Question about Electronics - Others
Usbflash drive everytime i insert my flash drive a message pops p telling me that my device could run faster at 2.0 if i had it tuned up. my motherboard is an asrock gpro, i think it's not fitted with usb 2.0 when i bought it. can you improve it? thanks a lot.
  • berguiza1 Feb 04, 2008
    i tried it before i read your reply and it worked. thanks to you anyway. i hope it wont recur.the fault i guess was on the extensions i bought. could that be possible? i want to inquire another thing on what i need to be able to watch tv programs on my pc. some people i talked to tell me that i got to buy a video card before i get a tv tuner. is that right? thanks again for whatever comment you would give. more power to all of you. THANKS A LOT!
    Sergeant:
  • 201 Answers
Hey there berguiza1, the usb ports you have are an older generation. It is not possible to change them. However I suggest you get a USB 2.0 card and install in your computer via the PCI slot. They are quite inexpensive and easy to install. Also if you are using the usb ports on the front of your case, you may find the ports in the rear are 2.0. depending on the age of your motherboard. I hope this helps. Good Luck!
Posted on Feb 03, 2008
  • Devocap
    Devocap Feb 04, 2008
    Hey there, berguiza1, I am glad you managed to work out your previous problem. With regards to the TV on line issue, I will refer you to this site
    http://tech.yahoo.com/blog/null/15069
    If the link does not work, just copy and paste. Don't forget to read the comments which follow. I hope it helps. P.S. Thanks for the Rating. Much appreciated
My Kingston 8GB USB is not working. The device icon shows in my computer but everytime i try to access it, a message pops up indicating "insert disk" or "no disk". Checked the...
It sounds like your USB stick has died on you. Unfortunately USB drives are not very durable and these things happen, I've been through at least a dozen now! Try it in another computer and see if it works there. If it does then try updating the USB drivers on your PC.
Feb 26, 2011 | Computers & Internet
I have an old computer running windows millenium. I used to be able to access my flash drive but now a message pops up that says that i need to format my flash drive. I format the flash drive and try to...
Would you try to format your flash drive using this software which I uploaded HERE. Download and unzip the file. Then run the exe file.
Do the followings:
- First plug in your micro-sd card into you PC using USB cable.
- Run the downloaded "HPUSBFW_2.2.3_MASTER.exe" file.
- In the program menu window, select the device (your flash drive).
- Select FAT32 as file system,
- Confirm that all the format options unchecked. (Uncheck the quick format option)
- And click the "Start" button to begin formatting.
- Then restart your computer to recognize your flash drive. Or from control panel, go to Add devices menu and search your flash drive to find and add.
Hope this helps.
May 13, 2010 | 3ware Electronics - Others
When burning cd on i-Tunes a couple of tunes seem to burn but then it all stops with an error message: Drive G:Sony CD RWDVD 4450 pops up. What does this mean? What do I do? (Am using windows XP 2002)
open the iTunes player and in the HELP tab you will find RUN DIAGNOSTICS check only the CD/DVD drive tests and push NEXT button before that insert an recorded audio CD in your optical drive if you have problems with your optical drive , the run test will tell you.
Feb 28, 2010 | HP Pavilion A520n (DW233A#ABA) PC Desktop
Dear sir, I am having Transcend 2 GB pendrive but when I insert it in my computer, it gives message THIS DEVICE CAN PERFORM FASTER IF U CONNNECT IT TO HIGH SPEED USB 2.0 PORT and its speed is also ver
If you have a USB port on the back of computer plug it in there. Or use USB extension if it is uneasy for you to plug your pen drive from time to time. From there you can hook up your pen drive much easy.
Apr 13, 2009 | Computers & Internet
Moser baer 4 GB pen drive is not working
i have 4gb moserbaer pen drive when i inserted it in to the Xp system it give the message "Insert disk"
plz. solve this problem.
Aug 05, 2008 | Computers & Internet
Cruzer 2gig won't see usb 2.0
1)maybe not all of the slots are USB2.0 try the furthest slot from the one you put it in or in front of your computer.
2) you should NEVER format a flash drive. It will not work after a format. You now need a new disk.
Feb 19, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
1gb cruzer micro
This is caused by 1 of 2 problems:
  1. Your flash drive is corrupted in some way, forcing the computer to reformat it before you can use it.
  2. The flash drive was formatted for a specific device (like a piano) and was made only for that device.
  3. Your PC incorrectly recognized it
  4. You do not have the correct drivers installed.
If you have problem #4, you can go onto google and search "1 gb cruzer micro drivers".
If you have problem #3, try plugging your flash drive into a different USB port.
If you have problem #2 or #1 (Which it most likely is), then you should try or buy a software application such as PC Inspector, to recover those files. Then you may reformat the flash drive.
However, I found that sometimes, just restarting the computer, and inserting and re-inserting the flash drive sometimes does work. But that's not guaranteed.
Feb 05, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
LOCKV116
hello, i have a Kingston 2GB Pendrive.I had run a program "LOCKv116.exe" on my pendrive and set password on it, but now after inserting pendrive to my pc, it is detected but when open it this message appears "please insert a disk into drive G:" If try to format it message is "There is no disk in drive G:"..If I run the program LOCKv16.exe it shows a message "please insert the device or run this utility as previledged user."
Dec 28, 2007 | Computers & Internet
Electronics - Others Logo
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
