Question about Apple iPod MA446LL/A MP3 Player
My iPod is pause crazy!
I have an iPod and it is a little over a year old and lately it has been putting its self on pause. i can barely get through a song with out having to push the play button at least five times. i dont know what is wrong, plaese help me.
Have you tried restoring it? I had a similar problem with one of my 30GB iPods about two years ago.
Posted on Feb 15, 2008
6ya staff
SOURCE:
What is wrong with my TV's Ypbpr input???
is this the only input where the TV does this? what happens when you disconnect this source? May be your source.
If the TV does this no matter what input, perhaps you have some leaky caps on the power supply PCB,. These can usually be detected by their bulging tops & usually self replaced (if you have the wherewithall) at a cost of less than $10.00
May 08, 2014 | Hitachi Televison & Video
Good Day. I have a 2010 e350 barely a year old. The car has only done about 1,500km. About a month ago I started the car and noticed the message that the ESP and ABS are Inoperable with the yellow...
something wrong in your statement
it is a 2010 car but barely a year old
the car is 7 years old
if you had a typo error and it is 2017 or late 2016 it will still be under warranty so you should be directing your concerns to a dealer service center for a warranty check and repair
Jul 22, 2017 | 2007 Mercedes-Benz E350 4Matic Wagon
My ipod works but i can barely see the screen help
Step 1: Go to Settings > Brightness > Drag Brightness all the way to the right.
Step 2: If this does not work, go to the Apple Store:
  1. If it is less than a year old, it will get replaced for free
  2. If it is older, they will repair if for a fee OR
  3. Bring your old iPod with you and buy a new one, you will get 10% off.
Feb 16, 2011 | Apple iPod touch
How do you set points for a 1974 yamaha 500
hello, old school bikers woud use a match book cover, get the lobe up , open points, close them to barely touch match book flap, tighten down see if it works, i have actually tried this it works on late model dirt bikes old triumps, late 70-80 dirt bikes, sounds crazy, try it
Mar 31, 2010 | 1974 Yamaha DT 360
IPod Touch doesnt show in "my computer"?
I know you were asking for rich, but I've got a suggestion that may help.. Have you attempted to put it into disc mode and restore yet? You said you have already done the 5 R's but with disc mode it should work. I've included a step by step below on putting an ipod into disc mode just in case you are unfamiliar with how it goes. I hope this helps you resolve your issue. However, if it does not resolve your issue; you most likely have a hardware issue and will need to either get the unit serviced or replaced.
Putting ipod into disc mode http://support.apple.com/kb/HT1363 Putting iPods with a Click Wheel into disk mode Before placing the iPod into disk mode, you should verify that it is charged. Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.) Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.
Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect" If you are having difficulty putting the iPod model into disk mode, set it on a flat surface. Make sure that the finger pressing the Select button is not touching the Click Wheel. Also make sure that you are pressing the Play/Pause button toward the outside of the Click Wheel and not near the center.
If you are still unable to put your iPod with a Click Wheel into Disk Mode, use one finger from one hand to press the Select button, and one finger from the other hand to press the Play/Pause button.
Apr 29, 2009 | Apple iPod 5th Generation
My computer doesn`t recognize my ipod?
Hi, try these steps
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  2. Press and hold the Play/Pause and Menu buttons simultaneously until the Apple/iPod logo appears, about 6 to 8 seconds. You may need to repeat this step.
Feb 02, 2009 | Apple iPod nano
Ipod nano switch off problem
Just hold the Pause button a little bit longer
also try charging the Ipod in the latest itunes software
May 20, 2008 | Apple iPod nano
Ipod nano green Help!!!
Try going to repair your iPod at apple.
I don't think they will accept it because it is a old version.
You can try. Or maybe your iPod hated you and wanted to die at the next day the warranty expires. (little joke there haha ^_^)
Hope this helps!
Nicholas
Jan 20, 2008 | Apple iPod nano
Ipod
Try restoring the ipod, this will erase all music from your ipod so make sure its backed up. it erases all of your ipods software and reinstalls it this will almost definitly fix your problem. if it doesnt, than the problem may be mechanical
contact me if my solutions doesnt work as hoped, or for further help.
Dec 26, 2007 | Apple iPod mini M9160LL/A MP3 Player
Apple iPod MA446LL/A MP3 Player Logo
48 people viewed this question
Top Apple Audio Players & Recorders Experts
Ekse
Sean Cole
Sean Cole
Jeffrey Groves
Jeffrey Groves
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
