Question about Frigidaire FEF366 Electric Kitchen Range
Oven will not power up.. relay does not engage
I recently went to bake and found that there is no power to either element in my oven. I baked a few weeks ago without incident. Pressing bake on the panel and setting a temp is all as usual, however, when it switches to preheat and actually turns on the oven (usually accompanied by a pronounced click from within the panel) nothing happens. I think the click is a large amperage relay within the panel that is no longer functioning. My ? is, do I have to replace the entire top panel or is the oven relay a separately replaceable part? Or if someone with more experience than myself knows I'm way off-base then by all means any help is appreciated.
  • wallywhol Feb 03, 2008
    ..also I forgot to say, the oven does not return any error codes as some others have reported. It all seems fine from the outside.
  • thunderbolt3 Mar 06, 2008
    Same exact problem, my range is only 4 yrs old. Only thing to add is that the broil piece works and the self cleaning doesn't. I noticed the entire is 125.00 not cheap. Any updates from the previous problem ? Thank You.
    Novelist:
  • 130 Answers
Hello wallywhol the panel usually has to be replaced. My suggestion is to pull out the range, unplug, then remove the back panel. You can now trace the wiring from the elements to where they connect. If you have a meter, you can plug the range back in and check voltage. There should be between 208 to 240 volts at the elements. If there is a bake relay not on the board, then it can be replaced seperately.
Posted on Feb 04, 2008
6ya staff
SOURCE:
How do I get my Whirlpool oven to work again?
You may have a damaged oven control panel. Contact your local utility and file a damage claim
Sep 07, 2018 | Whirlpool Ovens
Kenmore oven won't work
1.Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board.
2.
3.Even a bad relay door switch will hinder your oven from operating.
If your oven has internal fuses, a wiring or component problem could have caused a fuse to blow. A blown fuse is an indication that a component has shorted or failed, and the problem will need to be corrected. Most ovens that use fuses will have an indication of the circuits that are affected by a particular fuse. If an oven fuse has blown, then you should inspect the oven element and the associated wiring to determine the cause before replacing the fuse.
THINGS TO CHECK:
the broil element
is the heating element that is found at the top of the oven and produces a very high heat for broiling. If the broil element isn't working, you should first do a visual inspection for signs that the element has blistered or separated. If the element appears normal then you can check for continuity with a multi-meter. Remove power from the appliance before performing this test. Remove the back panel and locate the terminals for the broil element and inspect the terminals and wires for signs of overheating or damage.
If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. ( by placing the each of the meter prongs on each end of the heater element connectors) If the element is burned or no longer has continuity, it will need to be replaced. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
I offer free advice bcuz God is so good!
Apr 21, 2014 | Whirlpool RBS245PDS Electric Single Oven
Kenmore electric oven will not bake
The bake element
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. If the element is burned or no longer has continuity, it will need to be replaced.
Apr 04, 2014 | Kenmore 40494 / 40495 / 40499 Electric...
Oven does not heat up
2.
THINGS TO CHECK:
the broil element
The bake element
Feb 03, 2014 | Viking Ovens
Kenmore electric range oven baking element does not go on eveything else works
The bake element
Jan 30, 2014 | Kenmore Ovens
Have a lg oven lre30453st that the oven doent work the displa shows F7 clear the clock and unpluged it for 5min and still doesnt work.push the bake button it showed 375 thena second later went to...
Be sure you have 230 volts across the red and black wires at the terminal block the power cord attaches to. I suspect you have only one line to the range.
It is simpler to check a portion of the range first. Go to the relay board for the bake and broil elements. Check for incoming voltage between the red and black wires. You should have 230 volts all the time.
Set the oven control to bake at 350 degrees and check between the yellow and black wires that go to the bake element. You should have 230 volts. If you have 0 volts, check between the yellow wire that goes to the bake element and the black wire that goes to the terminal block of the range. If you have 230 volts here, the DLB relay on the relay board is bad. This will prevent bake and broil from working.
We can go through the relay board for the cooktop. I think it is best to eliminate one problem at a time.
Oct 16, 2011 | LG LRE30453ST (Electric) Stainless Steel...
No power to upper oven 'bake' heating element.
Sounds like you have it figured, need to spend some moola..........
You can ohm out the sensor to the oven should be about 1100 ohms at room temperature.((the sensor is the little rod with two wires attached to it sticking in the oven, as temps change resistance changes which is read by the board) The upper and lower oven sensors are probably the same,you could just swap them to test, but probably not necessary,might also be confusing if you do not do a lot of testing on a regular basis. Remember to unplug unit for safety.
The bake element if it was not bad should be about 20 ohms, bad would read open........
Feb 21, 2010 | Maytag MER6772 Gemini Electric Kitchen...
Electric oven will not maintain temperature. drops 20 degrees
Jump online & get the schematics for your oven.. You'll need to troubleshoot the bake circuit, which is comprised of 2 - 120VAC legs (240VAC is applied during bake). One 120VAC leg is from the DLB relay and the other is from the Bake relay. if either one is bad, or not energizing, you won't get any power to the bake element. (The bake element runs 100% of the time during the bake cycle. broiler only operates 25% of the time during bake) I have had luck re-soldering the relay leg nodes on the backside of the relay board, as they develop "opens" over time. The relays are designed for ridiculous ##s of cycles, so they're not *usually* bad.
Dec 23, 2009 | Amana AOCS3040 Electric Single Oven
Bottom Baking element not working
dmiller58
If all your connections are solid then your controller is defective. Did you get any faults before changing the element? Does the broil (one at the top of the oven) work?
Post a response
Regards
Sep 10, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Oven not working
Sounds like the oven control which is the clock is bad. The relay for the bake element has probably gone bad and will need to replace the control. You should check continuity on the bake element. If it shows resistance then it is ok. Also, on some models the overlay for the oven control is a separate part. If it is you will need to buy it also.
Oct 09, 2007 | GE JBP71 Electric Kitchen Range
Frigidaire FEF366 Electric Kitchen Range Logo
101 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Marvin
Marvin
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
