Question about Dryers
Amana LEA60AW dryer problem??
Hi, I have this dryer, and I can hear the timer running, but the lower part will not start. It was drying this morning, but then just stopped. Now it will not start the drying part, except you can hear the timer run.
This happened before and then just started working again.
  • Anonymous Nov 17, 2008
    my dryer justed stopped working also. I can hear the timer ticking, but the motor will not engage.
    I have recently replaced the thermostat,
  • 130 Answers
Check the door switch to see if it is engaging. This will shut down the motor. I usually do this with a plastic ink pen to see if I hear a clicking.
Posted on Feb 03, 2008
Amana dryer lea60aw.when dryer is plugged in and door open, timer is ticking and recently replaced heating element is giving off heat-does the timer need to be replaced? or is it a thermoststat/ etc.?
It should not be on sounds to me like the cent switch inthe motor needs replacement. Common on amana dryer motors, not too hard to fix. See if it slides easy by hand and oil it cleaning out any lint that may have accumulated in the swtich. The job of the switch is to power on the heating element ONLY when the motor gets up to speed and centrifugal force slides out wrights on the switch allowing for power to go to the heater element . Switch stuck most likely, let me know.
Jan 11, 2017 | Amana Dryers
Dryer has power to timer, but won't start...I have an Amana electric dryer that allows me to set the timer and I can hear it running, but when I push in the the timer knob to start the dryer (drum
The fuse is mounted on the heater element. When it blows nothing in the heater or motor circuit works but the power to the timer is not interrupted therefore you can hear. Service manual
Feb 11, 2013 | Amana Dryers
Replaced the thermostat and high limit regulator on my amana comercial dryer lea60aw but forgot to tag wires, starting from the thermostat on the blower, i'm not sure where the wires go to, i have
if i were there i could tell you.just think about it .the wires have to make a path all the way through the should have a wiring diagram in the control panel that will help you trace the path.hope this helps.
Dec 04, 2017 | Amana Dryers
The timer keeps readjusting while drying clothes, will say there is 45 minutes left and clothes are perfectly dry, this could be a fire hazard if left unattended.
you will need to clean the vent tube/internal duct work:
The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature then the thermostat tells the timer to begin advancing. The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
if the vent/duct work is clogged then the
dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry.
I hope this helps here is a website on how to remove cabinet:
Oct 24, 2010 | Amana NED7200TW Electric Dryer
Amana Dryer model # LEA60AW. Dryer runs but no heat.
check the heating element and the high limit fuse
Jul 10, 2009 | Amana ALE643RB Electric Dryer
Maytag model# LDE482 electric dryer won't blow hot air
Either the control panel is defective or the dryer heating element is defective.
Jun 28, 2017 | Maytag Dryers
Your heating element is dying. A new element runs 'bout $40. It'san easy fix. Couple screws .
Mar 05, 2009 | Amana ALE643RB Electric Dryer
Dryer will run for about 20 minutes then it cuts off.
Are you able to restart the Amana dryer right back up when it shuts down? If you can, there is a short issue. If you have to wait a few minutes and you might even hear a faint click, then it will start, your motor needs replaced.....If Ic an help further, I am here.....
Waiting to hear from you,
Eric Campion
Feb 14, 2009 | Amana DLE330RAW Electric Dryer
Dryers Logo
295 people viewed this question
Top Dryers Experts
