Question about Sanyo DS27800 27" TV
TV buttons keep sticking
My tv buttons keep sticking making the channels to change on there own
    Master:
    Sergeant:
  • 440 Answers
Try to spary sum wd 40 behind it ok see if u can undo sensor 1st thx nick
Posted on Feb 03, 2008
The channels on my ge 32gt720 tv keep changing by them self
Channel change button on the remote or on the side of the TV coule be stuck.
Jul 20, 2014 | GE 32GT720 32" TV
My viewsonic keeps changing channels which makes it impossible to use. We've unplugged it and everything. once you power it on, thats all it does. it continueusly changes channels. please help
The first thing to try is to see if a button is stuck on the remote or on the TV.
Remove the batteries on the remote and see if that helps. If it fixes the problem, you'll need to replace the remote.
If that doesn't help, look close at the buttons on the TV to see if one is jammed on. If changing channels continually up, then check the channel up button on the TV, if down then check the down button.
Worst case, you might have to take the back off the TV and unplug the cable feeding the external button panel on the TV and only use the Remote (for safety, rememeber to unplug the TV while doing any work on it).
Nov 28, 2013 | ViewSonic N3235w 32" LCD TV
Volume moving on it's own
Either the key/button the TV or Remote is stuck. Just remove the batteries of the remote and try. If same thing continues, do vacuum cleaning of the panel button/switch after switching of the TV, removing the plug from the power outlet. If the problem persists, this might require attention by a qualified service technician.
Jul 11, 2012 | Sanyo Televison & Video
Ihave spn 4235 plsama tv problem is keep scan channel and rase the valume by self also icanot use the remote control to use the tv for on and off just plug and unplug the wire power need help plz
First take the Batteries out of your remote control to see if the T.V. is still changing channels or not. If it stops changing the channels and volume, try opening the remote with a knife and clean all the pads with rubbing alcohol to prevent sticking buttons. Be careful if using a remote with a roller ball.
Jun 06, 2011 | Samsung SPN4235 42 in. Plasma HDTV
My t.v changes single the channels, if I am seeing a channel the minute changes to another one
Just a word of thought. Make sure your remote control is not pointing at the TV. Ive seen this many times. A faulty remote control sending out random signals to the TV due to fluid spillage in the remote. Try keeping the remote well away from TV and see if it still changes channels. If not, check the channel up and down buttons on your TV. Do they feel faulty when compared with volume buttons etc? If so, you might have a channel button on the TV that is half stuck in. Hope this helps :)
Feb 14, 2010 | Quasar SP-2723 27" TV
I have a HL-T5687S DLP TV. Since yesterday, my tv
right side push button stick ...check and open stick button
Nov 07, 2009 | Samsung HL-T5687S Television
Channels flipping non stop
Ether the front panel channel button is sticking or the remote channel button. take the remote out of the room.. if it still is changing channels make sure the channel buttons on the front of the set are not sticking. Spay a little WD 40 on them then wipe them off
Dec 03, 2008 | RCA F32649 32" TV
Channels keep scrolling
Check for a channel button on the front of the set.. one of them is sticking. Try spraying some WD40 around the front buttons and work each one to make sure none are sticking in..
Jul 31, 2008 | RCA F36650 36" TV
Sony trinitron tv KV-32LS36U changing channels
You may have a control button sticking either on your remote or on the front panel of your set. I have run in to this on several sets. When this happens, some really strange things will happen including problems like you're having. Stargazer
Jun 13, 2007 | GE 32GT660 32" TV
Sanyo DS27800 27" TV Logo
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
