Question about Dayton Electric Heater
Wiring a dayton 3e367 garage heater
I have a Daton Fuel Trimmer model number 3e367 that has not owner manual. The previous owner of the garage disconnected the wires and I don't know which wires go with what. I called and electrican but he was no help without an instruction manual or wiring diagram.
Thanks
SOURCE: Lot of the wires came off the on the back of the Heater
We have a Dayton Unit Heater in the garage, gas. the wiring is a mess do you have schematics?
Posted on Nov 18, 2008
  • 108 Answers
SOURCE: Wiring diagram for a Dayton thermostat
Contact Dayton on the internet for this problem. The diagram should be available on their site. Or they will give you a number for customer care. They can give you step-by-step instructions. I am a technician and this is what I would do as their are millions of wiring diagrams. Many are noy up to date.
Ray
Posted on Dec 07, 2008
Therinnaiguy
  • 1420 Answers
SOURCE: installed dayton nat gas hanging furnace in garage
Hopefully there is a wiring diagram glued to one of the panels to verify but on the transformer you will have 2, 110 volt wires. One is the power coming in (usually black wire) and the other is a common (white wire) and will be connected to other common leads. On the low voltage side of the transformer one wire will go to the thermostat then from the thermostat to the gas valve. The other side will connect to the gas valve. When the thermostat calls for heat it completes the circuit from transformer to gas valve back to transformer.
Posted on Dec 11, 2009
heatman101
  • 43501 Answers
SOURCE: I was wondering if the Dayton fuel trimmer model#
Yes, it can be set on concrete blocks or anything non-flammable.
Also make sure that you do not run it if you are working with flammable gases or materials. I don't believe that that heater is sealed combustion.
Make sure also that you have correct venting so you don't wake up dead...
If you can take good precaution then go for it...
Heatman101
Posted on Jan 14, 2010
Testimonial: "Thank you your advice was fantastic"
  • 3087 Answers
SOURCE: Have 30,000 btu Dayton heater m#3e3665 when reaches temp. fan
Hi blow heater out with air line flame sensor could be dirty check out pressure switch jump this out see if it lights
Posted on Feb 09, 2010
Dayton space heater 350,000 btu
Sounds like you have a bolwer motor or fuel pump that has bad bearings, as it runs, it starts to bind up, and get to the point where it is pulling to much juice to turn it, and the fuse does it's job and blows?
If you could give be a bit more detail, I can help you furthur.
Please rate the new guy :)
And get back to me, so we can get the problem fixed for you.
Lets get this fixed.
Sincerely,
Paul Gibson
Apr 04, 2010 | Dayton Electric Space Heater - Model D-F79
Feb 09, 2010 | Dayton (3E379) Heater
I was wondering if the Dayton fuel trimmer model# 3E369B can be placed on blocks in the floor of my garage
Heatman101
Jan 14, 2010 | Dayton Gas Furnace Heater
Need ignitor and gas valve for heater
They sell dayton stuff at Graingers
Dec 04, 2009 | Dayton G73 Utility Heater
I have a Daton Fuel trimmer furnace for my garage.
On the thermostat see if it has a setting for fan on auto and off try turning the fan on then see if it comes on, if it does then it may be your thermostat has failed if it does not turn on then reset the circuit breakers to see if you have a breaker kicked off. If it was wired properly there should be one near the unit and one in the main breaker panel so be sure to reset both. To do this you must force the breaker switches all the way off then all the way on. On some breakers if you do not force it to the off position it will not reset the breaker. If this does not help let me know and I will try to help you some more just replay to the e-mail you get go to the bottom of the page and post add comment
Nov 10, 2009 | Reddy Heater RLP100 Portable Forced Air...
I have fuel but wont inite
what is the air pressure set at????need to be exact for unit to work properly
Jan 11, 2009 | Dayton E51 Oil Filled Utility Heater
Need wiring info on DAYTON 3E342A. All info needed .
if you will google the make and model number you should find a pdf owners/ service manual
Dec 17, 2008 | Dayton Electric Heater
Dayton Fuel Trimmer Shop Heater
flue diameter is 4 inch
Propane Unit Heater, BtuH Input 30000, Full Load Current 2.1 Amps, Gas Inlet 1/2 Inch, Flue Diameter 4 R,V, Motor Power Rating 1/30 HP, Free Air Flow 700 CFM, Height 27 1/2 Inches, Depth 27 5/8 Inches, Width 14 Inches, OC Mounting 8 5/8 Inches, 115 Volts, Energy Saving
Nov 20, 2007 | Dayton (3E379) Heater
Dayton Electric Heater Logo
248 people viewed this question
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
Dan Webster
Dan Webster
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
