Question about Kenmore 24 in. 15142 Built-in Dishwasher
Kenmore QuietGuard I'm not exactly sure how it happened but somehow the piece that keeps the round spinny thing in place broke off. The dishwasher still works but it doesn't clean or rinse as well as it did. Do I need to call Sears and have them come out to replace the bolt or is there something that I can rig up from the local hardware store.
    Master:
    Sergeant:
  • 440 Answers
If u can get orginal bolt cheak locak store applices see if they have any in back room then u could if u cant get right bolt have them get u one ok thx for using fix ya
Posted on Feb 03, 2008
Kenmore Quietguard 2 dishwasher not filling.
There is a solenoid that keeps the water in the washer. It is either faulty or there is something preventing it from closing completely. If there is no power applied to the washer, does it then hold water?
Apr 28, 2010 | Kenmore 24 in. 17002 Built-in Dishwasher
Hello, i have a Kenmore Quietguard standard dishwasher. it is in the "lock" position under dry options and the dishwasher will not start. can you tell me how i might be able to re-start this?
On our Kenmore Quietguard the lock light is at the Air Dry button. Holding the Air Dry button for about 8 seconds turns the lock light off if it is on and on if it is off.
Jan 04, 2010 | Kenmore Dishwashers
Kenmore Ultrawash Quietguard Deluxe Problem
kenmore washers nothing but problems, my washer says clean and will not do any cycles...... less that 2 years old
Oct 21, 2009 | Kenmore Dishwashers
Kenmore quietguard standard wont start.
is there any function at all? if not, check thermal fuse located inside near control panel, check www.searspartsdirect.com and enter your model # to show how to take it apart. If it has functional display lights, replace main control board after ohm test on wash motor and fill valve.
Jun 25, 2009 | Dishwashers
I have a Kenmore Quietguard dishwasher, only a few years old, and it won't drain. I pulled it out and checked the drain hose, could not find a clog. I took the basket and sprayer out, couldn't find any...
I have a Kenmore Quietguard portable that won't stay connected to my kitchen sink faucet. Checked all I can and continues to spray the wall and me without staying attached securely to the faucet adapter. Help!! Any ideas?
Jun 17, 2009 | Kenmore 24 in. 15162 Built-in Dishwasher
Whirlpool dishwasher spinny thing is rattling
Hi, I suggest u to check these :
  1. Check the spray arm for damage and obstructions
  2. Check the inlet filter screens
  3. Test the water inlet valve
  4. Check the motor and mounts
  5. Check the fan motor and blade
  6. Check the drain for obstructions
Apr 11, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Kenmore Ultrawash QuietGuard 3 Dishwasher not draining or rinsing
Not draining may either need new drain motor. or something is blocking the drain pipe.
Spots on dishes means you are using to much detergent or the wrong kind of detergent.
Your owners manuel should tell you what type to use.
Nov 18, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Hi Claire,
Are you using rinse aid?
that may help with the film.you may also have stuff down in the trap causing the water to drain slow.
Nov 05, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
check the water inlet valve first
May 05, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore Quietguard Plus/Ultrawash - Kenmore
drain hose may be partially clogged or kinked up. ensure that the hose is not bent up thus restricting the flow of water out.
Nov 26, 2007 | Kenmore 16602 / 16604 / 16609 Built-in...
Kenmore 24 in. 15142 Built-in Dishwasher Logo
62 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
