Question about Meade LX200GPS Telescope
Meade LX200 10" - RA Gears slip when mounted on wedge (Milburn)
I have been using my LX200 10" for several years in Alt/Az position and have had many pleasurable viewing secessions and mediocre imaging secessions. I decided to build a concrete pier mount and Milburn wedge setup to advance my photo experience. I mounted my scope on the wedge and began my alignment process. As soon as the scope started slewing (btw the ra and dec directions are reversed so I had to stop the slewing) and then started slipping. The worm gear must have partially disengaged under the weight of the scope. the only accessories mounted to the scope were my 10x50 viewfinder and a newly added 80mm apo for auto-guiding. No cameras or counterweights were even mounted. I took off the base cover to inspect the gears for any damage do to this slipping. The gears appear to be in decent shape however I did not disassemble and clean the grease off to thoroughly inspect. I do not see any shavings or chips etc. so I believe there is little to no damage. I am suspecting that the spring tension on the worm gear/ drive motor is the culprit. Is there a Meade (or alt source) upgrade for this condition.
Thanks,
Barry
Those who always look up, find the wisdom to look beyond...
BC
  • sweiller Feb 28, 2009
    Hi all,
    I saw also a gear slip tonight (about 15°).
    There is nothing added on the telescope (LX200 Classic 10")
    What to do please ?
    Best,
    Sylvain
    Genius:
  • 1,027 Answers
The problem is the addition of the 80mm telescope to the assembly. The telescope is now out of balance, and places extra weight off-center as the position chages. Too great an off-balance will cause the main gears to 'jump' the worm teeth. The solution is to restore balance by adding counter weights as needed. Loosten the axis locks (carefully) and see which direction it wants to move. To balance my LX, I used a small bag with lead buckshot to determine how much weight was needed and where to achieve balance. Then I added fixed weights to the mount. Once this is done, the scope should track correctly.scopestuff.com has balance kits at reasonable prices.
Posted on May 22, 2008
Procedure to set up a meade 12" LX200R on
It's pretty much all spelled out in the manual. Here:
http://www.meade.com/manuals/TelescopeManuals/LXseries/LX200-ACF_manual.pdf
You should train the drives, and purchase a separate 12 volt power pack with the correct cigarette lighter style power cable. Calibrate motors BEFORE you train the drives with the same power source you will use outside at night.
If this is a GPS model-- and new--- I would execute a RESET on the hand controller-- calibrate motors and train the drives and take the scope outside and get a Satellite link and do a two star automatic alignment.
Make SURE you are centering the correct alignment stars. By the way TRAINING must be done in alt az mode before you put the scope on a wedge-- it cannot be done in polar mode.
Sep 18, 2011 | Meade 12 Inch LX200R f/10 Advanced...
I have 8" LX200 about
You have GOOD power? You can try and replace the hand controller cable--
I would also Calibrate motors, and retrain the drives. But re-training must be done in alt az mode.
Mar 14, 2011 | Meade LX200GPS Telescope
Motor tries but cannot move on the horizontal. Moves fine on the vertical. Usage only in Alt/Az mode. Only have the electronic controller that came with the scope.
You did tighten the AZ clutch? You did start from the HOME position? (turn the scope Counterclockwise to the hard stop)
Then you will either have to send it back to Meade for repairs, or open the bottom of the base, and look inside and see if the AZ worm gear is actually meshing with the motor. It could have come loose.
Meade customer service:
http://www.meade.com/support/index.html
Oct 08, 2010 | Meade ETX-125EC (500 x 127mm) Telescope
I would like some information on balancing a
Is this mounted Alt-AZ or is it on a wedge.
If Alt Az probably all you need is a rail and weights. If mounted on a wedge you may need a 3D weight arrangement.
See these web sites-
http://sctscopes.net/SCT_Tips/Balancing_an_SCT/balancing_an_sct.html
http://jan.eaglecreekobservatory.org/balance.html
Jul 18, 2010 | Meade LX200GPS Telescope
Meade ETX-60 Horizontal drive
The AZ worm gear is not engaging the gears. There is a spring next to the gear which applies pressure -- open up the base and see if the spring is loose or broken.
May 23, 2010 | Meade ETX-60 AT Telescope
HOW DO I USE THE TELESCOPE
he first thing you will need to know is does your telescope have a polar axis or not, that is, is it intended to track, or is it merely a point and look, or what we call Alt-Az. Alt means altitude and Az means azimuth, where Alt is the distance above the horizon, and Az is the direction in a circle around the horizon. If you have an Alt-Az mount, just skip the polar alignment step. If you have a polar axis, that is, your telescope is intended to track the stars, then find north, and make sure the polar axis is approximately lined up in that direction. It does not have to be too accurate, but make sure it is pointing pretty close to north. If you are not sure where north is, either use a magnetic compass, or try to find Polaris, the North Star.
Thanks.
Jul 02, 2009 | Meade Infinity 114EQ-DH Telescope
Confused with RA setting circle with Orion XT8 Dobsonian
An Orion XT 8 DOB cannot be polar aligned??? The mount is ALT AZ ---
You would need an equatorial platform to polar align. There are no setting circles on a stock XT??
May 16, 2009 | Orion SkyQuest XT8 Dobsonian Telescope
Azimuth motor stalling missing the electronic home sensor
Check for binding in the gears; my 10" had aluminium chips in the fork base that jammed the gear. Cured by removing the RA manual adjust assembly - was useless anyway, as it could only be used with the RA unlocked. One setscrew in the fork base holds it in place,just loosen and pull up.
Apr 16, 2009 | Meade LX200GPS Telescope
ETX125 PE new model. Elevation has totally stopped.
Could be that the DEC motor driver has died. That could be verified by swapping the connections between the RA and DEC. If the DEC now moves, then that is the problem. If not, then the DEC motor is bad.
Nov 17, 2008 | Meade ETX Premier Edition: ETX105 PE...
GOTO ERRORS MEADE LX200 10" CLASSIC
Most problems tend to be mechanical. Have you 'trained' the drive and set the backlash values? Those 2 can have dramatic effects on pointing accuracy. Also, if the optical tube is not in alignment with the mount, then nothing will work correctly. To check that, have the telescope in Alt-Az configuration, inside the house, loosen the RA lock, and shine a laser pointer on the corrector plate. as the telescope is rotated about the RA, the reflected spot should be steady. Adjust the DEC to minimize the diameter of the circle that is drawn. What is left, is the out-of-true on the DEC axis. That can be adjusted with the tube cradle alignment bolts.
Oct 17, 2008 | Meade Optics
Meade LX200GPS Telescope Logo
909 people viewed this question
Top Meade Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Experi
Level 1 Expert
Greg Cann
Greg Cann
Are you a Meade Optic Expert? Answer questions, earn points and help others
