Question about HP Pavilion ZE4300 series: 1170B01-90 (PAVILIONZE4300SERIES1170B) CD-ROM Drive
Notebook utilities I accidentally removed the notebook utilities folder from the programs list. I can't "hibernate" the computer anymore.
  • 108 Answers
If you are using Windows XP then go to Screen Saver tab of Display properties. There you can turn on hiberation under the Power Setting command.
The shortcut to it is when you click "turn power off' and you get Standby, turn off and Restart buttons. Now press the shift key, the standby button will change to Hibernate.
Posted on Feb 04, 2008
Why does my new HP Win 7 Pro notebook crash on sleep and hibernate?
You may have a registry error.
Advanced Computer User Solution (manual restore):
1) Start your computer and log on as an administrator.
2) Click the Start button then select All Programs, Accessories, System Tools, and then click System Restore.
3) In the new window, select "Restore my computer to an earlier time" option and then click Next.
4) Select the most recent system restore point from the "On this list, click a restore point" list, and then click Next.
5) Click Next on the confirmation window.
6) Restarts the computer when the restoration is finished.
Novice Computer User Solution (completely automated):
1) Download (Error 41) repair utility.
2) Install program and click Scan button.
3) Click the Fix Errors button when scan is completed.
4) Restart your computer.
Jan 23, 2014 | HP 650 Notebook PC
Tip
How to Make Windows XP Startup Faster Steps 1.Click on Start, then Run, and type...
Steps
1.Click on Start, then Run, and type "msconfig". Wait for a new window to pop up.
2.Look under the "BOOT.INI" tab. You will see a box labeled "Timeout:", and a numerical value. By default, it's 30, which means 30 seconds of wait time before boot. This can be changed, using 3 seconds. (Note: if you have more than one operating system, this means the wait time to startup to the highlighted OS. you might want a bit more than 3 seconds)
3.Delete the temporary files periodically from your computer to make the applications run faster. Type %Temp% in the run dialog box by clicking on Start -> Run, and click on "OK". You will see an open folder with many files. Click on the Edit menu and click on Select all and then click on the File menu and select Delete. Note: Always confirm that the folder which is opened has a temp on the top of menu bar and the folder indicates that it is a temporary folder.
4.Perform a scandisk to see that your computer hard drive is in healthy condition and it helps your computer run faster.
5.Always perform a disk defragmentation at least once in a month. start the disk defragmentation from the system tools available in the accessories from the start menu. it takes a longer time and it is advised not to run any applications in the computer including the screen savers, while running disk defragmentation.
Hibernation
After you have done all this, another method you can do is to allow the computer to hibernate. Hibernation closes and opens Windows faster than normally. However, Hibernation is a good long-term solution, as it does not waste electricity.
1.Go to Start->Control Panel->Power Options. Click on the Hibernate tab.
2.Click on the box that says "Enable hibernation" to check it.
3.Click on the Advanced tab and change the Power buttons options if you want to hibernate by pressing the sleep button or the power button. Otherwise, holding the Shift key while in the Turn Off Computer menu will give you the option to hibernate.
4.Restart your computer every week or so to clear your computer.
The power can then be completely turned off, even at the socket so that no power is wasted.
Prefetch
1.Simply browse to the windows folder (Ex: C:Windows) and under there you should see the prefetch folder. Go into the prefetch folder and delete all the files (Careful! It should look like this c:windowsprefetch). We need to edit a registry key to tweak it. Open regedit and browse to this key:
HKEY_LOCAL_MACHINESYSTEMCurrentControlSetControlSession ManagerMemory ManagementPrefetchParameters
Under this key you should see a value named: EnablePrefetcher
It has 4 possible values:
0- Disabled : The prefetch system is turned off.
1- Application : The prefetch only caches applications.
2- Boot : The prefetch only caches boot system files.
3- All : The prefetch caches boot, and application files.
We don't want to disable it entirely. This would actually make boot times *longer*. This is because this feature is also used to speed up the loading of boot files. That is why we are going to pick the number 2 option. It allows us to keep the advantage of caching system files, without continually clogging the system up with applications.
Set the value to 2 and reboot.
The 2nd time you boot it should boot much faster. Remember that the side effect is that launching individual applications once windows has loaded will now be slightly slower.
Tips
When installing new software choose not to add the program to the startup folder.
. Regularly check to see what programs are running from your startup folder as malicious programs such as spyware may have installed itself without your knowledge.
. If you accidentally uncheck a program, just retrace the steps above and recheck the program and restart your computer.
. Adding more RAM to a Windows XP computer helps it boot faster, and since RAM prices are very low these days, it's an easy way to boot faster.
. uncheck system startup unnecessary startup programs*
Warnings
. Save any open work before making changes.
. Shut down all applications before making changes.
. Don't uncheck anything from Symantec or any other anti-virus or anti-malware software. Doing so may disable or hinder the protection of your PC.
on Feb 25, 2011 | Computers & Internet
Slow opening of websites
Steps
Hibernation
Prefetch
Tips
Warnings
. Don't uncheck anything from Symantec or any other anti-virus or anti-malware software. Doing so may disable or hinder the protection of your PC.Remove all toolbar from add or remove program. From control panel. Reset web settings from internet option.
