Question about Danby 22 in. DDW396 Free-standing Dishwasher
Dial gets stuck
I turn the dishwasher on and it starts to work, only problem is that it intermittently sticks in the same spot instead of passing through the cycle, so after 20 minutes I go back and check on it and the dial is in the same spot, so I have to give it a little turn clockwise and it starts to continue through the cycle.
I've seen it stick in the one spot right past the longest cycle most often, I don't want to break it trying to investigate before asking a certified/experienced person from here what should be done.
Thanks in advance
  • Anonymous Apr 21, 2008
    I'm experiencing the same problem.  The little Danby has been great since we bought it over a year ago.  Don't want to lose it now.
Well that seems to be the heat sensor for water temperature all i did till danby sent me new sensory is bypassed the temp sensor.
Can do this on left hand side of unit under it white and red wire. Take the clips off sensor and tie the wire together just tells the timer to go on that temp ok and continues wash. when sensor comes in the put in and put clicps back on.
Posted on Nov 11, 2009
Danby sells the dial for about $30. It requires basic electrical and appliance repair knowledge to fix. Takes about 30 minutes.
Ray
Posted on Nov 28, 2008
MOST DISHWASHERS HAVE A PAUSE DURING THE HEAT
CYCLE IF TH WATER ISN'T HOT ENOUGH OR IF A HIGH
TEMP WASH IS SELECTED. NORMALLY, THE TIMER WILL
ADVANCE WHEN THE TEMP IS HOT ENOUGH TO TRIP THE
THERMOSTAT. IF IT NEVER GOES PAST THAT POINT, THERE MAY BE A FAILURE IN THE HEATER CIRCUIT.
Posted on Mar 26, 2008
How do I get my ge dishwasher to run? the lights
Hello there and welcome to fixya
If electrical power is available to the dishwasher but the appliance doesn't run, the problem is likely to be a defective door switch, timer, or selector switch. Make sure to turn off the power to the dishwasher before attempting any repairs
To solve a door switch problem, you may be able to adjust the door latch's strike slightly, using a screwdriver
then make sure the door closes securly, if this doesent work
please check the timer as follows
Dishwasher timer concerns can be classified into two general categories: the timer cannot be advanced manually and appears to be stuck or intermittent automatic timer advancement.
1. The timer dial cannot be advanced manually and appears to be stuck. Stuck timers are generally caused by objects that prevent the detergent cup from opening, or by a sticky substance between the timer dial and the control panel.
  • Objects that prevent the detergent cup from opening: If your timer will not advance, open the dishwasher door and check for items that may be blocking the detergent cup.
    Also, check the detergent cup:
    • It should be fully closed at the start of a cycle.
    • It should be fully open at the end of the cycle.
    • Almost fully open between main wash and final rinse.
    If it is in any other position, try to open or close the cup while at the same time rotating the timer. This should free it up. To prevent a reoccurrence, make sure nothing blocks operation of the detergent cup when the dishwasher door is closed and operating.
  • Sticky substances like orange juice that get between the timer knob and the front of the control panel on some models will bond the timer knob to the control panel. If you have this condition, it will be virtually impossible to rotate the timer knob while gently pressing the knob in toward the dishwasher. It will rotate normally if the knob is gently pulled away from the dishwasher while rotating the knob.
    This problem can be solved by gently pulling the knob away from the control panel and cleaning behind the knob with a damp cloth. Do not use excessive force because the knob is attached to the control panel on models affected by this problem. If this operation cannot be performed, service should be contacted to repair the problem.
2. Intermittent automatic timer advancement. This can be described as the timer can be advanced manually, but it does not advance automatically in spots for up to 30 minutes.
  • This is almost always a normal condition and always occurs on models with a "Delay Start" feature.
    Delay start timers increment or advance a couple of degrees once every minute or so during most of the cycle. However, during certain parts of the cycle they increment once every 30 minutes. This gives the dishwasher time to do the job of cleaning your dishes. The long increment times occur during "Delay Start", "Hot Start", "Normal Wash" and "Dry" cycles.
    The timer will not move at all during these delay periods. This is normal operation and service is not needed. If you notice delay times substantially longer than 30 minutes, replace the timer
  • Also ensue that you are getting adequate water pressure and the unit is getting water inside and that the water is at the right temperature 140 is the min. for most units
  • Please check the above and let me know what you have found so i can continue to help there is a lot of things to check but these that i have provided are the most common thing that need to be checked first ok?
  • Best regards Mike
Aug 21, 2011 | GE Dishwashers
The dishwasher delays mid cycle and will stay in the same spot, just after "short wash." If allowed to just hang there, it also develops a slight rubber burning smell. If I turn the dial past...
it sounds like the timer has a worn gear and will need to be replaced if you check with your local parts distributor they are rebuildable for a lesser cost
Feb 28, 2011 | Dishwashers
Dial sticks in two places until dial is moved slightly
HI. this Timer mechanism will need ot be replaced soon. the timer motor is defective. this will continue to affect the performance of this unit. replace asap.
Jun 20, 2009 | Frigidaire 24 in. FDB750RCC Stainless...
Cycle Sticks unless I manually move it along
Ya, the mechanical timer/dial is the problem. The heating element just got stuck on as the timer stalled in that dry cycle.
May 03, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
1998 kia sephia, starter kicks in but engine sometimes wont turn.
If it is a manual trans could be nuetral saftey switch but other then that check grounds at the bettery and engine .Still could be starter like you said flat spots on it hope this helps.
Mar 12, 2009 | 1998 Kia Sephia
Frigidaire FDB710LCS0 Dishwasher dial seems to stick?
I had the same problem. Turn the HIGH TEMP buttons off. Simply turning them off corrected this problem for me. Mine got stuck in two places and I had to manually turn the dials or the washer would run all night.
Nov 21, 2008 | Dishwashers
Cda dishwasher
green light on right flashing and beeping noise..Problem solved by thowing a few pints of water in the bottom of the dishwasher...must have 'primed' the pump..which must have been the problem; working fine now. David- Crosby
Apr 19, 2008 | Whirlpool 24 in. ADP5966 Free-standing...
Timer on dishwasher not working
ok start the washer after it fills and starts washing open the door again and turn the dial to drain shut the door see if it drains if it does then open the door and turn it to heated dry shut the door and get you a small glass of warm water let it sit in heated dry for about 3 minutes open the door and pour the water on the heating element and let me know if it sizzles
Mar 27, 2008 | Dishwashers
Danby 22 in. DDW396 Free-standing Dishwasher Logo
537 people viewed this question
Top Danby Dishwashers Experts
Jose Pino
Carmen Mikulic
Are you a Danby Dishwasher Expert? Answer questions, earn points and help others
