../67/.../ia5874_manual_bkm.pdf and operate your new VTech phone . Please take the ... Enhanced 5.8GHz Technology - Dual band transmission combines the best of 5 .8GHz and 900MHz ...
Video as well in link
vtech 5 8 phone Google Search
Jul 17, 2017 | Vtech Lands Phones
Why do my VTech phones says outer range or no base on both of my phones
Out of range OR No power at base is shown in the handset ...
www.vtechphones.com/support/.../353
VTech Communications Inc.Out of range OR No power at base is shown in the handset display window. Why don't ... Tip 1 of 5. Confirm proper installation of the telephone base and charger power adapters, and handset battery. You should only use the VTech power adapters provided with your telephone. ... Next Tip This solved my problem. Tip 2 of 5.
FAQs - VTech Communications
www.vtechphones.com/.../frequently-asked-...
VTech Communications Inc.Have a question about VTech cordless phones? Visit our ... How do I find my model number ... My battery pack does not last very long between charges.
VTech CS6429-4 DECT 6.0 Expandable Cordless Phone ...
Jan 08, 2016 | Vtech Lands Phones
Brand new, never used. Plug into wall to charge and just get flashing red light. After 16 hrs on charge, still flashing red and when turn on, screen blinks then shuts down.
check that you have the battery in the correct way
if it has batteries like AA , AAA or what ever the negative terminal of the battery goes against the coil spring so if you have them all facing the same way, that may be why they are not charging
the screen shutting down at this stage would be cause the batteries are flat
of course you could always bet new fully charged rechargeable batteries and put them in correctly to see if the rest works
Apr 30, 2017 | Sylvania SDVD7015 7 in Portable DVD Player
Hallo aggelos here i have bought a hi phone j8 dual sim 3,5 screen and i put the first battery about 16 hours and the charger had a red light which never turned to green how many hours have i to charge it?...
The chinese Clone phones have very little in the way of letting you know they are charged. A regular battery will charge fully after 5-6 hours of AC mains plug time.
May 04, 2011 | Cell Phones
I've been receiving this error message, "out of range or no pwr at base" on my vtech CS6329-3 for the last 4 days. Help!!! I bought the cordless phones thru my Airmiles program in Oct...
The phone is not charging or the batteries are bad. You will need to get another set of batteries for the cordless phone. Call the customer service desk and tell them that they need to send you a repalcement phone. The phone is not properly charging.
I’m happy to help further over the phone at https://www.6ya.com/expert/ronald_e152e07e272e4f27
Nov 26, 2010 | Cell Phones
3month old battery does not charge full even after ten /more hrs.
i could charge to full by usv port in 16 hrs. now i do not let discharge more than 20% or chage every 10hrs.
ravi shanker malviya
Jan 18, 2009 | Sony Ericsson P990i Cellular Phone
Latitude L400 new battery not working?
u should charge new batt for about 6 hrs and then 2 to 3 hrs
Dec 20, 2008 | Dell Latitude L400 Notebook
I just bought a new Vtech cordless phone, 5.8GHz, model CS5111, hooked up the new battery and the base and have been charging it now for Twenty-Two (22) hours and the red charge light is still on!!! The...
The red "charge" light comes on to indicate that the handset is inserted properly into the base. This is it's normal function. No further action is nessesary. :)
Nov 23, 2008 | Cell Phones
Battery
they say 6-8hrs if its brand new...but i always do it for 24 hrs so the battery will have the longest life possible and you should have years of reliable service from that Phone battery.
Sep 30, 2008 | Uniden Cordless Phone
VTECH VT9121
voice message light keeps blinking
Aug 25, 2008 | Vtech 9009111 Cordless Phone
Vtech 5.8GHz Analog Cordless Phone Logo
1,102 people viewed this question
Top Vtech Lands Phones Experts
David Burbee
David Burbee
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