Apr 14, 2012 | Microsoft Windows XP Home Edition English...
Too slow,how can i speed it up
Steps
Hibernation
Prefetch
Tips
Warnings
Apr 09, 2012 | Computers & Internet
My laptop is running slow
Steps
Hibernation
Prefetch
Tips
Warnings
Apr 05, 2012 | Lenovo Computers & Internet
How to uninstalled the expired AVAST antivirus from my PC?
Normal UninstallThe first thing you want to try is to locate Avast in the Add/Remove Control Panel and try to remove it from there. Follow these instructions to accomplish this.
1) Click on Start, Control Panel
2) Open Add/Remove Programs
3) Find Avast in the Programs list and highlight it
4) Click Remove and follow the prompts to uninstall Avast
Using the Avast Uninstall UtilityIf for some reason the normal uninstall does not work, you may have to download Avast's own Uninstall Utility.
1) Click on the following link and download the Avast Uninstall Utility to your desktop
http://files.avast.com/files/eng/aswclear.exe
2) Double-click on the file ASWCLEAR and run it
3) You should see the following screen
4) Click on the ellipsis and choose the folder where Avast is installed. This folder is usually in the Program Files directory. Ex. C:\Program Files\Avast
Be very careful which folder you choose since whatever folder is chosen will be completely deleted from your computer.
5) Once the uninstall has completed, reboot your computer. You may then try to reinstall it or another antivirus.
If for some reason the uninstall utility does not remove it, you may have to reinstall a newer version of Avast to then proceed to uninstall or you may have an issue where multiple antivirus programs are showing in the Windows Security Center.
Hope this help!
Sep 06, 2011 | AVAST Software Avast Free Antivirus
HOW CAN I UNISTALL FIX IT 9?
This came from the Avanquest Forum.
You can uninstall using the Add or Remove Programs component in the Windows Control Panel. This will initialize the Windows Installer to assist you with uninstalling.
If SystemSuite or Fix-It is not listed on the Add or Remove Programs list you can remove the program using the MicroSoft Installer CleanUp Utility. Please go to the following page and follow the steps on the web site. Run the utility and see if it detects SystemSuite or Fix-It and if it does then delete the entry. Once you've done this check the install directory located at C:Program FilesOntrackSystemSuite or Fix-It or VCOMSystemSuite or Fix-It and delete the folder if it still exists.
http://support.microsoft.com/default.aspx?scid=kb;en-us;290301
Best of luck getting this removed...I've read many reviews and people really dont' like it too much.
Aug 20, 2010 | Avanquest Fix-It Utilities 9 Professional...
My laptop was on hibernation. now it is not booting. please help
Hibernation is enabled by default in Windows Vista, and is one of the seven options (i.e. Hibernate) that appears on the Vista shutdown menu. Hibernate your Vista system will enable you to quickly restore to existing system state and intact workspace instead of start afresh, run programs and open your documents one by one again. If you do not use the hibernate feature in Vista, and want to delete hiberfil.sys and then recover the space occupied by the big hibernation storage file, the hibernation function can be turned off and disabled.
Unlike Windows XP, users cannot turn the hibernation on or off via Vista GUI interface anymore. Previously users can enable or disable hibernation via Power Options applet in Control Panel. This option no longer available in Windows Vista, which also enables Hibernate ability and creates hiberfil.sys by default. Instead, users have to rely on command line utility Powercf and Disk Cleanup Wizard to disable hibernation in Vista. Microsoft KB920730 provides details on how to disable and turn off hibernation on computer running Vista system. You must log on to Vista with user account in Administrators group to perform these action.
Click Start, and then type cmd in the Start Search box.
In the search results list, right-click Command Prompt or Cmd, and then click Run as Administrator on the pop up contextual menu.
If you are prompted by User Account Control for permission, click Continue.
At the command prompt, type the following command, and then press ENTER:
powercfg.exe -h off
Type exit, and then press ENTER.
Another easier workaround for those who’re not comfortable to work with command line is to disable hibernation and hybrid sleep feature in Windows Vista is by using Disk Cleanup wizard tool, the built-in Windows disk cleaner to delete hiberfil.sys file. The hibernation file must be enabled to access the hybrid sleep feature and the hibernation feature in Windows Vista.
Click Start button, then go to All Programs -> Accessories -> System Tools, and run Disk Cleanup.
Choose which files to clean up, either My files only or Files from all users on this computer is fine.
On “Drive Selection”, select the Windows Vista boot drive to clean up. Note that you must select the drive where Vista is installed, which normally is also the boot drive (C:) as hiberfil.sys file will be located on the root folder of it.
Once Disk Cleanup finishes scanning the system, Disk Cleanup for Vista window will open.
Select and tick the check box next to the Hibernation File Cleaner.
You can select or deselect other type files to clean or preserve from the available items or options in the list provided.
Click OK button when done.
Hibernation will now be removed and disabled.
