Question about NEC MultiSync FE700 17" CRT Monitor
MultiSync E700 Monitor Issue
I have an old Sony computer I used with a MultiSync E700 computer that runs on Windows 98. I set it up about three months ago to teach someone computers. Initially, I had a problem getting the monitor to work and then all of a sudden it worked. I think it had something to do with the order in which I switched things on but I can't really remember.
Well, I haven't used it in a month or so and I am trying to use it now. I can't get the monitor to come on. The power is on it, the green light comes on but it turns orange and then a dull orange. What is wrong?
  • starbright08 Feb 03, 2008
    What does the video cable look like?
    Is it a wire or a belt?
    Scholar:
  • 119 Answers
I thins the trinitron core is demaged..it also can be the cable which connects it to the video card..trey to check this one..if not..sorry for your old great monitor...
bye
Posted on Feb 03, 2008
  • andi n.
    andi n. Feb 03, 2008
    well..it is the cable who get the connection between monitor and computer unit..to the video card..the entrance in the back of the monitor may be damaged..try to move it..to chenge its position for few mm...
  • andi n.
    andi n. Feb 05, 2008
    a wire with a special head..ususlly for old monitors it is detachable
NEC Multisync LCD 2080UX has a strip that appears on screen after 20 mins use.
Might be from overheating, monitors do overheat sometimes. I had the same issue happening to one of my old monitors and it wasn't fixable unfortunately. I had to replace it and get a new one.
Nov 05, 2013 | NEC MultiSync LCD1810X 18.1" LCD Monitor
I have a "Multisync e222w
You likely need to adjust your Windows OS resolution to match the native one of the Multisync monitor (1680x1050 pixels).
Apr 28, 2011 | NEC E222W LCD Monitor
My screen monitor doesn't light up. The icons are visible if I shine a bright light on them but even then they are quite difficult to see. Can this problem be fixed or do I need to acquire another...
You should consider taken it apart to see if caps are blown on power supply before you acquire another monitor . It is a common problem and not that hard to fix if you can use a solder gun . Just look for caps. that have tops that are not flat .
Feb 09, 2011 | NEC MultiSync E700 17" CRT Monitor
How do you put a monitor into power save?
Depending on your operating system go to Control Panel of Windows and find the Power Options section.
There should be a setting there to change how long to waite before the monitor sleeps.
Jul 16, 2009 | NEC MultiSync FE700 17" CRT Monitor
My monitors light is blinking all the time n no pic Nec Multisync FP1355
there is a setting you can access from the monitor menu button. make sure that the monitor is set for the cable you have running to it.
If you are using DVI use the digital setting.
Anything else, use the analogue.
Jun 28, 2009 | NEC MultiSync FP1355 (White) 22 in.CRT...
I hooked my new computer up to my NEC Multisync 1700V moniter. When I power the moniter up the GREEN light comes on until I get a "no Signal Message" and then the amber lihgt comes on.
hi, hook up your old one and change the refresh rate to 60 or 70 hertz, go 2 display properties, then the settings tab, then advanced,then monitor. and set it as i said. turn off computer after you change settings. hook up the nec, you then should be good 2 go. good luck! and please rate this solution. if you need further help, reply.
Apr 13, 2009 | NEC MultiSync LCD1700V 17" Flat Panel LCD...
Monitor keeps stating "monitor going to sleep" now awhile after booting up. The monitor works fine with other computers and the computer in questioning when in safe mode - yet if tried to boot normally,...
This is probably a video setting issue. In Safe Mode, Windows starts with low resolution and color settings, so the monitor can display them. But when it tries to start normally, Windows is using a video setting the monitor can't handle.
Start the computer and press the F8 key three or four times when the manufacturer's logo screen appears. This should get you to the Windows startup menu screen, and you can pick the option of starting in VGA mode. This will start Windows with video settings any monitor can handle.
Once you have Windows up and running, make sure the video card and monitor types are properly set up. It would also be a good idea to download and install the latest drivers for your video card. You can usually find them at the manufacturer's website.
Feb 01, 2009 | Compaq FS7600 17" Flat Glass Monitor
Driver for NEC Multisync XE21
Normally if you set the refresh rate to match what the specs are (mentioed above), it should go you working.
Jun 07, 2008 | NEC MultiSync XE17 (White) 17 in.CRT...
Multisync E700 Monitor Problem
try the moniter on another p.c. see if it works then
Feb 03, 2008 | Gateway FPD2275W LCD Monitor
Display Image Pinched Vertically
I think this is a non-ddc monitor. But I think you right, the monitor is damaged and won't read it's own driver. http://support.microsoft.com/kb/162737/en-us
Jul 11, 2007 | NEC MultiSync XV17 17" CRT Monitor
NEC MultiSync FE700 17" CRT Monitor Logo
116 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
