Question about LG 42PC3D 42 in. Plasma Television
REMOTE CONTROL DOES NOT WORK
REMOTE DOES NOT WORK! BATTERIES ARE GOOD.
TV WORKS FINE WITH TV CONTROLS.
Unplug the TV for 30 minutes. Then plug & unplug 3 or 4 times quickly. After the last plug in the remote should work. We had the same problem and that fixed it.
Posted on Feb 26, 2008
  • jnkyrd Feb 26, 2008
    Unplug the TV for 30 minutes. Then plug-unplug 3 or 4 times in fairly quick order. After the last plugin - turn on the TV and the remote should be OK. THat's how we solved our problem
    Master:
    Sergeant:
  • 440 Answers
Ad remote usally droped or conecter wonttouch will have to order u a new remote thx for using fix ya lg.com has them or remotecentral ok
Posted on Feb 03, 2008
2 Suggested Answers
sabreusa
  • 271 Answers
SOURCE: Remote for one month old LG 37LG30 TV suddenly
Must be the IR receiver usually is soldered on a circuit board. Time to call your warranty..
N Sabre
Posted on Nov 07, 2009
My remote control for Haier tv stopped working, despite good batteries
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician.
Nov 19, 2014 | Haier HL32R 32 in. LCD TV
My LG AKB73375501 has stopped interfacing with my Blu Ray player but interfaces with my TV. I can only control my Blu Ray player via my TV remote. How do I get my LG AKB73375501 to interface with my
with lg this is normal and there is nothing you can do beside to take the set in for a exchange or repair service- I have an lg device or two that has the same issue, it is the players not the remotes. if i find a solution i will update you good luck questions just ask
Mar 30, 2013 | LG ELECTRONICS Remote Control AKB73375501...
RC-261 fails to turn on/off Insignia TV. Remote stopped working (batteries good)
Check the battery contacts inside its battery compartment for any rust or dust accumulated. Clean them well. If this too do not help you, check the remote control for its infrared emission. In some cases, cleaning the remote control may be necessary. If you wish to get more details about how to check, repair and clean a remote control, visit this site. Pull up older posts. One among the post has details.
Mar 24, 2013 | Insignia RC-261
Ah59-02342a doesn't control tv anymore
Hi I had exactly the same problem with mine it worked the DVD player fine but not the TV even though previously it had worked both .......... Manual Guide In the manual guide I managed to dig out it says to do the following to set up the remote to work the TV
Press the TV button on the remote
Then whilst holding down the power button you need to enter in the samsung TV codes until your TV turns off (I only got to the first and it did it)
The numbers are 00, 15, 16, 17, 40, 43, 46, 47, 48, 49, 59, 60, 98
Hope this helps
Feb 24, 2012 | Samsung TV Remote Control
Batteries are good. However TV isn't on right channel to show any programming what to do?
Hi William,
To confirm if the remote control is working fine, aim the infrared emitter of the remote control to your cellphone camera, press any button key and check if the infrared will flash to your camera. Watch this video on how to do this trick.
Also, does the front panel button key of the TV isn't working?
Jdvillanueva
Jul 09, 2011 | Toshiba CT-9995 Remote Control
Samsung TV remote. I noticed today my TV remote wasn't working. I changed the batteries and noticed there had been some leakage from the AAA batteries. Since changing the batteries the 8 buttons on the top...
Giving you some hints. Battery leakage is one enemy of tv control and other remote control. They can corrode your battery spring contact, give contact bridges with neighboring tracks that can cause erratic behavior of your remote.
Some repairs can be done but doesn't guarantee success. First is try to clean the corrosion on battery contact = no power usually. Erratic behavior cause by contact bridging = battery leak residues.
Opening a remote control. Some have screws on its small foot. Covered by a rubber or sticker. Some are notch clip in strategic location you have to fry that one by one, opening first on its weakest side. In some don't want to be open.
Cleaning the board by a soft eraser is one way. After you open the remote. Commonly the button area where contact takes place.
If the first procedure and cleaning doesn't work. Buy new remote or use universal remote controller.
Aug 23, 2009 | Samsung TV Remote Control
No remote control operation of TV
there is some probelem with tv so call its service center and repair it.
Jun 21, 2009 | Panasonic CT25G7 25" TV
Vizio remote control not working
Wow, I feel stupid! Solution #2 did it! There are 2 Tv buttons, one on the top right and one on bottom right. You have to press the bottom one!! THANK YOU PPL!!!
Apr 04, 2009 | Vizio VO47L 47 in. LCD TV
Remote won't work
Hi I had the same problem last night, so I took the batterys out  and left it for a Day, have just put them back and its working for the moment, hope that it keeps on working !!! good luck with yours.
Feb 18, 2009 | Samsung TV Remote Control
Vizio 50 inch plasma -- remote not working
You can also try to take out the batteries and push all of the buttons with the batteries out of the remote. Then put the batteries back in and push the power button on the remote. If this doesnt work press the two TV buttons at the same time and the remote should be fine.
Sep 14, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
LG 42PC3D 42 in. Plasma Television Logo
219 people viewed this question