It will solve your problem.
Dec 28, 2009 | HP Compaq Presario V3000T Notebook
Slow laptop
hi,
i would tell general steps to make windows faster.
  1. Click on Start, then Run, and type "msconfig". Wait for a new window to pop up.
  2. Look under the "BOOT.INI" tab. You will see a box labeled "Timeout:", and a numerical value. By default, it's 30, which means 30 seconds of wait time before boot. This can be changed, using 3 seconds. (Note: if you have more than one operating system, this means the wait time to startup to the highlighted OS. you might want a bit more than 3 seconds)
  3. Delete the temporary files periodically from your computer to make the applications run faster. Type %Temp% in the run dialog box by clicking on Start -> Run, and click on "OK". You will see an open folder with many files. Click on the Edit menu and click on Select all and then click on the File menu and select Delete. Note: Always confirm that the folder which is opened has a temp on the top of menu bar and the folder indicates that it is a temporary folder.
  4. Perform a scandisk to see that your computer hard drive is in healthy condition and it helps your computer run faster.
  5. Always perform a disk defragmentation at least once in a month. start the disk defragmentation from the system tools available in the accessories from the start menu. it takes a longer time and it is advised not to run any applications in the computer including the screen savers, while running disk defragmentation.
Hibernation After you have done all this, another method you can do is to allow the computer to hibernate. Hibernation closes and opens Windows faster than normally.
  1. Go to Start->Control Panel->Power Options. Click on the Hibernate tab.
  2. Click on the box that says "Enable hibernation" to check it.
  3. Click on the Advanced tab and change the Power buttons options if you want to hibernate by pressing the sleep button or the power button. Otherwise, holding the Shift key while in the Turn Off Computer menu will give you the option to hibernate.
  4. Restart your computer every week or so to clear your computer.
Prefetch
  1. Simply browse to the windows folder (Ex: C:\Windows) and under there you should see the prefetch folder. Go into the prefetch folder and delete all the files (Careful! It should look like this c:\windows\prefetch). We need to edit a registry key to tweak it. Open regedit and browse to this key:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\Memory Management\PrefetchParameters
0 - Disabled : The prefetch system is turned off.
1 - Application : The prefetch only caches applications.
2 - Boot : The prefetch only caches boot system files.
3 - All : The prefetch caches boot, and application files.
TIPS
  • When installing new software choose not to add the program to the startup folder.
  • Regularly check to see what programs are running from your startup folder as malicious programs such as spyware may have installed itself without your knowledge.
  • If you accidentally uncheck a program, just retrace the steps above and recheck the program and restart your computer.
  • Adding more RAM to a Windows XP computer helps it boot faster, and since RAM prices are very low these days, it's an easy way to boot faster.
  • Visit http://www.Sysinfo.org and look up the program and its details you don't know what one of the listed programs do.
  • uncheck system startup unneccessary startup programs*
here is another website link to handle msconfig utility
http://www.harry-inc.com/three-easy-steps-to-make-windows-faster
Apr 15, 2009 | Dell Inspiron 1501 Notebook
My laptop is not working right, it is extremely slow and something called Vongo keeps trying to install but won't and it won't do anything
Uninstall Vongo:
1. Restart the Notebook and keep Tapping F8.
2. Select Safe Mode and press Enter
3. Click on Start, select Run, type "msconfig" press Enter.
4. Click on Startup tab and uncheck the check box besides "isuspm"
5. Click OK and restart the system for the new settings to take effect.
Kate: Note: After you restart the machine you may receive a dialogue box stating 'System is running using Selective Startup', Check 'Don't show this message or launch the system configuration utility when Windows Starts' and click OK.
Kate: Now, restart the Notebook again and go into Safe Mode by tapping F8. Click on Start -> Control Panel -> Add Remove Programs.
Locate the Vongo Software and click on Remove to uninstall it.
If this does not resolve the issue, you may have to manually delete the files:
1. Double click on My Computer
2. Double click on C Drive
3. Double click on Program Files
4. Select the Vongo Software folder and press Delete.
5. Close the Window
6. Right click on Recycle Bin folder and select Empty Recycle Bin
This will remove the Software.
Now, run the Windows Installation Cleanup Utility, this will remove the registry entries for the Software.
You can download the Utility from the given below link: http://download.microsoft.com/download/e/9/d/e9d80355-7ab4-45b8-80e8-983a48d5e1bd/msicuu2.exe
(Note: Do not click on the link. Copy and paste the complete link in the address bar of the Internet Explorer.)
The Windows Installer CleanUp Utility does:
• Provide a dialog box where you can select one or more programs that were installed by Windows Installer. You select the programs on the Installed Products list in the Windows Installer CleanUp dialog box. After you make this selection, the utility removes only the Windows Installer configuration information that is related to those programs.
• Remove the files and registry settings that make up the Windows Installer configuration information for programs that you select.
Hope this resolves the problem with Vongo. Would appreciate if you rate it.
Thanks,
ArnWuLF
Nov 30, 2008 | HP Computers & Internet
Computers & Internet Logo
168 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
