Question about Samsung SCH-u740 Cellular Phone
DIALING W/ACCESS CODES
HOW DO I PROGRAM, THE DIAL A # THAT FIRST HAS AN ACCESS CODE, THEN AN ACCOUNT #, THEN THE CONTACT #? I HAVE PROGRAMMED THE CONTACT WITH "W" (WAIT), BUT I DON'T KNOW HOW TO MANUALLY COMMAND THE PHONE TO CONTINUE WITH THE CODES & #.
    Brigadier General:
  • 7,752 Answers
Sorry but contact your mobile provider customer service line to further assist you with this issue
Posted on Sep 20, 2008
How do i program the programmable feature buttons on my panasonic kx-t7731
To what, for what? The buttons can be used to dial inside or outside numbers. They're programmed by pressing PROGRAM, the button, and dialing a sequence. If the call is outside, that sequence includes an "access code" usually "9" then STORE.
Carl
Jul 06, 2011 | Panasonic KX-T7731 Corded Phone
Panasonic KX-T7730 Corded Phone programmed speed dial numbers not working. will not dial numbers programmed
When the system is installed, you need to make sure that only the lines equipped are in the access plan (program 400 in a TA series box). When you go to the intercom on a phone and dial "9" you should get an outside line every time. If that works, system and personal speed dials include that access code as part of the number. eg my test number is 914197845522 9+1+10 digits.
Carl
Apr 01, 2011 | Panasonic KX-T7730 Corded Phone
How do I program a phone number to the one touch buttons on a Panasonic KX-T7730 phone?
It depends on what you get when you dial "9" on the intercom. If you get an outside line, then the 12 right side buttons on your phone can be programmed for one touch dialing like this:
On an idle phone, press PROGRAM a button and dial 9 plus the number and STORE. You can program more than one button by just pressing button numbers and STORE. Exit programming by picking up the handset and dropping it back down.
If you want a specific line, you may be able to dial the specific 8x code to access a line directly, or you can go into system programming and delete the open lines in program 400. Disabling would be the best, because if your 8x line is busy, you can't make the call with the auto dial button.
Carl
Mar 08, 2011 | Panasonic KX-T7730 Corded Phone
How can i use the buttons of panasonic kx-t7730 corded phone ?
The 12 buttons on the right can be used for personal speed dial numbers and features like paging. They are programmed by pressing PROGRAM dialing codes and STORE. An outside call would use an "access code" usually "9" plus the number. Paging is 330.
The 12 left side buttons are very valuable as they have lights. You can store lines, extensions, and features that require lighted buttons, such as CID Indication or VM functions. They are programmed by PROGRAM the button a code the feature and STORE. For example, lines are programmed with 0 + line Extensions with 1 + ext and CID Indication System with 96 or the 9x voice mail commands.
Your OM or User's manual has a section on flexible button assignment with the codes and buttons required to do the programming. In my TA-824 200-OM it's in section 3.1.3.
Carl
Feb 19, 2011 | Panasonic KX-T7730 Corded Phone
Hoi have got speed dial on the main switchboard, so how do i do speed dial from other extensions
There is system and personal speed dials. System is programmed from the main phone and is dialed by using the AUTODIAL button and dialing a 2 or 3 digit code, depending on which system the 7730 is connected to. The other is PERSONAL speed dial, programmed on the 12 buttons on the right side of the phone. Those are programmed at each phone by using PROGRAM pressing the button and dialing an access code (usually 9) and the number then STORE.
Carl
Oct 23, 2010 | Panasonic KX-T7730 Corded Phone
KX-T7730 phone. Need to reprogram one of the PF buttons as a CO2 button. I accidently messed up the programming of this button while trying to program a different PF button as a one-touch dialing...
Just so we're on the same page, the PF buttons are the 12 buttons on the right and their ONLY function is one-touch dialing. They can't be CO buttons. The 12 buttons on the left are called CO buttons and they can be programmed to do a number of things, including CO, DSS, and feature access buttons.
To reprogram the button, press PROGRAM, the button, the dial 0 + the CO number (1-8) and STORE. Extensions are 1+ext and one-touch are 2+. Other features are in the programming guide.
The PF buttons are programmed by just dialing the digits, but if it calls out, you must dial an access code first, usually "9".
Carl
Jun 17, 2009 | Panasonic KX-T7730 Corded Phone
Faxing with a long distance code
after you dial the number you hit the pause button (usually 1-2 times) then dial additional numbers.
basically everytime you need the machine to wait for something to happen you need to hit pause
example: i have to dial five digit access code for my fax for LD calls it would be dialed on fax like this
1-234-567-8901 pause pause 12345 start
May 04, 2009 | Brother IntelliFAX 1170 Plain Paper...
Programming Auto Dial Number
Yep. Those are speed dial numbers. They are programmed from ext 101 or the main phone. Without picking up the handset, press PROG **1234 and dial 001 and ENTER. Dial your 3 digit speed dial number If there is something there, it will be displayed. A speed dial number is stored with the trunk access code in it (usually 9) so if you're putting in a new number, include the "9" plus the number exactly the way you dial it. Dial your new number with the access code and press ENTER.
Number changed :-)
You can keep putting in a whole boatload of new numbers with this procedure.
Carl
Mar 16, 2009 | Panasonic KX-T7633 Corded Phone
Extension Phone Numbers
Press Superkey
press NO until personal keys? is displayed
Press YES
Press the desired Personal Key
make sure key is not programmed
Press Change
speed call will appear
Press YES
dial the number to be saved
include the outside access code and area code,if necessary
Press SAVE
Press SUPERKEY AGAIN TO EXIT
Jul 07, 2008 | Mitel Superset 420 Corded Phone
Samsung SCH-u740 Cellular Phone Logo
51 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
