Question about Eureka Smartvac 7975 Vacuum
Eureka 4470 The suction works from the hose, but not from the base. I do not know how to remove the cover to check the inside.
    Master:
    Sergeant:
  • 440 Answers
Take apart botem 1st cheak the hoses for sumthign in there ok stick a hanger in it poke it out from bottem side under
Posted on Feb 03, 2008
Need to replace belt in eureka envirovac model 4470
You must remove the screws that hold the top cover onto get to the belt. Remove top cover then remove brush roll to install new belt. Replace belt at least twice per year for proper cleaning.
Oct 26, 2013 | Eureka High Filtration s Mighty Mite...
Eureka Smart Vac The Boss no suction from either setting. I have taken it apart trying to see if it was clogged but it isn't. Checked the hose it is not sliced.
Remove the bag cover and feel for suction above the motor. If their is suction there then check the bag compartment is sealed. You can drop a coin down the hose to check for blockages all the way to where the bag attaches.
Aug 16, 2013 | Eureka Smartvac 4870 Bagged Upright Vacuum
Eureka pet expert vacuum lost suction
I had the same problem with exact same vacuum, was working great and the one day just lost almost all suction in the hose and in very very poor suction on base when vacuuming carpet, also when vacuuming the carpet everything I vacuum shoots out the bottom and hits my feet, never happened b4, checked all hoses and tor apart every thing to see if their war dust in motor, clogging anywere but nothing everthing looked great, NEED HELP CANT AFFORD TO BUY ANOTHER VACUUM OR TO TAKE TO REPAIR MAN TO B CHRGED AN ARM AND LEG, SOMEONE PLEASE HELPPPP!!!!!!!!!!
Jun 05, 2012 | Eureka 3276AZ Pet Lover Bagless Upright...
Eureka rm 4480
Hi there SmartAlec from NelsonVacuums.com.au . Unless there is a bad sound coming from your vacuum i would suggest you have a blockage. This machine is prone to getting blockages in 3 different places.
  1. at the base behind the brush.
  2. Inside the main suction hose - this should be removeable so you can drop a small coin through. If it doesnt fall easily viola blockage found.
  3. Where the dirt enteras the chamber or bag.
Basically start by removing all hoses and filters and turn machine on put your hand over all inlet and exit points provided you can feel airflow at one of these points work backwards from there and identify the point at which you no longer feel airflow.
HAPPY vacuuming !
Aug 26, 2009 | Eureka Whirlwind 4480 Upright Vacuum
No suction on my eureka boss smart vac. The belt is fine and the roller moves. I just changed the bag but no dice. any insight?
I know this is an old question but this is a good vac and maybe I can help somebody else some day, wish I'd figured this out a couple months ago when this problem first started. :} Anywho, this is another option from an amateur; I don't know the right terms but here goes: Right below the yellow flow knob (Floor/Hose) are the tops of two hoses, one to floor beater, one leading to hose. There is a sort of black clip holding these in place. Open it up, it hinges toward the front of the vacuum. On the back of the vacuum to the right of the lower cord wrap is a gray screw-looking thing, with little pix of locks imprinted above - one locked, one unlocked. Turn the screw toward unlock. Take the top of the black tube that leads to the hose and maneuver it out of the hole it's in, and you may find your clog in the top there. I found just a handful of dog hair, leaves and sticks stuffed in that tube but it was dense enough to stop flow to the hose. Removing it fixed the problem completely.
Aug 15, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
Eureka vacuum
if you have ran over any big objects you might try removing the cover from bottom take out the roller brush and see if it is clogged from the bottom
Nov 30, 2007 | Eureka Altima Upright Vacuum Model 2996AVS...
Eureka Central Vac-Sweeper -Model B1501
I like using a Wire Clothes hanger to work the stuff out with. If you fashion a fish hook of sorts out of the wire, you can catch things inside the brush head and pull them out.
Oct 24, 2007 | Vacuums
Eureka Smartvac 7975 Vacuum Logo
104 people viewed this question
Top Eureka Vacuums Experts
Jim Parker
Jim Parker
charlesjo336
Level 1 Expert
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
